advice on building a wall. - AVS Forum | Home Theater Discussions And Reviews
Old 11-18-2013, 09:16 PM - Thread Starter
robc1976's Avatar
Quoted: 137 Post(s)
Liked: 87
Hi all!
Been a while since I posted. Well I moved and I am putting together my theater. The new house has the theater under the garage so there is concrete above the theater, to the right, front wall (actually has storage hall there I am going to use to put amps in wall and have access to all equipment in wall). The rear wall is also concrete in is actually custom built since prior owner used this room as a band room. Only thing is I need to put up one wall and want it to be as insulated as possible so sound won't travel (well keep it to the minimum) pretty hard to tame a 11.2 system with 2 15's. Sound panels I know how to do, all panels are GIK acoustics with bass traps, diffusers, 242 panels Ect. I just need advice on what to tell my contractor on how to build this wall, never done it before lol!
Klipsch RF82II Fronts & Wides
Klipsch RC64II Center
Klipsch RB61II Heights & Surrounds
2X Elemental design 15" subs W/ O-audio amps
Denon 4311ci
2X Emotiva XPA-5
Samsung D8000 64"
Denon 3313 UBD
Full GIK treatments
New theater under construction!
robc1976 is offline
Old 11-19-2013, 04:35 AM
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 139
Some good reading here. Most, if not all, of the soundproofing practices used in home theater builds are discussed in the Soundproofing 101 section of that website.
Spaceman is offline
Old 11-19-2013, 07:19 AM - Thread Starter
robc1976's Avatar
Quoted: 137 Post(s)
Liked: 87
Thank you. Great read!
Denon 4311ci
2X Emotiva XPA-5
Samsung D8000 64"
Denon 3313 UBD
Full GIK treatments
robc1976 is offline
