"The Best Of The Demo Discs Demo Disc" BD9/DVD-DL - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 13Likes
post #181 of 245 Old 09-17-2014, 11:36 AM
buzzard767's Avatar
Quoted: 1655 Post(s)
Liked: 2436
The Super 8 clip is my goto surround sound theater demo. People love it.
superleo likes this.
Buzz
THX Certified Level II Video Calibrator
buzzard767 is offline
post #182 of 245 Old 09-17-2014, 12:43 PM - Thread Starter
LastButNotLeast's Avatar
Quoted: 1773 Post(s)
Liked: 1392
My favorite of the favorites is Finding Nemo. Great surround, great bass, great animation. "Mine!"
That said, I recently had someone over to buy a subwoofer. I played Dolby Spheres, and his wife literally turned around in her seat.
Priceless!
Michael
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
post #183 of 245 Old 09-17-2014, 01:33 PM
Daffietje's Avatar
Quoted: 54 Post(s)
Originally Posted by superleo View Post
The difference in volume might be that the Super 8 clip audio is DOLBY TruHD while the other ones are DTS-HD. Most Receivers have a way to adjust for this through their setup menu.
There was no adjustment or anything else done to the audio or video on these clips. They are the exact copy from the original, other than cut as clips for size.
Nah, not to do with Dolby True HD cause there are other clips on the disc also in Dolby True-HD.
I think it is because that Super 8 clip is so heavy on all the channels (also the surrounds!) that it comes of louder as the other clips.
@LastButNotLeast : I changed the volume of the sub from -9 to -5.5 dB. That sounds better to me.
I also have to mention that the clips on this demo disc have more heavy bass (for example : War of the worlds, Flight of the Phoenix, DTS Demo) when compared to the "Reference 2 Bass". Note that the only clip I did not play so far on Ref. 2 Bass is the "Pulse" clip My subwoofer is only a week old, I want to give it some time to settle
I also had some choppy play when playing this demo disc and the Ref. 2 Bass demo disc. Never happened to me on my Oppo-103. Strange thing.
Panasonic TX-P50GT60 / Marantz SR5004 / 4 x KEF HTS 3001 SE (front + rear) + HTC 3001 SE (centre) + REL T-9 sub / Oppo BDP-103EU (MultiRegion+MultiZone)
Daffietje is offline
post #184 of 245 Old 09-18-2014, 08:27 PM - Thread Starter
Liked: 1392
Keep in mind that "lots" of bass isn't the same as "deep" bass.
If your system isn't calibrated, your sub probably has a peak around 40Hz, which gives most people the "wow" factor. If your system is calibrated to flat, the sound is very different.
I used to get "big" sound on the Jericho track with the music when the rocket launchers were turning. Impressive, but not "right." EQ'd, the music is even across the spectrum, and the big "boom" is saved for the landing of the rocket, as you would expect.
See some of the illustrations here:
The New Master List of BASS in Movies with Frequency Charts
I keep bringing this up, but I think it's important, re: Pulse:
The "thump, thump, thump" is cool, but if you can't hear her heavy breathing, feet dragging on the floor, and the rustle of paper as she turns the corner, your bass is drowning out the more important effects of the scene. And of anything else you may listen to. Which is why measurement and EQ are so important.
Choppy play is usually a mismatch between player and brand of disc. I use an HTPC, so I'm afraid I can't offer any specific advice. You may want to look on a thread dedicated to your player; I'm sure people there would have recommendations.
Enjoy!
Michael
Daffietje likes this.
post #185 of 245 Old 09-20-2014, 03:17 AM
Daffietje's Avatar
Quoted: 54 Post(s)
Enjoy!
Michael
Yesterday I could not resist to check the Pulse scene out
Seems my recent increase of +3dB was a little to much. Hear breathing and rustle of paper was still audible, but a couple of her footsteps (specially in the beginning when she opens the door) were not audible. So I changed the increase to +1,5 dB which sounded better. It is now at -7,5 dB instead of -6 dB.
Or is it wrong to take this scene as a reference to check the volume?
Thanks for the advice.
post #186 of 245 Old 09-20-2014, 01:07 PM - Thread Starter
Liked: 1392
Sort of.
