Double Stud wall - how much space between it and foundation wall - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 47 Old 10-24-2013, 11:34 PM
Cmontesi's Avatar
What I don't understand is from the west wall to the riser, it's 12'-8" but the boiler room size is 14' yet it's supposed to be smaller?
That hall width is 8'-10" according to that drawing yet the scale of the hall has a smaller footprint than the stairs which has the thread length at 3'-6".
Its confusing me
Cmontesi is offline
post #32 of 47 Old 10-25-2013, 04:49 AM - Thread Starter
cgott42's Avatar
Quoted: 133 Post(s)
Yep,the measurements are correct. I need to redraw to scale.
cgott42 is offline
post #33 of 47 Old 10-26-2013, 12:50 AM
Cmontesi's Avatar
Then that would mean the start of your stairs is basically in front of the boiler room and not to the side. That's throwing me off.
Cmontesi is offline
post #34 of 47 Old 10-27-2013, 12:06 AM - Thread Starter
cgott42's Avatar
Quoted: 133 Post(s)
BigM you mentioned about theflankingproblem if I leave two if the walls as bare poured concrete foundation
I want to do this the right way
How wouldi putawall in frontof the foundation wall?
What would I secure it to as the ceilng is already finished w clips and at channels
Also whatwould I put on theback of the frame nexttothefoundation. As there wouldn't be room to get behind there to hang drywaall
Lastly thespace islimited so hopefullyit won't take up too much room
Thx
cgott42 is offline
post #35 of 47 Old 10-27-2013, 08:01 AM - Thread Starter
cgott42's Avatar
Quoted: 133 Post(s)
CMontesi - I've updated the diagram, also I've organized the thread to better help others.
So please see this design threadw/ the updated diagram- Thanks!
BigM - Please reply in this FW thread in regards to the wall for the foundation wall
cgott42 is offline
post #36 of 47 Old 10-27-2013, 10:52 AM
Quoted: 3255 Post(s)
Liked: 2743
Thx
You would frame a wall one inch or so off the foundation. If the ceiling is already finished and you aren't keen on fastening the wall to the ceiling you would use IB3 clips as standoffs. Secure one end with masonry anchors and the other to a few studs (every 3-4 ft) near the top. The framing can stop one inch shy of the existing ceiling.
found this image with google
post #37 of 47 Old 10-27-2013, 11:20 AM - Thread Starter
cgott42's Avatar
Quoted: 133 Post(s)
thanks! - what tools do I need to fasten the masonry anchor to the foundation wall. And is there anything that I need to do so that I don't make a crack in the foundation?
re: the ceiling - I'd attach the wall to the ceiling - however now that it's finished - how can I find where the hat channel is?
cgott42 is offline
post #38 of 47 Old 10-27-2013, 11:41 AM
Liked: 2743
get a magnetic stud finder to locate the screws that originally fastened the drywall to the channel. this sucker works and will hold itself on a wall or ceiling to a hidden screw.
http://www.amazon.com/CH-Hanson-03040-Magnetic-Finder/dp/B000IKK0OI
post #39 of 47 Old 11-11-2013, 10:02 PM - Thread Starter
cgott42's Avatar
Quoted: 133 Post(s)
If I create a wall and attach it to the ceiling joists via whisper clips or RISC clips - should the face of the wall also then have whisper clips + hat channels installed to hold the DW+GG+DW (i.e. double decoupling) - or does the it then get attached directly to these studs since they are decoupled? (looking for LFE containment for $600 SVS sub - i.e. nothing rediculous , but regular theater level volume and sub)?
cgott42 is offline
post #40 of 47 Old 11-13-2013, 08:51 AM
AirBenji's Avatar
Quoted: 35 Post(s)
Liked: 83
No, you do not want to double decouple. Two options:
1. Build your wall so that the top plate is an inch or so short of the joists above. Then use IB-3 clips to attach the top plate to those joists. Finally, fasten your sheetrock to the studs as in any other room in the house. IB-3.
2. Build your new wall and mechanically fasten the top plate to the joists above (nails, screws, etc.). Then add WhisperClips and hat channel to the face of your new wall. Finally, attach sheetrock to the hat channel. Be sure to use appropriately sized screws so that you do not screw the sheetrock directly to the framing. WhisperClip.
