Grafik eye QS versus 3500 - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: Lutron Grafik Eye: 3506 vs QS
3506 1 50.00%
QS 1 50.00%
Voters: 2. You may not vote on this poll
post #1 of 9 Old 10-20-2013, 03:25 PM - Thread Starter
torontos's Avatar
I can't seem to decide between purchasing the 3506 grafik eye versus the QS model.  And if I purchase the qs, what model number.  This is what I need for my home theater currently:
Zone 1: Can lights above seats
Zone 2: Can lights by screen
Zone 3: Sconces
Zone 4: Rope lighting at stage
Zone 5: step lighting
I read thru the whole definitve grafik eye thread but just as I read it and would lean one way, I would read more and tend to lead the other way.  I appreciate any input.  Thank you.
torontos is offline
post #2 of 9 Old 10-20-2013, 03:41 PM - Thread Starter
torontos's Avatar
I wanted to add that I do not need shade control.  I believe the wireless QS model for 6 zones is QSGRJ-6P.
torontos is offline
post #3 of 9 Old 10-20-2013, 03:46 PM
jautor's Avatar
Quoted: 1327 Post(s)
Liked: 850
The QS has a hard-wired IR port on the back, and is also compatible with RadioRA2 if you ever want to incorporate the GE into a larger system, or want to control via IR (which is what I did).
NOTE: I am fixing photo links in my theater thread - if you find dead photo links elsewhere, please PM me and I will fix it.
jautor is online now
post #4 of 9 Old 10-20-2013, 05:20 PM
TMcG's Avatar
Quoted: 1186 Post(s)
Liked: 1002
What types of loads are you running for each of these zones? Are they all 120v incandescent / halogen / xenon? QS is the only one with the ability to control LED loads that are less than 120v.
Jautor has it right with the IR....the QS can accept the IR input from the back of the unit whereas the 3500 only has the IR target on the front. The IR emitter can be hidden underneath the front cover for an equally stealth look and functionality, so don't let IR integration steer your decision.
Quite simply, if you have LED anything that's less than 120v, then you have to go with QS, otherwise save yourself the $$ and go with the 3500 series.
TMcG is offline
post #5 of 9 Old 10-20-2013, 08:19 PM
RossoDiamante's Avatar
I did let IR integration steer me to the QS's.  Just hooked up the first GE this weekend.  Have 3 of the 6 loads currently fully wired.  Works like a charm.  All incandescent loads.  I will try the IR integration this week.
Diamante Build in DC - Double Drywall, Green Glue, Drywall Furring Channel, Riser, Stage, Bass Trap, In-Wall Speakers, BG Radia, JTR Captivators, Seymour AV, Sony HW-50ES, Sherbourn, Panasonic, Middle Atlantic, Lutron Grafik Eye, Baffle Wall
RossoDiamante is offline
post #6 of 9 Old 10-21-2013, 07:48 AM - Thread Starter
torontos's Avatar
Does the QS need a low voltage interface to connect low voltage wiring like the 3500 does?
torontos is offline
post #7 of 9 Old 10-21-2013, 05:07 PM
TMcG's Avatar
Liked: 1002
If you use the bus port, then yes. Options are RS-232 and TCP/IP control via the bus.
Lutron "speak" is natively RS-485, so the device essentially translates the communications protocol coming from the bus to interface with the control system.
TMcG is offline
post #8 of 9 Old 04-28-2014, 11:13 AM
kmhvball's Avatar
Quoted: 546 Post(s)
Liked: 301
Hi Jeff,
I noticed this post and another one, I think of yours, referencing purchasing IR 'wire' for the GE QS.   So, clearly one end of the wire is attached into the QS Unit/4 gang box.   Where is the other end terminated, in the equipment rack?   You have quite likely answer this, but I didn't see it off hand.
Kevin
kmhvball is offline
post #9 of 9 Old 04-28-2014, 11:18 AM
jautor's Avatar
Liked: 850
It needs to go to wherever the IR signal is coming from... Which, yes, is probably the equipment rack. In my case I have a Global Cache GC-100/iTach providing the IR signal.
