Projector Display & TV Displays - Edge of Image Cropped - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-02-2013, 08:00 AM - Thread Starter
jxpontig's Avatar
We have a PC in our church with an NVIDIA Geoforce GT630 graphics card. We take two signals from it - the main display (HDMI) to the PC monitor in our PA area and a VGA signal which goes to converter and splitter boxes. Converts the signal to S-Video for the main church projector and also sends a signal to two LCD TV screens. The problem I have is that on both the projected screen and the two TV screens I an losing the edges of the any pc image (looks normal on PC monitor), so if we don't leave a border we losee the first letter or so of sentences on the images that the congregation can see. Have played around in NVIDIA Control Center without success.
jxpontig is offline
post #2 of 3 Old 10-02-2013, 10:35 AM
BroncoSport's Avatar
The resolution of a standard (non-HD) television and I would assume your projector if it is fed via S video, is different than the resolution of a PC monitor. On some graphic cards you can independantly change the output resolution to fit the monitors native resolution. I am guessing that is your issue. If that card doesn't allow for resolution changes, I would buy a secondary card for the TVs/projector and run it's settings specifically for those devices.
BroncoSport is offline
post #3 of 3 Old 10-14-2013, 08:42 AM - Thread Starter
jxpontig's Avatar
Thanks for the feedback. We have now managed to solve this - we found an underscan/overscan switch on the signal converter black box, turned it to underscan and it worked!
jxpontig is offline
