The Beast, Unleashed - Page 42 - AVS Forum | Home Theater Discussions And Reviews
 1532Likes
Old 07-30-2014, 12:48 PM
MIkeDuke's Avatar
Quoted: 466 Post(s)
Liked: 190
I should have worded that more carefully. I did not mean a step down in subs because clearly your are not lacking there. I meant would you have to step down in your projector choice for the time being so you can do everything you want to do(personal and HT wise).
It ain't easy being green.
My System
MIkeDuke is offline
Old 07-30-2014, 03:28 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2686
Matt,
subs is something you can add later. I am. Start with something. Build on it when you get more $$$. That's fun anyways and something to look forward to after your theater is "completed"
4 subs is still "enough" to start and let's be honest even if you add four more it's still not "enough" because "too much is almost enough"right ?
4 Subs will sound great. 8 will sound better. Adding smoothing even better. After all that you could add 32 more This isn't a one lap race, so no reason you need it all upfront. Just design the room to accommodate adding more at a later date easily with location, pre wireing, etc..
I just learned this:
In case you are wondering how loud your home theater has to be to blow girls clothes off: Need help designing serious bass solution for a big theater..horns vs ported or both?
235db !
hmmm.... Scratch that off my bucket list
Haha!.
But seriously your theater is going to be amazing and BTW your thread is going to have 100k views before you install a carpet. Well done on that too.
Mfusick is offline
Old 07-31-2014, 05:09 PM - Thread Starter
BrolicBeast's Avatar
Quoted: 1103 Post(s)
Liked: 1149
Matt,
235db !
Haha!.
HAHAHAA@100k views before carpet!!! That's funny. I appreciate the support on this build---it's a stressful one. I have to call a structural engineer to draw up plans for widening a doorway in a load-bearing wall. Honestly, I'm sick and tired on spending money on things not related to actual theater construction. But hey--when one dreams a lofty dream, one cannot let minor obstacles interrupt the path leading from dream to reality. Thus Sunday I plan to make a serious dent in the double drywall between the joists. I haven't really had the time to do that, but I need to do it before we start wiring.
BrolicBeast is online now
Old 07-31-2014, 06:41 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2686
I hear you. That sucks. If it's any consolation I removed the entire load bearing wall between my kitchen and dining room (half the house) myself and just guessed at the beam lol. Not advising that. But it's still fine 10 years later. I just figured 4 2x12's would be enough for a 15ft span. I might be wrong ... lol We'll see if it falls down. (joking) But you could just skip the engineer part and grab some engineered beams that are in clear excess of the strength you need and throw them up. It would save you cash, even overspending on the beam. The beams are not much $$$. They suspend crazy things with them over long spans so while I don't know your space I suspect it would be sufficient. Excess wins! Look for "LVL" (Laminated Veneer Lumber) beams or ask your local lumber yard for an engineered beam and explain what you are doing they can get you a quick quote. I've seen some really huge home with long spans get held up by stuff like that so I'd be confident in it's ability. Especially over a short span.
Mfusick is offline
Old 07-31-2014, 07:07 PM
Quoted: 3269 Post(s)
Liked: 2751
here is the wall in question and unfortunately the soffit obsures the view. All of the ceiling joists which end at the stair well sit on the wall, two additional short joists at the top of the stairs are hidden from view. they sit directly above the double studs on the right side of the door way. In retrospect that wall probably should have additional cross blocking given the number of joists resting on it.
We want to widen that doorway. It is currently only large enough for a 24 inch door and not big enough to remove the water heater from the basement. I think we can put an appropriate size header spanning the wider door, but I'm not going to make the structural determination.
The surgery required isn't going to be a cake walk as the under stairs area is drywalled and the then there is the existing soffit framing on this side.
Old 07-31-2014, 07:26 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2686
Oh I see. Nice pic. I agree with you on making the determination. It's once thing if a home owner decides something, but I wouldn't do it in your shoes either.
I can't really see past the soffit but I am assuming this is all on the other side of that soffit ? (how do you spell "soffit" ?)
Jeff, are you doing this work or is this being subbed out ?
Mfusick is offline
Old 07-31-2014, 07:32 PM
Liked: 2751
Beast and I will probably do it once we have a consultants plan.
Old 08-01-2014, 01:39 PM
xzener's Avatar
Quoted: 30 Post(s)
Liked: 38
Beast, do you recall the product name of the lense you bought from Edmonds Optics for your hushbox?? I am building one and am having trouble finding that product on their website. Thanks.
xzener is offline
Old 08-01-2014, 03:17 PM - Thread Starter
Liked: 1149
Yup! 'Tis correct! We'll see what happens though. CEDIA will let me know quite a bit!
Sure, here it is: http://www.edmundoptics.com/optics/w...windows/43-973
Old 08-01-2014, 05:26 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2686
Where is your build thread?
Mfusick is offline
Old 08-01-2014, 07:38 PM
xzener's Avatar
Quoted: 30 Post(s)
Liked: 38
Shhh... Mfusick... It's a secret. You never saw me here.
xzener is offline
Old 08-01-2014, 07:40 PM
xzener's Avatar
Quoted: 30 Post(s)
Liked: 38
Thanks Beast, this will come in handy.
xzener is offline
Old 08-01-2014, 07:44 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2686
lol. I was expecting you to say the Mediabrowser forums.
