passive subs? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 11-03-2013, 01:50 AM - Thread Starter
Thundersnow's Avatar
Quoted: 24 Post(s)
Liked: 36
I have a very basic noobish question.
Do I want passive or powered sub woofers in my ht?
My experience with av equipment is limited to my current tv room setup with an onkyo av 5.1 system including a small 8" powered sub box.
I am currently building a dedicated ht in the basement and planning to have 2 12" subs located behind a AT screen along with the left right and center speakers.
I just don't know rather it's better to have the sub amps in the av closet or powered sub boxes. I haven't purchased my ht receiver so that's completely still open. Is there a receiver that offers amplification for sub woofers or are they only pre amp outputs?
Sorry like I said I am a noob when it comes to this.
Thanks for the help
Thundersnow is offline
post #2 of 17 Old 11-03-2013, 02:51 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
You'll need a separate sub amp (or amps, although one might do) for passive subs; also likely you might need some sort of dsp/eq, which can come included with suitable amps for passive subs or in a separate unit like a miniDSP. AVRs have only sub pre-outs (and not enough juice to run much of a passive sub otherwise) but do usually offer built in bass management.
What subs are you considering?
lovinthehd is offline
post #3 of 17 Old 11-03-2013, 06:01 AM
Quoted: 3266 Post(s)
Liked: 2751
while there are some capable 12 inch subs, it really is about moving the most air possible, If you haven't already bought the twelves look at some 15s or take a jump and build your own. There are plenty of guys who will advise you in the DIY speaker building section of this forum. You can even buy a CNC cut cabinet, glue it together and pop in a driver. Check out DIYsoundgroup.com
post #4 of 17 Old 11-03-2013, 01:21 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 942
Big has a great idea........................
Here is an option I'm thinking about using for rear leveling subs............
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-7094
doublewing11 is offline
post #5 of 17 Old 11-03-2013, 06:18 PM - Thread Starter
Quoted: 24 Post(s)
Liked: 36
The DIY sound group is the route I'm taking for my LCR speakers probably Fusion 10" Pure and then maybe Alchemys 8" for the surrounds.  I haven't made the selection for subs yet. Actually I haven't bought any speakers or other equipment.
My room is small at 8'x18'x8'.
As BIG stated I like the idea 15" subs. Sounds like passive is the way to go then?
Would this be a good option for me? http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-7093 What should I use for an amp and maybe dsp?
post #6 of 17 Old 11-04-2013, 05:35 AM
Liked: 2751
That is a DIYsoundgroup cabinet sold by PE you may want to visit their forum (diy) and ask for recommendations of the best drivers, of course there is a good DIY speaker forum right here in the audio section.
post #7 of 17 Old 11-04-2013, 05:56 AM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 81 Post(s)
Liked: 126
they also have a upgraded version http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-7097
this is one i think i will be ordering soon
snickers1 is offline
post #8 of 17 Old 11-04-2013, 02:33 PM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 691
I added 2 "helper" subs, one 15" 3 cu ft and one 18" 4 cu ft with SI drivers, to my HT room for flatter in room response, these helped my IB sub 4 x 15" line array.
I used a iNuke6000DSP to power both, works perfect.
I bought a iNuke3000DSP for my family room, I'm putting (2) 12" ported subs 4 cu ft , both with the Ultimax driver.
IMO that PE package deal is a steal, I'd grab either the 18" Dayton or the 15" Ultimax sub/box package at a heartbeat.
Better yet, get 2 of the 15" Ultimax for flatter in room response if you have multiple seating positions. Best would be 4 subs spread at the mid-points OR the corners.
Different threads went into the whys of that.
mtbdudex is offline
post #9 of 17 Old 11-17-2013, 04:44 AM - Thread Starter
Quoted: 24 Post(s)
Liked: 36
Rather than start a new thread I hope I can get an answer here since this question goes along with my original.
How do you decide rather to go with an amp in the a/v rack or amp built into the sub box? And for clarification is it correct if I want a powered sub box then need to run coaxial rg6 from the a/v rack to the sub?
At this point in my build I can go either way I'm just not sure if one is better than the other. Does distance of the run matter? My run will be about 30ft.
post #10 of 17 Old 11-17-2013, 05:07 AM
jbcain's Avatar
Liked: 64
Do you want to run dedicated electrical circuits and interconnects to each sub location or just some speaker wire? Rack located amps allow centralized tweaking with the rest of your gear and also allows a common cooling solution
jbcain is offline
post #11 of 17 Old 11-17-2013, 05:20 AM - Thread Starter
Quoted: 24 Post(s)
Liked: 36
I am going to have the sub behind the screen wall so access will be limited. That's a good reason to go with the rack mounted amp. As long as there isn't a good reason to go with a powered sub box then I guess I will stick to passive.
Thanks for the quick response.
post #12 of 17 Old 11-17-2013, 09:24 AM
Quoted: 229 Post(s)
Liked: 942
To answer your question........
If you purchase commercially manufactured subs then you are better off having outlets wired for plate amp subs spread around the room........as noted in prior post, mid-line at each wall location including routing snurf tube to rack.. I'd also recommend doubling the front wall outlets. On the safe side, I'd also wire in a pair of additional 20 or even a 30 amp circuits in rack to future proof your installation.
My biggest regret is NOT having a second dedicated 20 amp circuit for front wall and not having 4 dedicated 20 amp circuits in my rack.........I have 3-20 amp circuits and 2 15 amp circuits which is not enough.
Consider your options and the bug of adding more subs to your room in the future. The "Add more BASS" disease will surly hit you smack dab across the face!!biggrin.gif
post #13 of 17 Old 11-17-2013, 10:32 AM
Quoted: 229 Post(s)
Liked: 942
To the OP.................................
This came out today and I really believe you should be as excited as I am. Here is the information:
http://www.parts-express.com/dayton-audio-um18-22-18-ultimax-dvc-subwoofer-2-ohms-per-coil--295-518
Yup, Dayton Audio will be coming out with a new driver Jan 30, 2014,,,,,,,,,,,,,,,,, a product that should compete with the very best drivers than go down DEEP!
I was about to purchase 4 UXL 18's which are more than double the cost of these Dayton Audio drivers.....................good times! biggrin.gif
post #14 of 17 Old 11-17-2013, 01:37 PM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 691
Whohhh, 18" ultimax.....need to model those vs SI.
Via my 64GB iPhone 5s using Tapatalk
mtbdudex is offline
post #15 of 17 Old 11-17-2013, 01:44 PM
Quoted: 229 Post(s)
Liked: 942
post #16 of 17 Old 11-17-2013, 01:55 PM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 691
Doublewing, did these model into 4 cu ft for sealed? Perfect for flat pack if so.
mtbdudex is offline
post #17 of 17 Old 11-17-2013, 02:47 PM
Quoted: 229 Post(s)
Liked: 942
Yeah, 4 cf is what is indicated..............I suspect xmas will be close to the drivers in S2 which is why I was about to purchase UXL-18's.
I have emailed parts-express wondering if a flat pack will be available with discount like the 18HO.....................I will only need two flat packs as I'm building end tables with the other two drivers. I've sourced 18 ply 1" BB locally for those end tables.........................that plywood was almost as much as the 3/4'' Knotty Alder plywood I used for my columns! eek.gif
