Soundproof bumpers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-20-2013, 11:31 AM - Thread Starter
Metallus2000's Avatar
Liked: 30
Can't remember the name of them, but about to install the roxul sound proof insulation, followed by the bumpers you screw the sheet rock into. If anyone knows of install guide an place I can get these, I would appreciate it!
Ken
Metallus2000 is offline
post #2 of 3 Old 09-20-2013, 02:55 PM
Quoted: 3908 Post(s)
Liked: 3338
soundproofingcompany.com sells a variety of the reslient clips that hold the 25ga 7/8 inch furring channel that you buy locally.
post #3 of 3 Old 09-20-2013, 03:37 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 968
Ken
ACS Acoustics in Eugene, Oregon sells product similar to what you are describing..........................but from recollection, the bumper is used between layers of sheet rock and is used instead of GG. The bumpers are also used on studs to sheet rock.
doublewing11 is offline
