Best position for 2 subwoofers - option 1, 2, or 3? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 10-28-2013, 06:52 PM - Thread Starter
kenhdtv's Avatar
Quoted: 16 Post(s)
Posted this question in the subwoofer forum but it might make more sense here ...
http://www.avsforum.com/t/1496961/best-position-for-2-subwoofers-option-1-2-or-3
Also, front-facing or floor-facing subwoofers?
kenhdtv is offline
post #2 of 10 Old 10-28-2013, 07:30 PM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
Measurements will tell you better than anybody on here could. If you want it to look the best, than behind the screen where you can't see them is what I would say.
If you cant measure, do a sub crawl test. Also, the way the sub fires does not matter. What matters is the sub quality and amp compatibility.
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
post #3 of 10 Old 10-28-2013, 07:55 PM - Thread Starter
kenhdtv's Avatar
Quoted: 16 Post(s)
Thanks for the quick feedback PI. There won't be a shelf at the bottom of the screen so they would have to sit on the floor (carpeted).
kenhdtv is offline
post #4 of 10 Old 10-28-2013, 07:57 PM
HopefulFred's Avatar
Quoted: 490 Post(s)
Liked: 422
Bill is right in his answer on the other thread, but there are things you can bet on - like he said, you'll probably want one or more in the back of the room.
If you have adequate headroom and ability to EQ the subs independently, you can do a good job of getting good bass with subs in all four corners. Two is not as good, but can be done - the center of opposite walls is optimal (for making the bass response as similar as possible across multiple seats) with 2 subs. Check the first white paper at this link.
Wire is pretty cheap - mark every sub position you could possibly make use of, then use the two that work out best.
HopefulFred is offline
post #5 of 10 Old 10-28-2013, 08:37 PM - Thread Starter
kenhdtv's Avatar
Quoted: 16 Post(s)
Thanks Fred. He's going with powered subwoofers so the issue is also where to put AC outlets. The area at the back isn't an option because it can be used as a walkway from one part of the house to another. I'll take your vote as option 3 being the best of the 3.
kenhdtv is offline
post #6 of 10 Old 10-29-2013, 10:25 AM
dragonleepenn's Avatar
Quoted: 193 Post(s)
Liked: 85
Put one at the front center either under the center channel or right next to it. And one at the rear center wall about three inches away. Try it ! It works you can place one at the rear it clearly looks as if the space is there.
PeterV
dragonleepenn is offline
post #7 of 10 Old 10-29-2013, 10:57 AM - Thread Starter
kenhdtv's Avatar
Quoted: 16 Post(s)
Thanks for your comments Peter. That back recessed area will be occupied with cabinets for the electronics so it's not an option for a sub. I shoulod have marked that on the diagram.
kenhdtv is offline
post #8 of 10 Old 10-29-2013, 11:52 AM
Quoted: 193 Post(s)
Liked: 85
Then go with number one(1) it should still give a good coverage, hopefully nulls won't be a problem. Try to place your main listening position (seat) at the 38% distance from the back wall. That should help with a more smooth position to Listen from. Good luck your plan has high potential I like the setup. The layout of the surrounds/back speakers again looks very well thought out. What components are you using? Any pictures?
PeterV
post #9 of 10 Old 10-29-2013, 12:37 PM
kromkamp's Avatar
Quoted: 88 Post(s)
Liked: 70
If you don't have a convenient starting point (such as midpoint of two opposing walls), then your best strategy is to do a little analysis with something like Room EQ Wizard. Put a sub at your seating location, and measure the response at different spots where you might put your subwoofer. Pick the flattest. Then do the same with your second subwoofer.
kromkamp is offline
post #10 of 10 Old 10-29-2013, 12:55 PM
filetandrelease's Avatar
I placed 1 of my Chase 15" Cubes behind the screen, the other on the back riser off the way a bit- sounds great, you really feel the bass all around you with the front/back config. Beign piushed my a 1000W amp helps smile.gif
filetandrelease is offline
