Placing compressed fiber glass next to the front speakers on the side walls - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-13-2013, 01:56 PM - Thread Starter
sukumar's Avatar
Quoted: 12 Post(s)
My front speakers are very close to the side wall. I plan to place 2inch or 4inch compressed fiberglass (2feet x 4feet) panels on both side walls.
Is it good practice to place panel just next to speaker on side wall?
Is it advised to use 2 inch or 4inch panels?
If I need to place on the side wall next to the speaker, does bottom of panel starts from the floor or from the ear height.
Appreciate your help.
sukumar is offline
post #2 of 3 Old 07-13-2013, 03:19 PM
Mad Norseman's Avatar
Liked: 101
Go to this website and read up - there's a lot of great advice on acoustic treatment 'dos and don'ts',
Its well worth the visit.
http://www.atsacoustics.com/
The Insane Pink Care Bear's Home Theater Set Up:
Marantz AV 8801 Processor, Emotiva XPR-5 Amplifier, Panasonic 65" ST30 Plasma, Yamaha BD-S2900 Blu-ray, Yamaha CDC-697 CD Player, Yamaha TT-500U Turntable, w/Signet TK5e, JBL ES100 Fronts, JBL LC2 Center, JBL ES30 Surrounds & 2 JBL ES250P Subwoofers
Mad Norseman is offline
post #3 of 3 Old 07-15-2013, 12:20 PM - Thread Starter
sukumar's Avatar
Quoted: 12 Post(s)
I could not find much information other than FAQ on the web site. Appreciate suggestions from anybody.
I already made 3 panes 2x4 OC 703 with thickness of 4inch. I got help from another forum to place about 1 1/2 to 2 feet above the floor. When I place speaker next to the panels in an angle, the panel will be almost close to center of the speaker.
I will also test with anthem receiver software if there are any bumps. Since my speakers are almost close to the wall and I don't have space due to bigger size of the screen, I want to use panels as absorber.
sukumar is offline
