What wood is used for "goal post" minimal frame. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 07-18-2013, 03:00 PM - Thread Starter
kainers's Avatar
I went to lowes and showed them picture of people's goal post framing and they aren't sure what is used. I'm heading to Home Depot now, can someone tell me what to ask for?
kainers is offline
post #2 of 15 Old 07-18-2013, 03:06 PM
HopefulFred's Avatar
Quoted: 490 Post(s)
Liked: 422
I think you want the finger jointed (joined?) pine. It is built from small straight pieces joined together. I think it usually comes primed and in a small dimension, like 2x3.
Hopefully someone can confirm.
HopefulFred is offline
post #3 of 15 Old 07-18-2013, 03:11 PM - Thread Starter
kainers's Avatar
Ok thanks ! Is it something that comes jointed together , or I make that myself ?
In lowes they don't have any "posts" just thin pieces like moulding.
kainers is offline
post #4 of 15 Old 07-18-2013, 03:45 PM - Thread Starter
kainers's Avatar
I'm at Home Depot, they only have pieces like 1x4, 1x2, etc. but they have fjp.
kainers is offline
post #5 of 15 Old 07-18-2013, 03:48 PM
Quoted: 490 Post(s)
Liked: 422
Mostly it is molding. I can't find it at lowes.com right now but hd has 1x3 molding like what I was describing. Store sku 424600
post #6 of 15 Old 07-18-2013, 03:57 PM
Quoted: 490 Post(s)
Liked: 422
Try lowes item #360066 1x4x16 spruce-pine-fir primed board.
post #7 of 15 Old 07-18-2013, 04:02 PM
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 139
The minimalist design does not include traditional posts. It's smaller pieces like the fjp you are finding, joined together in an "L" shape to make a "post". Sounds like you found the right stuff. Here's a link showing what I used (in various sizes).
http://www.homedepot.com/p/1-x-3-x-8-Primed-Finger-Joint-Board-424600/202085979?N=1z11df5#.UehlV6xjGSo
Big actually found 5/4 stock, but I wasn't able to find it. My HD only had the 1" stock and it worked just fine.
Spaceman is offline
post #8 of 15 Old 07-18-2013, 04:14 PM - Thread Starter
kainers's Avatar
Ohhh. Thanks! That makes sense. I just thought they were solid beams, but I see what you are saying now. Thanks everyone
kainers is offline
post #9 of 15 Old 07-18-2013, 07:59 PM
Quoted: 3255 Post(s)
Liked: 2743
post #10 of 15 Old 07-18-2013, 08:47 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
You don't need the fancy stuff for trim work. No 2 is fine. Save your cash. If they don't have "primed" you could always prime or paint it yourself (extra cost and work)
Mfusick is offline
post #11 of 15 Old 07-19-2013, 12:49 PM - Thread Starter
kainers's Avatar
Ya,
Thanks everyone. My main issue was I never knew the posts were an L. Thanks for clarifying that for me. The pictures were great as well. Thanks again!
kainers is offline
post #12 of 15 Old 07-24-2013, 08:13 PM - Thread Starter
kainers's Avatar
Should I paint the front of the posts black before I wrap them in velvet?
kainers is offline
post #13 of 15 Old 07-24-2013, 08:24 PM
Liked: 2743
Any fabric wrap pre-paint is a function of the fabric and if there is see through. Just another data point, I've never wrapped the goal posts.
post #14 of 15 Old 07-24-2013, 08:31 PM - Thread Starter
kainers's Avatar
Thanks Big, I have the triple plush from syfabric. I feel like I can see the white of the post when I hold up the velvet, but I'm also right up on the posts. I'd imagine light spill past the actual screen frame wouldn't be an issue for the wall frame.
kainers is offline
post #15 of 15 Old 07-25-2013, 05:11 AM
Liked: 2743
