"The Best Of The Demo Discs Demo Disc" BD9/DVD-DL - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 13Likes
post #91 of 245 Old 10-12-2013, 10:26 AM - Thread Starter
LastButNotLeast's Avatar
Quoted: 1793 Post(s)
Liked: 1404
Now there's a match made in heaven: ScubaSteve and superleo. Go for it, guys!
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
post #92 of 245 Old 10-12-2013, 01:18 PM
superleo's Avatar
Quoted: 83 Post(s)
Liked: 312
Originally Posted by scubasteve2365 View Post
Originally Posted by LastButNotLeast View Post
I'm pretty sure you'd get enough input that you don't need to have one of your own. wink.gif
Of course, you wouldn't be able to enjoy it much after you produced it. biggrin.gif
Couldn't even test it.
There is a free 3D player that you/we could use for testing, it uses side by side 3D; active 3D grasses are still needed you want to actually see (pun intended) the results. BTW, don't know if you are aware that TmuxeR has been developed to support 3D, which would make things easier. Can download the latest TmuxeR version at doom9.
RPCRT-TV Overscan Reduction
Reference Blu-Ray Demo Disc
superleo is offline
post #93 of 245 Old 10-13-2013, 07:50 PM
nlpearman's Avatar
Quoted: 31 Post(s)
Liked: 27
Now that was really interesting. Thank you. That's what I love about this place: people are always trying/needing to do something someone else would never have considered. Here's what I've found.
First, I would suggest MakeMKV. It's much faster, though you need to process one file at a time (ie, load the index file so it knows what's on the disc, then select one title at a time). The other caveat is that you need to select (if you want it) the high def audio:
Rename the resulting file (since the next one will default to the same name), and just work down the list. A couple don't work (00007 and 00013), for which you'll need to use handbrake. Again, you need to select the high def audio output:
For the video, you'll need to experiment depending on your output device. For me, the default of 20 was horrible; 18 was okay, 15 was great but probably overkill. There are other threads and arguments on that topic. Pick your poison.
I'm not set up for it, but I couldn't get iTunes to read the mkv files, so you might want to check that before you go through the rest of the trouble.
And, by all means, let us know!
Michael
I'm trying to handbrake this for my Apple TV2 and I think I'm missing some steps here. Does MakeMKV turn the clips into one file that HB can handle? How exactly do I handle clips 00007 and 00013 that don't work?
Thanks in advance.
Upgraditis Anonymous
nlpearman is offline
post #94 of 245 Old 10-13-2013, 08:02 PM - Thread Starter
Liked: 1404
Just put each file individually into handbrake.
The other poster wanted mkv files specifically. You can get AppleTV files from the m2ts files directly.
post #95 of 245 Old 10-13-2013, 08:11 PM
nlpearman's Avatar
Quoted: 31 Post(s)
Liked: 27
Oh ok - so there's no way to get this as one file with different chapters for each clip for my Apple TV?
post #96 of 245 Old 10-13-2013, 09:28 PM
PCMusicGuy's Avatar
Downloading now. I'll seed for a little while too.
PCMusicGuy is offline
post #97 of 245 Old 10-16-2013, 08:40 AM
DGF
DGF's Avatar
Liked: 39
Downloaded (and seeded) over the weekend - followed SherazNJ's simple instructions to create the files/folders on a USB memory stick - stuck the stick in my PS3, fired everything up and it worked perfectly first time! A huge thanks to all involved in putting this together! I've dinked around with ways to show off my HT over a period of several years, but I can now leave the tiny USB stick permanently in one of the 4 PS3 USB slots and have instant access to the great content. I love it!
Thanks again for all of your efforts - it's what makes AVS such a great place!
DGF is offline
post #98 of 245 Old 10-16-2013, 08:59 AM
deids's Avatar
Yes. People here are really awesome! Thanks AVS.
deids is offline
post #99 of 245 Old 10-16-2013, 10:11 AM - Thread Starter
Liked: 1404
:D
Our pleasure.
post #100 of 245 Old 10-16-2013, 10:31 AM
DGF
DGF's Avatar
Liked: 39
It just dawned on me that having the content loaded on to a USB memory stick would make a great present for some of my more HT-oriented friends.
DGF is offline
post #101 of 245 Old 10-16-2013, 01:48 PM
ed3120's Avatar
Quoted: 22 Post(s)
I burned this disc using ImageBurn as a UDF 2.5 disc, but I'm having a lot of problems playing this on my PS3. Most of the videos start, but then the sound goes silent in the middle of some of them. Has anyone else had this problem?
ed3120 is offline
post #102 of 245 Old 10-16-2013, 02:22 PM
deids's Avatar
I have a similar problem when I run the downloaded content from my laptop.
