Roxul "safe and sound" the same as "comfort Batt" - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By BIGmouthinDC
post #1 of 18 Old 12-06-2013, 12:17 AM - Thread Starter
robc1976's Avatar
Quoted: 137 Post(s)
Liked: 87
Having a contractor build my wall to My theater and the insulation had 2 different pkgs do I asked him and he says it's the same...it is just a marketing scheme.
He has "safe and sound" and "comfort batt" (thermal installation). He has 2 pkgs of safe and sound and 6 pkgs of comfort Batt.
Are these the same? The look almost identical?
Klipsch RF82II Fronts & Wides
Klipsch RC64II Center
Klipsch RB61II Heights & Surrounds
2X Elemental design 15" subs W/ O-audio amps
Denon 4311ci
2X Emotiva XPA-5
Samsung D8000 64"
Denon 3313 UBD
Full GIK treatments
New theater under construction!
robc1976 is offline
post #2 of 18 Old 12-06-2013, 04:54 AM
memmo's Avatar
Quoted: 76 Post(s)
Liked: 66
I believe Safe and Sound is a bit more dense and since Roxul markets the Safe and Sound as an interior sound + fire proofing product, they don't publish any thermal specs for it. Comfort Batt on the other hand clearly states R14. Obviously the Safe and Sound has some r value, how much I'm not sure.
The Big Bay Home Theater Build Thread
My personal theater build on Kempenfelt Bay, Barrie Ontario Canada
memmo is offline
post #3 of 18 Old 12-06-2013, 10:08 AM
ithunter's Avatar
check this out...
here and here
I used "safe and sound" in the ceiling and walls of my theater.
ithunter is offline
post #4 of 18 Old 12-06-2013, 10:58 AM - Thread Starter
robc1976's Avatar
Quoted: 137 Post(s)
Liked: 87
Originally Posted by ithunter View Post
check this out...
here and here
so from reading that it seems safe and sound is actually different than the other. I am using it on one wall double staggered stud with 2 layers of the 1/4" sheet of drywall with gel in between another 1/4" so basically 1" of drywall with 2 layer of gel on one side and 1/2" with gel on other. The other walls on ceiling are concrete. Ceiling is 19" thick lol! Walls are 12" thick concrete.
Denon 4311ci
2X Emotiva XPA-5
Samsung D8000 64"
Denon 3313 UBD
Full GIK treatments
robc1976 is offline
post #5 of 18 Old 12-06-2013, 01:22 PM
ithunter's Avatar
I put it directly behind 5/8" drywall on the walls and laid it in the joist space of the ceiling covered by fabric panels and cheated by using it in the void of the seating riser. I think you will be happy with the choice.
ithunter is offline
post #6 of 18 Old 12-06-2013, 01:54 PM - Thread Starter
robc1976's Avatar
Quoted: 137 Post(s)
Liked: 87
my contractor is saying they sure the same product...S&S are the same as the "comfort batt" they look identical but according to Roxul are not even that close but are made of similar material.
Denon 4311ci
2X Emotiva XPA-5
Samsung D8000 64"
Denon 3313 UBD
Full GIK treatments
robc1976 is offline
post #7 of 18 Old 12-06-2013, 02:06 PM
Quoted: 3254 Post(s)
Liked: 2743
Doesn't it give you cause for concern when your contractor is either stupid or a liar.
JRock3x8 likes this.
post #8 of 18 Old 12-06-2013, 02:26 PM - Thread Starter
robc1976's Avatar
Quoted: 137 Post(s)
Liked: 87
Big time! Main reason I made this thread.
Denon 4311ci
2X Emotiva XPA-5
Samsung D8000 64"
Denon 3313 UBD
Full GIK treatments
robc1976 is offline
post #9 of 18 Old 12-06-2013, 02:54 PM
Swervepf's Avatar
Quoted: 38 Post(s)
Liked: 31
So many, and perhaps most, unfortunately are. A few weeks ago, I had a drywaller tell me the Certainteed ProRoc Easi Lite he was hanging in my bathroom wall shared with a bedroom to be 'the standard weight stuff' to which I said it's not, and that I wanted the regular, heavier weight drywall, as the objective was to reduce sound transfer from the bathroom to the bedroom with the double drywall and green glue assembly I asked him to install. He again stated that this was the standard, and that there was lighter stuff that he doesn't use. I let him know that I've bought, hauled, and hung enough sheetrock to know the difference and that it was clearly labeled as 'Easi Lite' on the sheetrock. He simply said, 'it's still heavy' which pretty much summed up why it was going up in my bathroom. Annoyed, but wanting to have my bathroom done sooner rather than later, and as him stopping work, going to the supplier, and charging me all the way for his additional time and additional materials, I let him carry on. Now I've got a 30% lighter than desired DD&GG assembly in there.
