Old Woods Theater 2.0 - Page 6 - AVS Forum
post #151 of 163 Old 05-15-2014, 10:47 PM
DavidK442's Avatar
Quoted: 21 Post(s)
Liked: 65
I just read through your thread. If I understood correctly there were three goals to your upgrade; improved aesthetics, a more lively, less absorptive sound and better sound proofing.
The aesthetic upgrade is obvious. As others have commented I love the rock faced screen wall and the staggered panels which blend very nicely.
You made a comment that the acoustics were as good, if not better than your previous theater. Given the 2D diffuser at the first reflection point and the use of hard flooring in the back half of the room I assume that the sound is noticeably different. I think audio recollection is a muddy thing, but do you have any other thoughts on the difference in sound for movies and music?
I see no comment on the sound proofing. Did the use of channel and insulation have any obvious affect?
Your ceiling height was 7.5 feet correct? How long and wide is your theater?
By the way, I liked your observation that it was difficult to tell the difference between projected black and black shadowed by your hand.
That puts the JVC black level into perspective.
I remember how dismayed I was when I brought home my first projector a few years ago (a Panasonic AE 4000 "Ultra Contrast") and was able to perform shadow puppet shows on a projected black screen. I have been running low cost DLP's ever since. Glad to know that when I upgrade to a real projector the shadow puppet show will be a thing of the past.
ellisr63 likes this.
DavidK442 is online now
post #152 of 163 Old 05-16-2014, 05:08 AM
elmalloc's Avatar
Liked: 35
I think there are different tiers of projects, Panasonic is not in the same tier as JVC/Sim2, etc. In my opinion the real deal starts around 4-5K, but it seems like the Ultra Black Epsons have done an OK job in the black department, just from reading reviews.
Current Projects:
ON HOLD - Building Home Gym.
elmalloc is offline
post #153 of 163 Old 05-16-2014, 05:55 AM - Thread Starter
deewan's Avatar
Liked: 54
Originally Posted by rmaddog View Post
Wow, I really am diggin' your room. Love how you used so many different materials and yet made it look fantastic. I have thought about getting iRule and you setups just look awesome and have just about pushed me over the fence to give it a go.
Thank you for the kind words. After a steep learning curve with iRule (with I have read about a lot), I REALLY like how easy it is and how effective it is. It really is very easy to personalize if you choose to do so. the best thing I can suggest is to download the free 30-day trial and work with it a bit. Watch the tutorials on the iRule page. They really help. Once you understand how the main features work, you can begin to guess at how other things work. For me at least, the first 1-2 hours seems hopeless. Now, it is so easy and seems logical how to set things up.
deewan is offline
post #154 of 163 Old 05-16-2014, 06:23 AM - Thread Starter
deewan's Avatar
Liked: 54
You bring up a very good point. I haven't really addressed the final acoustics of the room. At first I hadn't commented because I was waiting on a new processor and didn't want to spend time monkeying with the current processor only to have that EQ work be thrown away when I upgrade. However, I am still waiting on the new processor so I went ahead and re-calibrated everything using the current gear. If my audio memory serves me properly, I can tell a good difference between the old room and the new room. Sound isolation has been improved. Not as much as I had hoped, but it is very noticeable difference. I don't hear people walking around upstairs anymore and with the exception of bass, the sound is mostly contained to the room. The sound doesn't decay as quickly as in the old room thanks to the decreased absorption, so I say the room sounds more alive. However, there isn't a reverb or echo, so it doesn't fail the clap test. I was trying to strike an even chord (pun?) with 2-channel music and movie surround sound and for the money I spent, I feel I accomplished it. I could have improved the sound more, but besides material costs my out of pocket expense for the acoustics in this room was $0!!! I'm not saying I have a room that sounds as good as a Rives or another company's room. But only my time was spent researching and not the $1500-$2000 for a entry level design.
Many 2-channel live concert recording give the impression of a large concert hall. The sound stage across the front has really impressed me. Prior to a few weeks ago, I didn't have anything EQ'ed and I didn't have my ceiling clouds installed (no pictures posted yet). The room and speakers gave the impression of listening to a good set of headphones. I couldn't pinpoint the sound coming from the speakers, but I could pin point the sound stage (imaging) either. I set the EQ, set the distances, played with the amount the speakers were toe'd in, installed the ceiling clouds and BOOM. First track I listened to I literally got up from my seat and walked to the center channel because I swore I had left the multi-channel DSP turned on and the center channel was active and playing. I was happy to find that the center channel was not active and only the main fronts were producing sound. The sound stage between the speakers is amazing and with a little more tweaking I was able to gain some sound stage outside of the speakers width. That is good enough for now. Once I get the new processor I hope to obtain the same results and add the depth to the sound stage.
Movie soundtracks have also benefited. I don't recall the movie I was watching the other day, but several times I turned my head because I thought my wife had entered the room behind me and was about to interrupt my movie. I had similar experiences before with louder, and more pronounced surround sounds, but I am beginning to pick up the smaller effects now. Most multi-channel soundtracks make the walls disappear completely and I hear only what the sound engineer wants us to hear in the 'movie environment'.
