SC 170 Acoustical Caulk vs Green Glue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-17-2013, 05:38 AM - Thread Starter
Jeff in Canada's Avatar
Quoted: 167 Post(s)
Liked: 61
I think a lot of green glue, but i have a question about SC 170. Can you use it effectively between OSB and Drywall? Will it function similarly to green glue as a damper?
I was going to run both through an electron scanning microscope to see how they compare material wise. I'm going to do the same with putty pads and duct / electrical putty people recommend on here, to see if only the color is different on the putty.
Audio: Denon AVR-4520, Fusion 12 Tempest (LCR), Fusion 8 Alchemy (4xSurrounds+2xWides+2xHeights),4 x 15" Dayton Ultimax
Video: Sony VPL-HW40ES, Darbee Darblet, SMX 2.35:1 Screen
Seating: Fusion Lagoon Chairs
Theater Build
DIY Speaker / Sub Build
Jeff in Canada is offline
post #2 of 3 Old 10-17-2013, 06:08 AM
Quoted: 3255 Post(s)
Liked: 2743
there are published MSDS on line that list the components of each and they aren't even cousins. I've used the OSI product for sealing cracks and it performs about the same as the Green Glue Caulking product not the same as the Dampening product. After curing they have different coefficients of elasticity.
post #3 of 3 Old 10-17-2013, 07:47 AM - Thread Starter
Quoted: 167 Post(s)
Liked: 61
Thanks Jeff.
After it dried a bit, it felt stiffer. I do like it for sealing holes / cracks. It is a bit "tar" like though.
Thanks again for the info.
Theater Build
