Dual side surrounds. - AVS Forum | Home Theater Discussions And Reviews
Old 10-07-2013, 03:55 AM - Thread Starter
MX48's Avatar
Quoted: 69 Post(s)
Liked: 40
I posted this in the audio theory section but there isn't as much traffic over there. Wanted to see if anyone here has any thoughts. I have seen threads on here about this but are usually directed towards theaters having multiple rows of seats.
I am increasing the size of my HT and am wondering about side surrounds.
The room will be 30L x 20W and only 1 seat. It will almost never have more than 1 listener/viewer.
Is there an advantage to 2 sets of side surrounds? They would be run thru a MiniDSP for eq/delay to external amp (of course).
I will be using a Denon 4311 and have heights and wides as well as back.
Can this create a better surround field? Of course rear surrounds are also included.
I will be using a Denon 4311 and have heights and wides as well.
Thanks for any help,
Moto
MX48 is offline
Old 10-07-2013, 04:20 AM
Nightlord's Avatar
Quoted: 711 Post(s)
Liked: 237
It definitely works wonderfully for me. I don't use any electronic delays, just shorter distance to ears from the frontmost pair, they share the same signal. I'm even using three, not two.
Under construction: the Larch theater
Nightlord is offline
Old 10-07-2013, 04:24 AM - Thread Starter
MX48's Avatar
Quoted: 69 Post(s)
Liked: 40
Is this with a single seat or row or multiple?
MX48 is offline
Old 10-07-2013, 04:56 AM
Nightlord's Avatar
Quoted: 711 Post(s)
Liked: 237
In tv-room - single row two seats:
In cinema under construction - two rows, three up front, two back.
Old 10-07-2013, 05:08 AM - Thread Starter
MX48's Avatar
Quoted: 69 Post(s)
Liked: 40
Thanks Man.
I found a lot of good info in another thread by accident that I hadn't seen before.
MX48 is offline