There is no real "reference" (okay, technically, besides THX, et al), though, by making that change, you have probably improved your over-all listening experience, which is all that matters. If you have a way to EQ, a boost at 20Hz (or 15, or 10 ) would restore the "pulsing" without stepping on (pun intended) the higher frequencies, but you're heading in the right direction with what you have done.
Which is why I love that scene, just for reasons different from almost everyone else.
Michael
post #187 of 245 Old 09-20-2014, 02:26 PM
Daffietje's Avatar
Quoted: 54 Post(s)
No idea if I can EQ.... I guess not with my current setup (see sig) ?
I know the options in my AVR pretty well, I have not seen much about EQ.
If someone can tell otherwise I am happy to hear it
post #188 of 245 Old 09-20-2014, 02:43 PM - Thread Starter
Liked: 1392
It looks like you have Audyssey MultEQ, which is nice, but doesn't do subs.
See page 28 of your manual:
http://us.marantz.com/us/Products/Pa...oductId=SR5004
You would need (and might be interested in getting, if you want to start a whole new hobby ) this to EQ:
http://www.musicgoroundtroy.com/p/22...inger-dsp1124p
available used periodically (no longer manufactured, but perfect for this use) or something similar,
and learn to use REW:
Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs
Or you might just want to enjoy what you have for now.
Michael
post #189 of 245 Old 09-21-2014, 03:19 AM
Daffietje's Avatar
Quoted: 54 Post(s)
Thanks for the suggestion Michael!
My T-9 sub only goes 28 Hz @ -6 dB, so I doubt it would be useful to give a boost at 20 Hz or lower
Good advice though, but I think I will enjoy what I have now (for now )
post #190 of 245 Old 11-26-2014, 07:32 PM
kikkoman's Avatar
Quoted: 70 Post(s)
Is there another working torrent file? I tried downloading the one on the first page but when it tries to open in uTorrent an error occurs. I already have the Reference files and just downloaded the Reference 2 files, so need to watch those soon. Then I saw this thread so I definitely want to get my hands on these files as well.
Thanks in advance!
kikkoman is offline
post #191 of 245 Old 11-26-2014, 09:21 PM - Thread Starter
Liked: 1392
You did unzip the file first, right?
I just tried it and found, much to my very pleasant surprise, eight seeders at the moment.
Thanks, everyone!
Try again, and let us know if you still have a problem. If you do, let us know what you're using.
Michael
post #192 of 245 Old 11-27-2014, 07:55 AM
kikkoman's Avatar
Quoted: 70 Post(s)
Thanks, everyone!
Michael
Thanks LastButNotLeast! I was too quick and didn't read the instructions. I assumed it followed similar steps as the other reference demo files, which were to download the file, remove the .zip extension from the file name and then to open in uTorrent.
DOH!
It works now. Many thanks on Thanksgiving!
kikkoman is offline
post #193 of 245 Old 11-27-2014, 08:00 AM - Thread Starter
Liked: 1392
post #194 of 245 Old 12-06-2014, 07:52 AM
martinq's Avatar
Quoted: 25 Post(s)
Burned this disc & tested in the Oppo 103d and it works great. Thanks!
Not so good for the other discs (Reference 1 & 2). Just tried burning Bass and Vision from the Reference 2 set and they show as data-discs instead of video. Same behaviour in the PS3.
Used the same DVD-DL disc for both and the same ImgBurn settings. Discs verify OK and did a re-check on the torrent files to verify they were OK too.
martinq is offline
post #195 of 245 Old 12-06-2014, 08:20 AM - Thread Starter
Liked: 1392
What do the files on those other discs look like?
They should have the same folders and layout of this disc (and any other BD, for that matter).
I tried to keep mine simple for exactly that reason. The other discs need to be uncompressed to create the BDMV folder.
Michael
post #196 of 245 Old 12-06-2014, 10:17 AM
martinq's Avatar
Quoted: 25 Post(s)
Yes, exactly. The disc shows as a data disc with two folders (BDMV and CERTIFICATE) just like the Best Of disc.
