Rocco's Theater Room Construction - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 24Likes
Old 05-07-2014, 03:39 PM - Thread Starter
roccoleach's Avatar
Quoted: 109 Post(s)
Liked: 52
roccoleach is offline
Old 05-07-2014, 03:46 PM
ambesolman's Avatar
Quoted: 1076 Post(s)
Liked: 897
Sorry you're having a rough go of it😉
ambesolman is offline
Old 05-09-2014, 08:12 AM
kmhvball's Avatar
Quoted: 496 Post(s)
Liked: 275
Originally Posted by roccoleach View Post
Yeah my contractors needed me to explain it to them about 5 times. I was there the whole day making sure it was done right, caulking the seams with soundproof caulk. I did every seam on the first layer, and just the corner seams on the second.
I was under the impression you didn't need to do the first layer really (other than corner's) and could just do all seams & corners on the second layer?
kmhvball is offline
Old 05-09-2014, 11:43 AM - Thread Starter
roccoleach's Avatar
Quoted: 109 Post(s)
Liked: 52
Well, i had enough caulk in my order from ted to handle doing it that way and still had 1/2 a tube left at the end. maybe because the 12ft sheets left less seams.
Old 05-09-2014, 12:00 PM
kmhvball's Avatar
Quoted: 496 Post(s)
Liked: 275
Did you order a case of 12?
I haven't tried to figure out how many linear feat I'll need, so, debating the order quantity.
kmhvball is offline
Old 05-09-2014, 12:25 PM - Thread Starter
roccoleach's Avatar
Quoted: 109 Post(s)
Liked: 52
Less then that. But they're the larger tubes. I couldn't recommend ted more, everything he recommended was helpful, prices were the best, and he got all the quantities right
Old 05-14-2014, 11:05 AM - Thread Starter
roccoleach's Avatar
Quoted: 109 Post(s)
Liked: 52
Just an image how I decided to work with my cloth. Used a pool skimmer rod made this little rig to hold it up
And this is my simple method for cutting. Run the scissors along a wire that I twisted around a few screws. Gets me straight and efficient enough to work with panels, as the edges don't much matter
Old 05-22-2014, 07:55 PM
quamosa's Avatar
Quoted: 99 Post(s)
Liked: 72
Nice work on the panels, I'll be making about 22 of those things.
My First Build Ever in progress
quamosa is offline
Old 05-25-2014, 02:14 PM - Thread Starter
roccoleach's Avatar
Quoted: 109 Post(s)
Liked: 52
I really like this fabric I'm working with as it's very forgiving and stretchy. A few times I thought I would have ripped it also and it doesn't even show a mark. It's the acousticmac dmd stuff
Old 05-25-2014, 03:25 PM
kmhvball's Avatar
Quoted: 496 Post(s)
Liked: 275
Did You Get All Black? I Have A Bunch Of Their Samples...
kmhvball is offline
Old 05-27-2014, 09:59 AM - Thread Starter
roccoleach's Avatar
Quoted: 109 Post(s)
Liked: 52
Old 05-27-2014, 01:22 PM
kmhvball's Avatar
Quoted: 496 Post(s)
Liked: 275
Originally Posted by ambesolman View Post
Don't know why you're not getting more traffic in here either because it's a great build so far.
What Size Are Your Panels, 2x4? DoeS This Leave Much Fabric Left Over?
Was looking at you panel frames. Are they 1x3" with 1x2" around that? Just wondering how/why you built them that way. They do look sturdier than my 1x3" frame. What are they made of?
kmhvball is offline
Old 05-27-2014, 03:34 PM - Thread Starter
roccoleach's Avatar
Quoted: 109 Post(s)
Liked: 52
They are 1x3 and 1x2. Weight 10 lbs." with fiberglass installed. Glued and nailed with 18awg 2" on the corners, and 23awg 1" and glue piece to piece. The overlapped corners not only give it a better look, but also provide extra strength in the corners where it's needed
Old 05-28-2014, 05:50 AM
kmhvball's Avatar
Quoted: 496 Post(s)
Liked: 275
I am not sure I fully understand... I thought the 1"x3" & 1"x2" are the two layers of materials used to make the frames.   My question is what are the lengths of your frame sizes, are your frames 2 feet wide x 4 feet long, or are they 1 foot x 3 foot and 1 foot x 2 foot?
kmhvball is offline
Old 05-28-2014, 06:22 AM - Thread Starter
roccoleach's Avatar
Quoted: 109 Post(s)
Liked: 52
Old 07-13-2014, 12:34 PM - Thread Starter
roccoleach's Avatar
Quoted: 109 Post(s)
Liked: 52
Been a really busy summer but I'm starting to wrap the soffit
Old 07-22-2014, 09:54 PM - Thread Starter
roccoleach's Avatar
Quoted: 109 Post(s)
Liked: 52
Ceiling almost done just needs putty and paint. stapled up the fabric at the seams, coordinated seams of cloth with the wood slats. it got dark really quickly in the room.
