Not sure what to do with Accoustics in Garage - AVS Forum | Home Theater Discussions And Reviews
Old 10-17-2013, 09:38 AM - Thread Starter
SHMO's Avatar
I am hoping for some effective, and inexpensive suggestions for my garage theater. I would like to improve the acoustics, but at the same time keep a functioning garage setup. For obvious reasons, the acoustics of this room as stacked against me. I am completely clueless on what to address first, and where my best bang for the buck focus should be.
Here is my setup.
5.1 surround
8" monoprice Kevlar in walls speakers for LCR
8" monoprice in ceiling speakers for surround
BIC F-12 subwoofer
The room itself is 24'x25' with 10 foot tall ceilings.
Any and all suggestions are welcome.
Thanks in advance.
SHMO is offline
Old 10-19-2013, 08:12 AM
petew's Avatar
Quoted: 26 Post(s)
Liked: 68
I'd add rigid fiberglass panels to walls and ceilings to tame the space down. You could either buy prefabricated stuff or go the DIY route.
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
Old 10-21-2013, 09:03 AM - Thread Starter
SHMO's Avatar
I appreciate the reply. Thanks
SHMO is offline
