Speakers Distance from Treated Wall; how close is OK? - AVS Forum | Home Theater Discussions And Reviews
Old 12-05-2013, 04:00 PM - Thread Starter
Oldstate's Avatar
I am currently planning out acoustic treatments for my semi-dedicated HT.
My 128" CIH screen has forced me to place my L/R speaker within 12" of the side wall. I am going to treat this area and was thinking of going with 4" panels.
Will this be an issue or do the panels essentially remove the boundary effect of the wall?
Oldstate is offline
Old 12-05-2013, 05:32 PM
HopefulFred's Avatar
Quoted: 490 Post(s)
Liked: 422
I think you're making a good choice.
HopefulFred is online now
Old 12-05-2013, 06:08 PM - Thread Starter
Oldstate's Avatar
So your saying there is no issue having speakers 6 to 8" from the acoustic panels?
Oldstate is offline
Old 12-05-2013, 06:42 PM
Quoted: 490 Post(s)
Liked: 422
The distance between the loudspeaker and the treatment is not relevant to any consideration I've ever heard of - assuming the treatment isn't in front or something, obviously.
The distances that matter are the distance from the speaker to the natural boundary (wall, etc.) and the thickness of the treatment. The distance between the speaker and the wall determines (basically) the frequency of the null created by the interference of the reflected sound. The thickness of the treatment should be adequate to absorb as much of the sound energy at that frequency as possible. Without doing all the math, and making a judgement call based on my own inexperience, I think you're okay.
Old 12-06-2013, 06:54 AM - Thread Starter
Oldstate's Avatar
Ok. Thanks. The more I research on room treatments the more things I uncover that I didn't even think would play a roll. I just want to make sure I'm not missing something.
Oldstate is offline
