Trim or not to trim front theater wall - AVS Forum | Home Theater Discussions And Reviews
Old 11-02-2013, 05:45 AM - Thread Starter
toofast68's Avatar
Quoted: 485 Post(s)
Liked: 130
I am finally making progress again and my wife and I are in a "battle".
How many of you actually put baseboard trim on your front theater wall ?  Mine will be FR701 Black Fabric over Linocoustic using the Fabricmate setup, etc.
This is NOT a dedicated theater per say, but it is a "dedicated" theater in a open room concept, so you will see baseboard trim on the back (drywall) walls, etc.
Any "opinions" are welcome.
Below is an overhead "Drawing" of the space to give everyone a visual....
700
toofast68 is offline
Old 11-02-2013, 06:04 AM
Quoted: 3255 Post(s)
Liked: 2743
It is a hard call, I've done it both ways,
Since you are not doing a false wall, it complicates the issue. The best approach visually if you are doing floor to ceiling fabric with a track system is to have the baseboard out from the wall the same distance as the fabric. I often use wood furring for fabric so the baseboard goes over top hiding the staples, In your case you would add furring behind the baseboard then mount the fabricmate track tight to the top of that. Of course you don't want to paint it white.
If you don't put something down at the bottom of the wall you will need to be carful to keep banging it with the vacuum.
I've done front walls without baseboards. After the room was carpeted I built frames surrounding the screen, see staggered panel thread in my signature. The panels sat directly on the carpet. We removed the front wall baseboard but the side wall panels mounted on top of the existing baseboards.
Old 11-02-2013, 06:26 AM - Thread Starter
toofast68's Avatar
Quoted: 485 Post(s)
Liked: 130
Yeah, tell me about it...
What if I put the fabric walls "nearly" to the floor...then I put the trim OVER top of the fabric, treating the fabric wall like a regular wall?  I would be blocking behind the fabric to allow me to nail the trim into it ?  Does that make sense ?
Old 11-02-2013, 07:31 AM
Mazeroth's Avatar
Me thinks you need to be more concerned with your speaker placement in your rendering. tongue.gif
Mazeroth is offline
Old 11-02-2013, 07:40 AM - Thread Starter
toofast68's Avatar
Quoted: 485 Post(s)
Liked: 130
Yes the speakers are not quite right, that is for sure!
Old 11-02-2013, 09:44 AM
Liked: 2743
I think that is what I said
Old 11-02-2013, 11:34 AM - Thread Starter
toofast68's Avatar
Quoted: 485 Post(s)
Liked: 130
Ok, sorry...but pictures are worth a 1,000 words.
Awesome, thanks much!
Old 11-02-2013, 01:16 PM
fcaico's Avatar
Big, Your theaters are always so nice. Wish you lived closer to me! :-)
I'm very happy with my theater, but its just not quite the level of awesome that even your simple plans come out like.
fcaico is offline
Old 11-02-2013, 10:01 PM
Scopeguy's Avatar
I didn't put any trim/baseboards at the front of the room and I'm quite pleased with the look.
Scopeguy is offline
Old 11-03-2013, 09:55 AM
Tedd's Avatar
Quoted: 922 Post(s)
Liked: 339
You could warp the columns with the kick trim and do a return to wall, ninety degree cut. The rets could be
fabric to floor or if you want some protection from a vacuum, you could use a half round profile painted out
in black.
kick trim.JPG 16k .JPG file
Tedd is online now
Old 11-04-2013, 11:51 AM - Thread Starter
toofast68's Avatar
Quoted: 485 Post(s)
Liked: 130
Awesome, thanks for the visuals...I think that is what I am going to do....meaning NO TRIM on the front wall, but trim up to it.
Old 11-04-2013, 12:34 PM
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 139
And another visual (black base board between black panels and black stage). This was a false wall application, but the concept would still work against a regular wall. I applied the baseboard first and the panels attach to the false wall just above the baseboard. In your application, you could just run the bottom piece of Fabricmate track just above the top edge of the baseboard. I like not having to be too careful with the vacuum.
Spaceman is offline
Old 11-04-2013, 02:29 PM - Thread Starter
toofast68's Avatar
Quoted: 485 Post(s)
Liked: 130
Your theater is awesome...thanks again, now I am undecided again, I love what you've done!
