Stage build - roofing felt or liquid nails between OSB layers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 09-02-2013, 05:45 AM - Thread Starter
joetarin's Avatar
So yesterday I spent all day building an 18' wide stage for the theater room. The first layer of OSB for the top is down and I need to add the second layer to finish it off. I have read that most people are putting roofing felt in between layers but wanted to see what people thought of using liquid nails instead (and regular nails) .
Is the layer of felt really crucial for minimizing the vibrations?
Notes: roofing felt was used as the stage base layer as well as 2000+ lb of sand to fill the stage.
Sent from my DROID RAZR using Tapatalk 2
joetarin is offline
post #2 of 10 Old 09-02-2013, 05:55 AM
NGiovas's Avatar
Liked: 43
First choice would be Green Glue. Second choice would be roofing felt. I wouldn't use regular glue or adhesive. Also, I suggest screws over nails to keep everything tight over time.
Nick
NGiovas is offline
post #3 of 10 Old 09-02-2013, 06:27 AM
Quoted: 3255 Post(s)
Liked: 2743
+1 GG first choice, then felt. Use screws
Looking at the pictures I don't see a lip (overhang) of the top decking. Your carpet layers are going to hate you. With a lip they cover the top bring it around under the lip and staple out of sight. Then cut a strip for the vertical fronts. With no lip bringing it out around and down a curved stage will be a challenge. If you planned on banging on something after the fact, never mind.
post #4 of 10 Old 09-02-2013, 09:19 AM - Thread Starter
joetarin's Avatar
Thanks fellas. I will source GG to use and will use screws to hold it down.
And yea, I'm planning a 1.5" lip over the curve.
joetarin is offline
post #5 of 10 Old 09-02-2013, 09:23 AM - Thread Starter
joetarin's Avatar
Another question, 1" or 1.5" lip?
My only concern in having a larger lip is someone stepping onto the stage on the lip and it eventually breaking.
joetarin is offline
post #6 of 10 Old 09-02-2013, 09:31 AM
NGiovas's Avatar
Liked: 43
The best solution would have been to cut the lip as part of the plywood.  That way there is no risk of it breaking off.  I don't know if it is too late to recut those pieces (probably worth the time and cost).
For Green Glue, contact Ted or John at the Soundproofing Company.
NGiovas is offline
post #7 of 10 Old 09-02-2013, 09:47 AM - Thread Starter
joetarin's Avatar
The second layer will have the lip as part of the cut. I just didn't put a lip on the first layer. It looks like my local Menards hardware store sells GG.
joetarin is offline
post #8 of 10 Old 09-02-2013, 09:56 AM
NGiovas's Avatar
Liked: 43
How thick is the second layer?  A 1 1/2" layer shouldn't break off if it is 3/4" thick.
Make sure you buy the "noise proofing compound", not the sealant.
NGiovas is offline
post #9 of 10 Old 09-02-2013, 10:25 AM
Liked: 2743
recommended coverage is two tubes per full 4x8 sheet.
post #10 of 10 Old 09-02-2013, 11:52 AM - Thread Starter
joetarin's Avatar
Base layer is 7/16. Top layer with lip will be 3/4". I should have used 3/4 for both but ill save that for the "what would I do differently thread" :-\.
joetarin is offline
