6lb on shelf on plasterboard wall - where to start? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-30-2013, 10:29 AM - Thread Starter
Leo_AV's Avatar
Hey folks!
I've done a bunch of drilling and projector installation a few years back but have forgotten basically everything (ha). I live in an apartment in NYC and probably have plasterboard walls, not even sure.
I'm getting a BenQ 1070 which weighs about 6lb and am intending to put on a shelf that my SO just bought. 6lbs isn't a ton of weight, do you think I'd be good with regular screws or should I get some of those self-drilling chunky rawl plugs or something from Amazon?
Thanks all!
--Leo
Leo_AV is offline
post #2 of 7 Old 09-30-2013, 11:19 AM
Quoted: 3257 Post(s)
Liked: 2743
Drywall anchors for sure unless you are positive you hit a stud which will probably be metal. Keep in mind that a 6 lb load on a shelf gets multiplied by the fulcrum effect depending on your shelf design and brackets.
post #3 of 7 Old 09-30-2013, 12:27 PM - Thread Starter
Leo_AV's Avatar
Ok, cool, thanks for the response! I'll get anchors to play it safe.
FYI, this is the shelf.
What do you advise for cutting a hole in the shelf for cables, would a hole saw/drill bit do it?
Cheers!
--Leo
Leo_AV is offline
post #4 of 7 Old 09-30-2013, 02:41 PM
Liked: 2743
hole saw or a large spade bit. And you don't have to make just one hole.
I REALLY like Bosch Daredevil spade bits. You can get one for this project for $5.
post #5 of 7 Old 09-30-2013, 02:55 PM - Thread Starter
Leo_AV's Avatar
Ah, yes! Spade bits! Had forgotten they even existed. I think I'll opt for that instead of a hole saw. Think I'll get away with a single g-clamp on the side of a table?
Cheers again, excellent advice.
Leo_AV is offline
post #6 of 7 Old 09-30-2013, 03:33 PM
Sands_at_Pier147's Avatar
Clamp a piece of scrap wood to the back of the shelf where you want to drill the hole, to minimize / prevent tearout. When a spade bit blows through the back of the hole, they tend to really make a mess. A backer board will help minimize that.
It appears my hypocrisy knows no bounds.
Brian
The Cinema Rouge Home Theater
Sands_at_Pier147 is offline
post #7 of 7 Old 09-30-2013, 07:25 PM
Liked: 2743
or cut the hole half way from one side then flip and cut the remainder on the other side, that will minimize the tear out. But just a warning, the blade I recommended cuts FAST.
Leo_AV likes this.
