Theater Flooring Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 09-04-2013, 08:55 PM - Thread Starter
mijotter's Avatar
Liked: 59
Thinking about using this as flooring in my dedicated theatre room. Will it be too reflective?
http://www.homedepot.com/p/G-Floor-8-ft-x-22-ft-Coin-Commercial-Grade-Midnight-Black-Cover-and-Protector-Garage-Flooring-GF75CN822MB/203450731#specifications
If so is there a carpet or carpet like flooring that has a similar coin pattern? Themeing out my room.
mijotter is offline
post #2 of 14 Old 09-05-2013, 05:02 PM - Thread Starter
mijotter's Avatar
Liked: 59
Anyone?
mijotter is offline
post #3 of 14 Old 09-06-2013, 05:48 AM
Quoted: 3267 Post(s)
Liked: 2751
Had that crap in an office lobby once. Some interior designers bright idea. That looks good for a garage other than the fact it shows dirt really well. I wouldn't put it in a theater, too reflective. And I'm not big into mopping floors.
post #4 of 14 Old 09-06-2013, 05:26 PM - Thread Starter
mijotter's Avatar
Liked: 59
That's what I was worried about was the reflective nature of the material. Is there a carpet or another style of flooring that has a similar pattern in it then?
mijotter is offline
post #5 of 14 Old 09-06-2013, 08:32 PM
Liked: 2751
So this guy walks into his neighborhood carpet store and asks do you have any carpets with a coin pattern?
post #6 of 14 Old 09-06-2013, 08:45 PM
Liked: 2751
post #7 of 14 Old 09-07-2013, 12:31 AM - Thread Starter
mijotter's Avatar
Liked: 59
Lol big I don't know how you find all this stuff. I searched and searched but nothing. I do like that pattern. Are there any other brands?
mijotter is offline
post #8 of 14 Old 09-07-2013, 06:08 AM
Liked: 2751
I did Google IMAGE search for circle pattern carpet, then once I had a picture of something promising I followed it back to the web site.
post #9 of 14 Old 09-18-2013, 01:26 PM - Thread Starter
mijotter's Avatar
Liked: 59
Could something like this work?
http://www.homedepot.com/p/ROPPE-ROPPE-Black4-ft-x-4-in-x-080-in-Vinyl-Laminate-Wall-Base-16-pc-carton-H140LA5P100/100581171#.Ujn7oRCHua8
Looking for something that is rounded like that but it's all I could find at Home Depot. I want to give the room a "rounded" feel to it instead of sharp corners.
mijotter is offline
post #10 of 14 Old 09-20-2013, 06:25 PM - Thread Starter
mijotter's Avatar
Liked: 59
Anyone?
Also, do you line up the front of the threshold with the front of the door?
mijotter is offline
post #11 of 14 Old 09-21-2013, 09:47 PM - Thread Starter
mijotter's Avatar
Liked: 59
Bump
mijotter is offline
post #12 of 14 Old 09-22-2013, 06:06 AM
Liked: 2751
define front ? Inside/Outside Swing side or Push side.
If you are planning an automatic door bottom you need to plan for it to land on the flat portion of the threshold so in that case it needs to protrude out on the push side of the door. (side with the door stops)
Assuming your door opens into the theater this means that the threshold is not protruding into the theater.
post #13 of 14 Old 09-22-2013, 07:27 PM - Thread Starter
mijotter's Avatar
Liked: 59
Thanks a bunch again. Was just wondering for the riser built right on the concrete, should I use PT wood?
mijotter is offline
post #14 of 14 Old 09-23-2013, 05:17 AM
Liked: 2751
I put down a layer of Roofing felt then use regular wood.
mijotter likes this.