Name:	Bass Trap1.jpg
ID:	175754   Click image for larger version
Name:	Bass Trap2.jpg
ID:	175762   Click image for larger version
Name:	Bass Trap3.jpg
ID:	175770   Click image for larger version
texpilot likes this.
Old 07-23-2014, 06:11 AM - Thread Starter
roccoleach's Avatar
Quoted: 109 Post(s)
Liked: 52
Going to finish the ceiling today. Carpet coming in about 2 weeks, then i'll finish the wall panels and build the columns to hide the surround speakers.
ambesolman likes this.
Old 07-26-2014, 11:49 AM - Thread Starter
roccoleach's Avatar
Quoted: 109 Post(s)
Liked: 52
So with just the ceiling/soffit bass traps it makes an incredible difference that I can hear just playing my g-boom boom box it sounds amazing can't wait to have the rest of the treatment up with some real speakers!
Old 07-26-2014, 11:56 AM
ambesolman's Avatar
Liked: 897
Pics!
Sent using Tapatalk since the mobile version is still 👎
Old 07-26-2014, 12:07 PM - Thread Starter
roccoleach's Avatar
Quoted: 109 Post(s)
Liked: 52
Pics are up there. No difference just filling holes from the nails sanding and painting while I listen to music and it sounds very tight and clear. Carpet goes down in like 2 weeks and then I finish trimming out the wall to wall sound paneling
Old 07-26-2014, 12:13 PM
ambesolman's Avatar
Liked: 897
That shiny stuff wouldn't reflect sound?
Old 07-26-2014, 12:20 PM - Thread Starter
roccoleach's Avatar
Quoted: 109 Post(s)
Liked: 52
It's 705FRK. This gives the insulation more effective low end absorption. With help of my brother in law and a mirror, we did peel off the backing from the first reflection points as heard from the main 3. On the sides and wall to ceiling will be unfaced 703 for all the low end absorption I might need, along with the ability to change to frk/remove alltogether if the room is audibly too "dead" after everything is installed. I have 4 mondotraps, 4 2x4 minitraps, and 4 2x2 minitraps for the wall/wall and tri corners, which all also are reflective to higher frequencies.
Old 07-26-2014, 02:01 PM
ambesolman's Avatar
Liked: 897
Nice! You shod be well covered. What % of the room would you say is treated?
Old 07-26-2014, 02:34 PM - Thread Starter
roccoleach's Avatar
Quoted: 109 Post(s)
Liked: 52
90% of ceiling (mostly frk) 95% of walls (mostly 703 unfaced) all corners have realtraps in them
Old 08-02-2014, 08:52 PM - Thread Starter
roccoleach's Avatar
Quoted: 109 Post(s)
Liked: 52
Can anyone Refer me to a place to buy the Panamorph UH480 mounting plate? I will be forever grateful!
Old 08-03-2014, 11:49 AM
LeBon's Avatar
Quoted: 184 Post(s)
Liked: 86
Have you checked with AV Science?
LeBon is offline
Old 08-04-2014, 05:00 PM - Thread Starter
roccoleach's Avatar
Quoted: 109 Post(s)
Liked: 52
I can find the lense when I search but not the mount
Old 08-05-2014, 04:52 PM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
Can you take more pictures of your ceiling? Some from a distance. I love the way it looks and that was one of the ways I wanted to do my ceiling. I can't make up my mind on what I want to do exactly.
Great job!
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
Old 08-05-2014, 05:37 PM - Thread Starter
roccoleach's Avatar
Quoted: 109 Post(s)
Liked: 52
Hey. I framed it out with plywood and 2x4 run top and bottom for support. All around with plywood. Then after I stuffed it with fiberglass and 705 frk, I wrapped it in cloth, and took the 1x2 longways, and trimmed the edge with 1x6 boards to hide the edges. Pre painted boards, Filled the nail holes, and painted it again. Between the lighting and the all black room it's hard to get a good picture, but I'll try
