Dead HDMI cable run! - AVS Forum | Home Theater Discussions And Reviews
Old 11-19-2013, 09:52 AM - Thread Starter
lithiumus's Avatar
So I finished my basement home theater and was slowly getting things up and running... when I fired up my receiver and PJ I got no signal to the PJ. After a lot of testing I discovered that my Monster Cable 1000HD Ultimate cable run from the PJ room to my equipment room is dead. I did the run and I am certain that from opening the new package until the install, it was carefully strapped and installed. I should have done testing prior to install as it could be a bad cable but now all the ceilings and walls are done...
Not sure what my options are at this point. I'm going to get an HDMI cable tester to see if at least most of the wires are intact. Pulling another cable would be an absolute disaster but might be my only option. Even if most of the wires are intact, if one are 2 are cut or bad, there is no hope right? The connectors look fine... mad.gif
lithiumus is offline
Old 11-19-2013, 02:33 PM
Johnsteph10's Avatar
Quoted: 31 Post(s)
Did you run it in a conduit or an area where you can fish a new cable?
John
Johnsteph10 is offline
Old 11-19-2013, 04:51 PM
Quoted: 3255 Post(s)
Liked: 2743
did you run at least one cat 5e or cat 6 wire to the projector? if so HDbaseT adapters may be in your future.
Old 11-22-2013, 10:12 AM - Thread Starter
lithiumus's Avatar
Unfortunately, no conduit and no cat5e or cat6.
Looks like ill need to abandon that cable and fish a new one. Ill run a couple of cat 6 while im there and a mini phono for any remote control ir blasters etc.
Thanks anyway guys... Sad face...
Old 11-22-2013, 10:47 AM
Liked: 2743
there are wireless HDMI adapters, some work in some circumstances.
Old 11-22-2013, 11:43 AM
jbcain's Avatar
Liked: 64
This. My Epson 5010e had a wireless hdmi link. It did fairly well until I introduced multiple walls.
jbcain is offline
Old 11-22-2013, 01:26 PM
thrillcat's Avatar
Quoted: 172 Post(s)
Liked: 233
Is it run in a way that you could tie-off one end of the new cables to it, then pull them through by pulling the dead cable out?
I love my iPhone, but it will never replace my turntable.
The Cinema 1858 Remodel Thread
thrillcat is offline
Old 11-25-2013, 08:30 PM - Thread Starter
lithiumus's Avatar
Im going to look into this. Its only 2 drywalls separating the two units but generally, im not fond of wireless...
Old 11-25-2013, 08:39 PM - Thread Starter
lithiumus's Avatar
No. I strapped the cable down every 1-2 feet so thats a no go, plus it wasnt a straight shot and snakes through joist holes and around studs. I would have done a conduit if it was a straight shot...
Old 11-26-2013, 09:00 AM - Thread Starter
lithiumus's Avatar
Given the cost and performance, ill run another cable instead...
Monster Cable 1 Meter 1000hd Ultra High Speed Hdmi Cable
