Basement HT Drop Ceiling - Green Glue and Drywall - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-11-2013, 03:12 PM - Thread Starter
gmanvbva's Avatar
Would it be worth the time to cut strips of drywall and glue it to the underside of my first level floor between the joists?
I really want a drop ceiling (using ceilinglink) but want to get some sound dampening between the 1st floor (dining room) and basement home theater room located directly below..
gmanvbva is offline
post #2 of 5 Old 07-11-2013, 03:48 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Stuff it with pink would be easier and cheaper
Mfusick is offline
post #3 of 5 Old 07-11-2013, 03:59 PM - Thread Starter
gmanvbva's Avatar
I was thinking of doing both. Stuffing insulation in where possible.
gmanvbva is offline
post #4 of 5 Old 07-11-2013, 07:37 PM
Quoted: 3255 Post(s)
Liked: 2743
If your dining room is hardwood, adding strips of drywall with green glue under the subfloor will make a big difference, do two layers. PM Snickers1 he was the last one I remember doing this at his place.
post #5 of 5 Old 07-11-2013, 07:49 PM
greedo's Avatar
I put two layers of 5/8" drywall in a GG sandwich between my floor joists. I noticed a very large improvement, and I have carpet on the floor above me. I can't imagine not doing it with hardwood upstairs. It's a bit of work, as each joist cavity varies a bit, but it's not crucial to seal the joists; you're really just adding mass to absorb the footfalls.
greedo is offline
Green Glue Noiseproofing Compound 12 Tubes