To answer your question, my room does have 7.5 feet ceiling and is 12.5 feet wide and 19 feet deep. I would like a larger room, but 60% of the time it is only me down in the room, and for that it is plenty big. smile.gif
DavidK442 likes this.
deewan is offline
post #155 of 163 Old 05-16-2014, 09:16 AM
DavidK442's Avatar
Quoted: 21 Post(s)
Liked: 65
Great response. Thanks.
Sounds like Theater 2.0 was well worth the time and money.
Enjoy.
post #156 of 163 Old 05-16-2014, 10:05 AM
thrillcat's Avatar
Quoted: 21 Post(s)
Liked: 94
Are you having any issues with your TiVo and the UMC-1? Which TiVo is it, a Roamio, or a Premiere?
I love my iPhone, but it will never replace my turntable.
The Cinema 1858 Remodel Thread
thrillcat is online now
post #157 of 163 Old 05-16-2014, 11:19 AM - Thread Starter
deewan's Avatar
Liked: 54
Enjoy.
It was in my eyes. And since I did all the researching, designed, and building myself, it was pretty cheap all things considered. I think final cost without the equipment upgrades was less than $4K. Almost half of that cost was on the rock wall, solid core door, and equipment rack and shelves. I also sold a few items like the 2-zone Grafix Eye which was replaced with a 3-zone, from the old theater to offset those costs. So it worked out even better in the long run.
My main (whole home) "Tivo" is in the theater and is housed in a Pace MG-1 cable box. It's essentially just the Tivo software in the Pace box. I have Tivo minis in other rooms. But I have had no problems with the UMC and the main DVR hub. Then again, outside of golf, I rarely watch TV down in the basement until football season starts so my experience is limited.
deewan is offline
post #158 of 163 Old 05-16-2014, 11:25 AM
thrillcat's Avatar
Quoted: 21 Post(s)
Liked: 94
Cool, I have an audio issue if I use HDMI audio from the TiVo to the UMC-200. I just added in an optical cable and use that for audio. Don't lose any quality, just checking. I'm looking for someone with a Roamio to perhaps tell me the new units could possibly solve my issue.
post #159 of 163 Old 05-16-2014, 12:13 PM - Thread Starter
deewan's Avatar
Liked: 54
That's an odd duck? Have you found anyone else with the same issues? What is the audio issue you expereince? Dropouts? I'm curious if switching to a different HDMI port on the UMC-200 would make a difference.
deewan is offline
post #160 of 163 Old 05-16-2014, 12:55 PM
thrillcat's Avatar
Quoted: 21 Post(s)
Liked: 94
It's actually pretty common between DVRs and the UMC-200. I was almost expecting it to happen based on what I read, and it did.
Basically, when you FF/REW or Play/Pause or switch channels to a channel broadcasting a different resolution, or going into the menu or guide, basically anytime the audio might cut out and back, it would sometimes get hung up on a single bit of information and repeat it, loudly, it almost sounded like a machine gun. Another quick Play/Pause would usually fix the issue. And it didn't happen all the time. I think it happened 3 times during the first week I had the UMC-200. The common solution was to route audio through an optical cable. Haven't had an issue since.
My non-scientific, totally evidence-free hypothesis is that the UMC-200 needs a good, solid, robust HDMI stream to lock onto, and DVRs don't quite offer that all the time.
post #161 of 163 Old 05-16-2014, 02:23 PM
kjlewie's Avatar
Red pill or Blue pill - love it! The iRule screenshots look fantastic - thumbs up! Very motivational. I'm going to sit down with iRule for a few hours and set if I can get something functional.
Clearly, I'm a man of action - just give me a few minutes to think about it.
Lewis Family Cinema 1.0
Lewis Family Cinema 2.0
kjlewie is offline
post #162 of 163 Old 05-16-2014, 09:05 PM - Thread Starter
deewan's Avatar
Liked: 54
You're move Mr Lewis. Welcome to my new lighting page and drawer... smile.gif
Dedicated page
Drawer
But seriously kjlewie, if you need help with iRule before Sunday, give me a call or shoot me a text.
deewan is offline
post #163 of 163 Old 06-01-2014, 07:22 PM - Thread Starter
deewan's Avatar
Liked: 54
Thought I would post another update. While it is golf season and not much works gets done inside during this time of year, the rainy weather has allowed for some small projects. This past week I installed the first reflection point ceiling absorption. I am VERY happy with how the room reacts with 2-channel music. Most of my 2-channel demo material sounds the best my audio memory ever recalls. A few of my buddies even commented that the sound stage is pin point and stated the always over used phrase, "the speakers disappear". But I have to agree. If I close my eyes and turn my head, I can't point where the speakers are located. I only hear voices or instruments across the front of the room. So, I am very excited about the room treatments and room sound. Not bad since I am still not using any room correction processing and it was all DIY!
deewan is offline
User Tag List
