Klipsch THX Ultra 2 speaker mounting - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By torontos
post #1 of 2 Old 11-09-2013, 08:12 PM - Thread Starter
torontos's Avatar
I am purchasing the Klipsch 7.2 THX ultra 2 speaker system with 3 KL-650-THX and 2 KL-525-THX speakers.  I am planning on mounting them on my walls.  I am thinking of using the omnimount 60.0 ST-MP to mount them but I like the look of the 60.0 WA mounts but it seems they are no longer made and I have read a few reviews stating that heavier speakers tend to sag.  My question is what is your experience with either of these 2 mounting systems or are you using another system (and if so, what?)  Has anybody mounted them in their walls with a built-in frame and how does that affect the sound of the speakers?
babymlin likes this.
torontos is offline
post #2 of 2 Old 11-11-2013, 08:07 PM
Moggie's Avatar
Quoted: 23 Post(s)
Liked: 33
Hi, I put my KL-650-THX on little shelves behind the screen, partially recessed into a cutout in the baffle wall. They sound fine. I have some of the Klipsch omnimount's(no idea which variety they are) but they cause the speaker to protrude quite a way from the wall. The massive ball joint is ribbed so I doubt it would slip if bolted up correctly.
- Paul.
My "Old Vic" Theater Build | Screen Build | HT of the Month | Contest Win
My 8 year old daughter: "are contractors the people that mess up your house for money?"
Moggie is offline
Klipsch Kl 650 Thx Lcr Speaker Right Channel , Klipsch Kl 525 Thx Lcr Speaker