Mfusick is offline
Old 08-02-2014, 08:19 PM - Thread Starter
Liked: 1149
Playing around with riser design. A single rectangular riser just won't do. Any thoughts on the steps (or anything else regarding the riser)?
Old 08-03-2014, 12:09 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2686
Cool idea. A tad dark to see. Lighten it up.
One thought is the curve ends too soon so if your are entering the second row from the side you end up taking a double step. Continue the curve a little farth back so the step is on the side too.
REEDZONE had a nice riser design. Ever seen it ?
Mfusick is offline
Old 08-03-2014, 09:00 PM - Thread Starter
Liked: 1149
Great advice! I'll work on the riser design (and lighten up the pic tomorrow). I haven't heard of the reedzone riser....ill need to search for that,
Old 08-03-2014, 09:07 PM - Thread Starter
Liked: 1149
Today was spent doing HW from Big: digging-in on the drywall between joists operation. Got the first layer drywall pieces cut today....that was tough, but not as tough as the second layer will be. tomorrow the Mrs. and I will be loading green glue onto these dusty rectangles and attsching layer one to the subfloor. All of layer 2 won't get done this week, but the perimeter will have two layers for framing purposes, amd I'll work on the middle of the ceiling after next Sunday's activity.
Old 08-04-2014, 07:41 AM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 81 Post(s)
Liked: 126
i remember doing that also ...you look at and think ah this will be nothing will get it done fast....Wrong!!!
snickers1 is offline
Old 08-04-2014, 07:56 AM
TMcG's Avatar
Quoted: 1075 Post(s)
Liked: 877
I HATED doing this part of the project in my theater. Good luck to you!
snickers1 likes this.
TMcG is offline
Old 08-04-2014, 08:27 AM - Thread Starter
Liked: 1149
lol, man, although I expected the tedium associated with the task, I didnt anticipate just how long it would take. And after layer one, we get to do it all over again! Lol....but hey, I view these challenges as rites of passage! I'm not the first, and I shan't be the last.
I totally understand the hatred behind the task! It's makes a person think things like "one or two footfalls from above wouldn't be thaaaaat bad." Lol....but then I remember the "TURN-IT-DOWN!" horror stories, and I keep pushing forward!
BllDo likes this.
Old 08-04-2014, 10:07 AM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 81 Post(s)
Liked: 126
be careful around your sprinklers and make sure when you get them lowered your there to watch the work be done ..my friend has started his theater and is doing clips and channel and two layers of DW so the sprinkler obviously needs to be lowered. the guy came out broke a pipe panicked cut a nasty whole in the adjacent bathroom ceiling to fix his mistake...needless to say the sprinkler head work was done for free ..... tips though the cost should be 100$ and hour min 2 hours and if you have 3 to 4 heads in your space he should be done within 1.5 hours if they know what there doing. I will not recommend the guy my friend used to you for the obvious reasons .... just thought you maybe happy to hear that this modification to your room should not cost you a small fortune. also if they are nice they will give the cups that go around the sprinkler heads.
Old 08-04-2014, 10:11 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2686
Is sprinkler system required as code in a basement? Or is this just a premium option ? Seems like sprinklers spraying your gear and carpet is as much a detrimental threat as a real fire. In the event of a small house fire would an activated sprinkler system and the damages from that be covered by insurance?
Reddig likes this.
Mfusick is offline
Old 08-04-2014, 10:43 AM
TMcG's Avatar
Liked: 877
Yeah, just put in a Halon fire suppression system....it would probably only cost as much as your entire house!
TMcG is offline
Old 08-04-2014, 11:03 AM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 81 Post(s)
Liked: 126
its code for Maryland no way getting around it .... also they have strict rules on there spacing.
Old 08-04-2014, 11:05 AM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 81 Post(s)
Liked: 126
and i think those systems are usually used in server farms and are under the raised floors? but yep $$$$$$$$$$
Old 08-04-2014, 11:28 AM - Thread Starter
Liked: 1149
Maybe I can just attach weights to the handles of fire extinguishers and suspend them by a melt-ready cable. Heat melts the cable, weight swings against handle, fire extinguishers put out fire. Wait....this started as a joke, but now it sounds like I'm actually thinking this through. Stop me, somebody!
A bit cave-man-esque, to be sure. Of course, there's lots more to do in the town of bedrock...like invent a circular device capable of rolling and, when used in conjunction with others of its type, carrying carts and humans.
Old 08-04-2014, 12:34 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2686
Or let your house burn...
Mfusick is offline
Old 08-04-2014, 12:36 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2686
You guys have a lot of fires or something? That's not around here. It doesn't seem like house fires are very common either. I almost never hear of any.
Reddig likes this.
Mfusick is offline
Old 08-04-2014, 12:57 PM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 81 Post(s)
Liked: 126
Its a Maryland thing , I'm in Virginia... not sure why they have that rule/code there you would think it be something for California where there are a lot brush fires and stuff.
Old 08-04-2014, 01:23 PM
BllDo's Avatar
Quoted: 575 Post(s)
Liked: 373
They were trying to push it through it Minnesota. I think the bill finally died, thankfully.
Reddig likes this.
BllDo is offline
Lumagen , Triad , Seaton Sound , Triad Inwall Gold 6 Lcr