AirBenji is offline
post #41 of 47 Old 11-13-2013, 09:59 AM - Thread Starter
cgott42's Avatar
Quoted: 133 Post(s)
thanks -I didn't realize that double decoupling makes things worse (If I'm understanding correctly - or did you just mean that it's a waste of $$ , with no added benefit)
I think I read in the forum that option (1) is the better of the options
cgott42 is offline
post #42 of 47 Old 11-29-2013, 04:53 AM
Nightlord's Avatar
Quoted: 711 Post(s)
Liked: 237
Think of a decoupling as a spring coil. You have a certain resonance. Now take two slightly or very different springs and connect together - what do you get? Definitely not something calculated for that application. Decoupling clips are designed for an operating range, combining it with another decoupling may very well move it outside the useful range.
Under construction: the Larch theater
Nightlord is offline
post #43 of 47 Old 11-29-2013, 07:25 AM - Thread Starter
cgott42's Avatar
Quoted: 133 Post(s)
thx
cgott42 is offline
post #44 of 47 Old 12-23-2013, 01:24 PM - Thread Starter
cgott42's Avatar
Quoted: 133 Post(s)
Probably a stupid Q, but just to confirm:
Finally about to start framing the wall - the ceiling (made last year) is already decoupled from the joists (i.e. 3 layers of DW+GG+DW+GG+DW attached to the ceiling joists via Whisper Clips + Hat Channel ) - being so do I attach the stud of the new wall directly to those hat channels - or do I need IB3 or other clips to separate the new wall - I'm guessing I don't need but want to confirm.
I'm figuring to use 4" screws - b/c 3 sheets of DW = 15/8” + 1.5” wood stud (2x4) = ~3.5” - so the screw will go 1/2" into the hat channel, and there's a 7/8” gap until the ceilign joists
Not sure if it will ruin the soundproofing of the ceiling
cgott42 is offline
post #45 of 47 Old 02-09-2015, 10:32 PM
Liked: 0
<div class="quote-container" data-huddler-embed="/t/1496221/double-stud-wall-how-much-space-between-it-and-foundation-wall/30#post_23943286" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>AirBenji</strong> <a href="/t/1496221/double-stud-wall-how-much-space-between-it-and-foundation-wall/30#post_23943286"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
No, you do not want to double decouple. Two options:<br><br>
1. Build your wall so that the top plate is an inch or so short of the joists above. Then use IB-3 clips to attach the top plate to those joists. Finally, fasten your sheetrock to the studs as in any other room in the house. <a class="bbcode_url" href="http://www.soundproofingcompany.com/soundproofing-products/soundproofing-clips/ib-3-clip/" target="_blank">IB-3</a>.<br><br>
2. Build your new wall and mechanically fasten the top plate to the joists above (nails, screws, etc.). Then add WhisperClips and hat channel to the face of your new wall. Finally, attach sheetrock to the hat channel. Be sure to use appropriately sized screws so that you do not screw the sheetrock directly to the framing. <a class="bbcode_url" href="http://www.soundproofingcompany.com/soundproofing-products/soundproofing-clips/whisperclip/" target="_blank">WhisperClip</a>.</div>
</div>
<br>
Probably a stupid Q, but just to confirm:<br><br>
Finally about to start framing the wall - the ceiling (made last year) is already decoupled from the joists (i.e. 3 layers of DW+GG+DW+GG+DW attached to the ceiling joists via Whisper Clips + Hat Channel ) - being so do I attach the stud of the new wall directly to those hat channels - or do I need IB3 or other clips to separate the new wall - I'm guessing I don't need but want to confirm.<br>
I'm figuring to use 4" screws - b/c 3 sheets of DW = 15/8” + 1.5” wood stud (2x4) = ~3.5” - so the screw will go 1/2" into the hat channel, and there's a 7/8” gap until the ceilign joists<br>
Did you ever get an answer to your question? Does anyone have input here (as old as this thread is)?
Bongani is offline
post #46 of 47 Old 02-10-2015, 05:00 AM
Liked: 2743
If you build your room correctly you will never need an answer to this question, You frame the room first. if for some reason you do just run screws up into the channel
post #47 of 47 Old 02-10-2015, 06:42 AM - Thread Starter
cgott42's Avatar
Quoted: 133 Post(s)
Yep agreed, I only had the Q - b/c I did a partial soundproofing to begin, and then had to redo/finish.
however to let you know, yes, I screwed the studs into the channel, and my result is good. Though I did notice that depending on how you size the studs, you can make it so that the studs push up into the hat channel and into the whisper clip so that the clip doesn't have any give to absorb the vibration.
cgott42 is offline