I think the Reference 1 Bass disc was missing the CERT folder. I've burned four discs so far that don't work. The only success is the Best Of disc.
martinq is offline
post #197 of 245 Old 12-06-2014, 10:26 AM
thebland's Avatar
Quoted: 1594 Post(s)
Liked: 926
Can you burn this to a DVD?
Goodbye to a great audio and video genius and writer... JOHN GANNON. I enjoyed your friendship, wit and a nice long run we took around Indianapolis at CEDIA years back... and for buying my Runco 980 Ultra years back... you saved my ass! Rest in peace.
thebland is online now
post #198 of 245 Old 12-06-2014, 12:08 PM
martinq's Avatar
Quoted: 25 Post(s)
Yes, just like the title says. DVD-DL
martinq is offline
post #199 of 245 Old 12-06-2014, 07:45 PM - Thread Starter
Liked: 1392
That sucks.
Though I'm happy you had success with mine , it would be nice to figure out what's wrong with the others.
All burned as UDF 2.5, I presume. No other folders or data on the disc? BDMV in the root directory, not in a folder? Many players don't care about a missing CERT folder (it's empty, anyway), but having one is a good idea - ImgBurn should ask you if you want to create one if you just drag a BDMV folder onto it, which is a good way to make sure it knows you're making a BD file structure disc.
I hate to see you make any more coasters, but I can't think of why you're still seeing them as data discs.
post #200 of 245 Old 12-07-2014, 06:51 AM
martinq's Avatar
Quoted: 25 Post(s)
Yes.
No.
Yes.
I've never tried that but it might be worth a go. I also have a different type of DL disc to try but I doubt that'll help. Still worth a try I think.
Thanks for the feedback and suggestions!
martinq is offline
post #201 of 245 Old 12-07-2014, 07:50 AM - Thread Starter
Liked: 1392
Unfortunately, these discs aren't available as rewritables, which is what I regularly recommend for people burning BDs.
Since the discs are burning, and readable, I don't think a different brand will help.
I'm stumped.
post #202 of 245 Old 12-22-2014, 05:18 PM
highlife's Avatar
Hello, downloading this disc now. Is 11 hours ETA sound right? If I download to my iMac, is it easy enough to burn to a DVD using the iMac super DVD drive?
2 wrongs don't make a right, but 3 lefts do...
highlife is offline
post #203 of 245 Old 12-22-2014, 07:30 PM
AeR0's Avatar
bit confused here.... is this meant to demo PQ and audio ?
or just PQ?
AeR0 is offline
post #204 of 245 Old 12-22-2014, 08:34 PM - Thread Starter
Liked: 1392
It will download faster with more seeds. I just added mine, which should help.
The first 40+ GB demo disc I downloaded (ScubaSteve's) took over 5 days! That's why we wanted to do this smaller one. It should finish for you by early morning.
As long as you can burn a DL disc, you should be fine. You will, of course, need a blu-ray player to play it back (though you will be able to play the individual m2ts files on the mac with VLC).
You're welcome. Enjoy.
Michael
post #205 of 245 Old 12-22-2014, 08:37 PM - Thread Starter
Liked: 1392
or just PQ?
Both. Just look at the table of contents.
Of course, some emphasize one more than the other, but (in my humble opinion ), they're all demo-worthy.
Let us know what you think.
Michael
post #206 of 245 Old 12-23-2014, 05:44 AM
highlife's Avatar
Should I use a +DL or -DL disc, or doesn't it matter? My brand new Apple superdrive says it will burn both.
highlife is offline
post #207 of 245 Old 12-23-2014, 05:51 AM - Thread Starter
Liked: 1392
Your playback device will determine that.
That said, it probably doesn't matter.
Did we cut it down from 11 hours?
post #208 of 245 Old 12-23-2014, 06:25 AM
highlife's Avatar
It ran overnight, was down to 5, showing 14 now : (
I have an Oppo Blu Ray player, about 5 years old, I will check to see which disc it prefers
highlife is offline
post #209 of 245 Old 12-23-2014, 06:26 AM
highlife's Avatar
Now its 4 hours, differing speeds I guess. 4 seeds showing
highlife is offline
post #210 of 245 Old 12-23-2014, 08:00 AM - Thread Starter
Liked: 1392
Make sure your download speed is set to "unlimited."
At least you won't have to wrap it.
