Splitting an IR signal - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 11-04-2013, 02:35 PM - Thread Starter
mbroder's Avatar
I posted this in the remote control forum as well, but this is part of my dedicated theater build, so I thought it might be more appropriate here and thought some of you may have experience with it.
I have 4 components in my rack that are going inside a closet. All of them have IR input ports in the back that I can use a 3.5mm IR receiver and plug right in. My question is, can I just use 1 receiver (eye) and split it with a few of these and daisy chain them without using an IR block or some kind of repeater kit with emitters? I'd like to avoid using emitters over the sensor if I can. It seems simple, but maybe too simple???
mbroder is offline
post #2 of 11 Old 11-04-2013, 02:43 PM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
Not sure about that. It is a cheap try though. Look on the back of your components. Some of them might have an IR input and output that will do the same thing you are wanting to do.
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
post #3 of 11 Old 11-04-2013, 02:45 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
An IR receiver needs power from somewhere...
That's what the connecting blocks are for, usually. Power in, Receiver in, 3-4 emitter ports out. You can use those emitter ports with a 3.5mm patch cable to those input jacks.
jautor is online now
post #4 of 11 Old 11-04-2013, 03:02 PM
Quoted: 978 Post(s)
Liked: 506
jautor....I just looked at your photobucket pics and have to say that that your theater is really nice! Was that an attic space originally?
post #5 of 11 Old 11-04-2013, 03:21 PM - Thread Starter
mbroder's Avatar
So I need power...okay. Can I use this from monoprice, but just use 3.5mm patch cables instead of the emitters?
mbroder is offline
post #6 of 11 Old 11-04-2013, 08:33 PM
jautor's Avatar
Liked: 777
Thanks! No, it was a space that was left "unfinished" during construction so that I could have both time and money to build the theater later... biggrin.gif
post #7 of 11 Old 11-04-2013, 08:34 PM
jautor's Avatar
Liked: 777
Probably. The IR input jacks on equipment can be finicky - it SHOULD work but you can fall back to emitters if needed. Emitters on concealed equipment are quite reliable, but I'd certainly try the jacks first, too.
Jeff
post #8 of 11 Old 11-05-2013, 10:17 AM
TMcG's Avatar
Quoted: 1072 Post(s)
Liked: 870
Did anyone consider just buying dual IR emitters like this??? http://www.amazon.com/Unique-Products-Online-Dual-Emitter/dp/B00255NW12
They work perfectly. I've installed hundreds with a wide variety of equipment and never any issues. You only need power boost if you are moving to 3+.
TMcG is offline
post #9 of 11 Old 11-05-2013, 10:52 AM
jautor's Avatar
Liked: 777
OP wanted to use IR input jacks on his equipment instead of emitters. As it stands, though, he doesn't have a functional IR receiver / repeater system, so that's step 1. But yes, dual-headed emitters work perfectly once you've got the signal captured!
post #10 of 11 Old 11-05-2013, 11:05 AM
TMcG's Avatar
Liked: 870
Oops! biggrin.gif I will say that a surprising number of IR input jacks on equipment is non-functional....most notably on TVs for some reason.
Regarding the OP, I have never seen an IR repeater system where the target doesn't require a power supply. Either that dual-band Monoprice unit or something like THIS from Newegg should work perfectly with switching out the IR emitters for mono cables.
TMcG is offline
post #11 of 11 Old 11-05-2013, 02:33 PM - Thread Starter
mbroder's Avatar
Thanks for the replies...
I'm going to order the one from Monoprice. I need to order my wiring from them anyway, so for $17 it's worth a shot. Hopefully I can use the IR jacks on my Marantz 7007 receiver , Oppo 103 and DirectTV HR34 without too much trouble.
mbroder is offline