But I am assuming that when i burn this onto the DVD, it might work fine.
deids is offline
post #103 of 245 Old 10-16-2013, 03:09 PM - Thread Starter
Liked: 1404
See any of the eight million references to MultiAVCHD.
http://multiavchd.deanbg.com/
post #104 of 245 Old 10-18-2013, 06:25 AM
SherazNJ's Avatar
Quoted: 1210 Post(s)
Liked: 144
I had similar issues. I then used USB and it worked fine. Here are the steps I defined in the post. Try doing same with dvd and see if it works ( I haven't though) but it definitely works with USB.
http://www.avsforum.com/t/1491761/the-best-of-the-demo-discs-demo-disc-bd9-dvd-dl/60#post_23828295
SherazNJ is offline
post #105 of 245 Old 10-20-2013, 05:24 PM
DAlba's Avatar
Quoted: 33 Post(s)
Originally Posted by caper_1 View Post
Are you certain of that? I have been using AVCHD on external USB HDD for years and have never heard of this shortcut. That doesn't mean it doesn't exist though! I added the BD50s (Reference Disc 1 & 2) to multiAVCHD and "re-authored" and it worked perfectly that way for both. MultiAVCHD threw an error when I tried to make a AVCHD compatible project for the "Best of" when I tried to add the files/folder.
Sorry for double post, but I am unable to edit the previous post and append this information to it.
I am having the same problem. I converted about 5 other demo disks with MultiAVCHD to play on my Oppo through network hard drive and it worked flawlessly but the Best Of disk gives me an error in MultiAVCHD.
DAlba is offline
post #106 of 245 Old 10-20-2013, 05:35 PM - Thread Starter
Liked: 1404
Perhaps the error message here or on the MultiAVCHD support page might mean something to someone.
post #107 of 245 Old 10-20-2013, 09:24 PM
DAlba's Avatar
Quoted: 33 Post(s)
I have attached some pictures of what happens. When I select to import all the file it wants to create ends up being over 60GB.
DAlba is offline
post #108 of 245 Old 10-25-2013, 06:23 AM - Thread Starter
Liked: 1404
I'm surprised (and sorry) no one's jumped in. I don't use multiAVCHD, but my understanding is that that is a bug, not an error. Ignore it, make sure you've selected PS3 format, and let it run.
And keep us posted.
Michael
post #109 of 245 Old 10-25-2013, 06:34 AM
buzzard767's Avatar
Quoted: 1660 Post(s)
Liked: 2438
Same here. Something is set up wrong in multiAVCHD but I have yet to figure it out.
Buzz
THX Certified Level II Video Calibrator
buzzard767 is offline
post #110 of 245 Old 10-25-2013, 07:05 AM - Thread Starter
Liked: 1404
post #111 of 245 Old 10-25-2013, 07:29 AM
superleo's Avatar
Quoted: 83 Post(s)
Liked: 312
I'm just checking back and saw the questions about MultiAVCHD.
In order to reauthor the disc so it will play from a thumb-drive / external drive for the PS3 you drag/drop the entire BDMV folder into MultiAVCHD. Then it will let you know you reauthoring a dicc, just say Ok. Let it process the files, when its done processing chose the "Sony PS3" button. I believe the calculated space to be process is an incorrect number, you should need, if anything, just a little more space than the size of the disc being processed.
After it finishes processing the files the new reauthor disc is under the MultiAVCHD folder. It created a new folder BDRA. You copy this folder to the external drive. Once copied renamed the BDRA to AVCHD.
superleo is offline
post #112 of 245 Old 10-25-2013, 07:42 AM
buzzard767's Avatar
Liked: 2438
I selected AVSHD instead of PS3. The program chugs along for an hour or more and then crashes.
Buzz
post #113 of 245 Old 10-28-2013, 12:11 PM
bdixon1's Avatar
I burned from the file provided, i did not convert to AVSHD.
It skips in my Samsung BD P1600 to the point its not watchable. Is it time for me to buy a new blu ray player or is something else wrong?
bdixon1 is offline
post #114 of 245 Old 10-28-2013, 12:59 PM - Thread Starter
Liked: 1404
According to this list, it should play:
post #1
post #115 of 245 Old 10-28-2013, 01:25 PM
bdixon1's Avatar
I did NOT convert it using AVSHD
bdixon1 is offline
post #116 of 245 Old 11-07-2013, 05:37 PM
Anks329's Avatar
Originally Posted by SherazNJ View Post
I tested AVCHDMe and was successfully able to play thru USB. Steps are very simple
1 - Create a folder named AVCHD.
2 - Copy BDMV and Certificate folder into AVCHD
3 - Run AVCHD.
4 - Click on Browse button and select BDMV button.
5 - AVCHDMe will show 3 points and they all should have correct mark. If any of them has a cross mark then its not in right format. Click on Fix it button and it will fix it.
6 - Copy AVCHD folder to USB.
Enjoy the movie.
Now one thing I wand to do is to have multiple movies on usb. My usb is 35 GB and I want to copy more. Does anyone know if I can copy multiple movies on USB?
th.
I'm assuming the USB needs to be FAT formatted and not NTFS.
Anks329 is offline
post #117 of 245 Old 11-07-2013, 07:39 PM
SherazNJ's Avatar
Liked: 144
That's correct
SherazNJ is offline
post #118 of 245 Old 11-27-2013, 12:54 PM - Thread Starter
Liked: 1404
I just need to seed to one more person and I've crossed 100GB.
:D
Thank you, everyone, for your interest.
Michael
post #119 of 245 Old 11-27-2013, 01:01 PM
superleo's Avatar
Quoted: 83 Post(s)
Liked: 312
superleo is offline
post #120 of 245 Old 11-27-2013, 01:11 PM - Thread Starter
Liked: 1404
Couldn't have done it without you, Leo.
