Ideas for a new Home Theater Room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-10-2013, 11:21 AM - Thread Starter
supersteve1938's Avatar
Just bought a new house and I wanted to turn part of the basement into a HT area.
The room is about 30x30. The stairs are in the middle of the room.
So I will be dividing the room into two parts. The theater area will be 18Lx12W.
I have a few questions.
1) does the area need to be fully enclosed? Or can the back of the area be open to the rest of the room?
2) I was thinking of using dark gray on the walls and roof. The couch will be red and a few red decorations. Th carpet is a light brown and white Berber. I would like to replace the carpet with a dark color. But it's new carpet and seems like a waste. Will the lighter carpet be okay?
3) the basement is finished so I don't want to start ripping down drywall. What are some cheap ways to make the area more theater like and better for sound?
4) we want to keep the costs low What are some cheap decore ideas and what not.
supersteve1938 is offline
post #2 of 5 Old 11-10-2013, 11:49 AM
HopefulFred's Avatar
Quoted: 490 Post(s)
Liked: 422
You can do it however you want - but there is always a cost and consequence. Maybe I can help put a finger on some of the costs and consequences.
1 - A fully enclosed room has several advantages. If defines an acoustic space in which you can mold the sound. Much (most?) of what you will listen to in the theater will be sound reflected from the walls and ceiling of the room. Your brain is very sensitive to the nature of the reflected sound. For the your brain to work with the sound encoded on the track to recreate the "space" of the soundtrack, symmetry and consistency are important. If there is no wall in the rear, your brain will know it, and the sounds from behind you will never have the same character as others. It's hard to put a finger on, and you can enjoy the soundtrack and experience in either case, but how about this: this is one of the few things that BIGmouthinDC has said he would change about his theater if you were to rebuild it.
The second major advantage to an enclosed space is the possibilities for sound isolation. A larger open space invites windows, appliances, and foot traffic - all of which bring in unwanted sound (and heat) and let out nuisance sound to other areas. Your requirements for this are your own, but overcoming these challenges is one of the most significant design/engineering hurdles in dedicate theater building. Be realistic about your uses and needs (as well as your neighbors' and the rest of your household's).
2 - Dark grey for the drywall surfaces is a pretty good choice. Look at LRV (light reflectance value) for the colors/paints you are choosing (I have only seen this bit of data from Sherwin Williams, but it's probably available for other makes - you own't find it at Lowe's or from Martha Stewart. A lower LRV means less of the light from your projector that is reflected to the walls from the screen will reflect back onto the screen and wash out the dark areas of the image. Preserving intrascene contrast is a difficult challenge, but that process can also be aided by certain types of screen technologies. The carpet falls into the same category, obviously, but has some simpler solutions. You could cover it with an area rug near the screen. In fact, this philosophy can be carried to the walls and ceiling, with paint choices.
3 - The cheap ways of dealing with theater acoustics are mostly limited to absorption, and do-it-yourself. There are lots of resources around here to help you visualize the possibilities. As a rule of thumb, try to allocate 4 inches of thickness for wall treatments - keep that in mind when you lay out the seating and other features of the room, like wall sconces or columns or wainscot.
4 - I'm no good for decor ideas, so I'll leave that. You should check out all the "show me" threads in the stickies.
HopefulFred is offline
post #3 of 5 Old 11-10-2013, 04:41 PM - Thread Starter
Thank you for the information. Much appreciated.
post #4 of 5 Old 11-11-2013, 09:03 AM
secondhander's Avatar
Sliding doors at the back can work as a way to enclose your space if you're not sound proofing (I have it) although enclosing fully is definitely best.
If its a finished space and you're not tearing down drywall then fishing the wires to 7+ channels and the patchwork afterwards can be job in itself from experience.
As Fred mentioned go through all of the show me your completed theater looks to see the right look/feel for you.
secondhander is offline
post #5 of 5 Old 11-26-2013, 11:42 PM - Thread Starter
Bought the first thing for our new theater room today.
The couch. Got it at Leon's for $1700
Also found these for $40 each. Going to put them on an 8" riser behind the couch.
