Does This Make - AVS Forum | Home Theater Discussions And Reviews
Old 10-23-2013, 09:21 AM - Thread Starter
EdL
EdL's Avatar
I have an existing basement ceiling that has 2 layers of 1/2" drywall (no green glue), connected directly to the floor joists. Will I receive any noticable sound deadening by adding a 3rd layer of drywall with resilient channels on top of the existing ceiling? The new darwood floors above are driving me crazy.
EdL
EdL is offline
Old 10-23-2013, 10:38 AM
Quoted: 3258 Post(s)
Liked: 2744
First the design you propose is a triple leaf which can work against you, you want a fix you need rip down the ceiling and start over. In this case use solution level 5 diagramed at the soundproofingcompany.com. Attach two layers of DW directly to the bottom of the sub floor then add clips and hat channel then two layers of 5/8 eith GG.
Old 10-23-2013, 07:05 PM - Thread Starter
EdL
EdL's Avatar
Thanks, but that won't be possible, budget won't allow a 1,000' sq. ft. demo & do ever.
EdL
EdL is offline
Old 10-23-2013, 07:08 PM - Thread Starter
EdL
EdL's Avatar
Will another layer of drywall without the clips and green glue help.
EdL
EdL is offline
Old 10-23-2013, 07:37 PM
Liked: 2744
define help, I'm sure with the right test equipment you could measure an improvement. Will it cut the sound in half? doubtful.
Old 10-24-2013, 02:59 PM - Thread Starter
EdL
EdL's Avatar
I'm looking for an improvement of between 25 - 50%. I was originally hoping for more.
EdL
EdL is offline
Old 10-25-2013, 08:22 AM
cw5billwade's Avatar
Quoted: 328 Post(s)
Liked: 184
I agree with Big and if you are careful when you take down the existing drywall by cutting along the floor joists you can reuse it as Big suggested. Look how Tim did his http://www.avsforum.com/t/1442340/the-stonewater-cinema-build-thread/250_50#post_22887842
I only have about 3k in sound proffing but that was with IB-1 clips and hat channel on three walls and the ceiling and IB-3 clips on my decoupled double wall at the back of theater. Half of that cost was Green glue but to me well worth it.
cw5billwade is offline
Old 10-25-2013, 02:33 PM - Thread Starter
EdL
EdL's Avatar
You all are making me pause, rethink, and possibly reload. My dilemma is that my room is not a dedicated theater, it's an open area with a wet bar in the middle, pool table on the other side. Windows on 1 wall (3 - 45" by 40") on one side of the TV area. I don't think I can afford to get the acoustics right, just trying to quiet the friggin hardwood down.
Time to rethink....
EdL is offline
Old 10-25-2013, 03:16 PM
GWCR's Avatar
Quoted: 17 Post(s)
Liked: 39
You may want to post a few pics and/or draw out the entire space. That will help you get the best advice from everyone on here (plus, we like to look at pictures...rolleyes.gif).
GWCR is offline
Old 10-25-2013, 07:30 PM - Thread Starter
EdL
EdL's Avatar
Under the soffit area is approximately 7.5' high. Soffit free areas are 9' high.
Width across window to wall is approximately 15.25' feet.
Distance to theater seats approx. 10' from TV Screen.
There are bunches of angles, no rectangles here.
EdL
This is the view from the left side facing the Theater area.
Lside.JPG 270k .JPG file
Straight back from behind the bar.
Bside.JPG 250k .JPG file
EdL is offline
