Tracing coax through drywall and only have one end of cable - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-03-2013, 09:48 AM - Thread Starter
dand13's Avatar
Hello,
I recently purchased a house and found a blank faceplate in the living room. Behind it was a coax cable with no F-connector. Had the cable company come out, put an F-connector on it and tone test it to see if it runs back to the main junction box. Apparently it does not. I went into the (finished) basement below the living room, can see about 18" of the cable, but then it runs back into the ceiling of the basement. I've had the cable company out twice more, they've tone tested every F-connector in the house, but none of them pair to the living room outlet.
Is there a device/process that I can use to find the end of this coax? I'm sure it was covered when they finished the basement. I'd love to use a wire tracer (eg - http://www.homedepot.com/p/Sperry-LAN-Tracker-Wire-Tracer-ET64220/202520187#.Uf0iFtLVAz8 ) but I'm afraid the shielding on the coax will prevent that from working.
Thoughts? I'm approaching desperation.
thanks!
Dan
dand13 is offline
post #2 of 2 Old 08-03-2013, 10:40 AM
Quoted: 3255 Post(s)
Liked: 2743
what might be useful is a tone generator and probe. Basically you send a signal in the wire and wave the probe around in the vicinity of the wire and it will sound a tone that you are getting close. It can locate a cable on the other side of a piece of drywall. If you have any luck you can trace the path. Surprised that the guys who came out didn't have one.
http://www.flukenetworks.com/datacom-cabling/installation-tools/Pro3000-Analog-Tone-and-Probe
