Sump Pump Failed - HT 2.0 Theater - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 32 Old 10-06-2013, 09:55 AM
HeWhoRoams's Avatar
I think my electric is moving forward OK, but I'm looking at the best place to buy insulation (probably getting it lowe's/ HD) and a drywall installer. I've interviewed 3, they had some range in price but none seemed too expert on my soundproofing ideas.
I'm looking at ceilings with RC, DD+GG, which they said they could all do.
HeWhoRoams is offline
post #32 of 32 Old 10-17-2013, 07:16 AM - Thread Starter
Jeff in Canada's Avatar
Quoted: 167 Post(s)
Liked: 61
Finished up my wiring. Ran new speaker wires (12 gauge) and ran power and RCA (coax) cable for extra sub placement.
My plan is to have a sub at the front and rear walls, dead center.
I finished up the insulation last night and the poly barrier. I pulled out some of the insulation I felt they did a bad job with the first time. I added more layers as well. I also caulked all joints and holes. I also put up 5 sheets of OSB (5/8") along the walls 3/4" up from the cement.
I'll put up some pictures before and after some of the OSB going up and the insulation done later tonight or tomorrow.
HeWhoRoams likes this.
Audio: Denon AVR-4520, Fusion 12 Tempest (LCR), Fusion 8 Alchemy (4xSurrounds+2xWides+2xHeights),4 x 15" Dayton Ultimax
Video: Sony VPL-HW40ES, Darbee Darblet, SMX 2.35:1 Screen
Seating: Fusion Lagoon Chairs
Theater Build
DIY Speaker / Sub Build
Jeff in Canada is offline
Klipsch Rw 12d 12 Subwoofer Each
