Better way to secure can light trims? (Stop the rattling?) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-01-2013, 12:36 PM - Thread Starter
blipszyc's Avatar
Quoted: 134 Post(s)
Liked: 72
Subject says it all - I've got 6 can lights in the theater and the trims still rattle during heavy bass scenes. I was thinking I could run some weatherstripping material inside of the trims to stop the rattle, but wondered if anyone tackled this problem a different way and if it was successful.
Visit the Lipszyc Home Theater! 1.0
2.0 done and finally posted! - Theater 2.0
And now...The Queen City Theater (3.0)
blipszyc is offline
post #2 of 3 Old 11-01-2013, 01:41 PM
Quoted: 3255 Post(s)
Liked: 2743
I had some sconces with glass that rattled. I used clear 100% silicon caulk. It has a pretty high temperature rating so no issue there.
post #3 of 3 Old 11-02-2013, 02:23 AM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
I used spray foam that is fire rated. The kind used in walls that is orange colored. Get it at home improvement stores. Works amazingly well. Will melt at parts closest to bulbs so lay down some cloth at first.
Blazar!
blazar is offline
