Basement Layout - Looking for suggestions on Dedicated HT - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-14-2013, 08:37 AM - Thread Starter
Media Room = HT
I have attached a simple layout. I am debiting where to put the screen. Suggestions are welcome... Thx
Manny E.
Basement Simple layout 14SEPT13.jpg 207k .jpg file
Name:	Basement Simple layout 14SEPT13.jpg
jme3192 is offline
post #2 of 5 Old 09-14-2013, 09:10 AM
cdika17's Avatar
Take rack niche out of back corner, put it elsewhere, don't frame in the corners, leave room square and fill corners with bass traps(ie OC703). Only use 1 door, 32", install it closer to screen in that gap.
What are your soundproofing plans and treatment plans?
Room is not deep enough for a AT screen
Lots of research and asking questions and you should be alright.
Id propose something like this.
Get sketchup and play around with layouts.
If you want pro help, check out this: http://www.avsforum.com/t/1400898/pro-theatre-layout-service/0_100
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
post #3 of 5 Old 09-14-2013, 11:02 AM - Thread Starter
It is a load wall done by builder. In addition all framing is already done. I need to work with it as it is... frown.gif
jme3192 is offline
post #4 of 5 Old 09-14-2013, 11:45 AM
sdurani's Avatar
Quoted: 4973 Post(s)
Liked: 3436
Noticed you had the screen on the north wall, which is where I'd put it as well (only wall that allows for symmetrical speaker placement).
jme3192 likes this.
Sanjay
sdurani is offline
post #5 of 5 Old 09-14-2013, 05:16 PM - Thread Starter
Thank for the note.
I have the electrician coming in about in a week. Still think lighting positions and power outlets in the ceiling and the AV closet (southeast).
jme3192 is offline