Roxul SS and CB are similar but not the same. They're okay in the other's intended purposes however, and further, insulation isn't terribly important. You can use any readily available insulation really with very similar results. Other factors to SP are far more important. Check out soundproofingcompany.com to take the course soundproofing 101.
Swervepf is offline
post #10 of 18 Old 12-06-2013, 03:23 PM
Liked: 2743
Yes the net difference on the project is probably not measurable between the different insulations, my point is that it is irritating that many contractors think their clients are idiots and should believe what ever they tell them. On the drywall, one of my drywall suppliers can no longer get heavyweight 1/2 drywall. It is all light crap. Still has the heavy weight 5/8 but heads up, light weight 5/8 is already in the supply chain and you need to be careful.
post #11 of 18 Old 12-06-2013, 03:39 PM
Swervepf's Avatar
Quoted: 38 Post(s)
Liked: 31
Yup, and I'd say it's only a matter of time until they start marketing the regular stuff as 'heavy weight, 30% denser, soundproofing' etc, at a new price point which will be at a premium to the light weight stuff. Marketing is some powerful stuff.
Swervepf is offline
post #12 of 18 Old 12-06-2013, 04:46 PM - Thread Starter
robc1976's Avatar
Quoted: 137 Post(s)
Liked: 87
agreed, he knows I am not a newby to home theater, he had to help move all the panels, gear ect...makes me wonder if his crew just picked up the wrong stuff. Below is a pic of stuff he got S&S in Brown and comfort batt in blue.
What are the thoughts on the drywall I am using? It is (2) 1/4" sheets with gel in between abs he is double layering it on theater side and single layer on other side.
20131206_164248.jpg 192k .jpg file
Denon 4311ci
2X Emotiva XPA-5
Samsung D8000 64"
Denon 3313 UBD
Full GIK treatments
robc1976 is offline
post #13 of 18 Old 12-06-2013, 06:24 PM
Liked: 2743
They ran out of S&S, the Roxul website lists the density of the two materials One is 2.5 lbs per cu ft, the other is 2.0 (From memory)
I hope you are kidding about the 1/4 inch layers You need two layers of 5/8 firecode with Green Glue between layers if you are going for sound containment.
post #14 of 18 Old 12-06-2013, 11:22 PM - Thread Starter
robc1976's Avatar
Quoted: 137 Post(s)
Liked: 87
it will be over 1-1/2"ofdry wall with gel when all together. I know it will be weakest spot since ask other walls including ceiling is concrete.
Denon 4311ci
2X Emotiva XPA-5
Samsung D8000 64"
Denon 3313 UBD
Full GIK treatments
robc1976 is offline
post #15 of 18 Old 12-06-2013, 11:35 PM - Thread Starter
robc1976's Avatar
Quoted: 137 Post(s)
Liked: 87
so 1/4" then gel, 1/4" then 1/4" gel 1/4" won't be enough? Same on other side. Staggered stud wall ect. If not I will adds more.
I am using #525 quite rock drywall.
Denon 4311ci
2X Emotiva XPA-5
Samsung D8000 64"
Denon 3313 UBD
Full GIK treatments
robc1976 is offline
post #16 of 18 Old 12-07-2013, 06:09 AM
Liked: 2743
More information needed, I don't know your overall soundproofing strategy for the walls, ceiling and floor. Are you using any isolation methods or just drywall and hair gel? As I said normally we want the mass of two layers of 5/8 on the theater side and at least one 5/8 on the outside. Drywall should be hung on a clip and channel isolation system.
post #17 of 18 Old 12-07-2013, 06:51 PM - Thread Starter
robc1976's Avatar
Quoted: 137 Post(s)
Liked: 87
More information need, I don't know your overall soundproofing strategy for the walls, ceiling and floor. Are you using any isolation methods or just drywall and hair gel? As I said normally we want the mass of two layers of 5/8 on the theater side and at least one 5/8 on the outside. Drywall should be hung on a clip and channel isolation system.
the ceiling is 24" of concrete (room is under a floating garage floor). Right wall is concrete, rear wall is concrete with doors to theater. The door way is 2 solid core doors (studio room style) front wall is also concrete with a, wall built 5' in front of it (this where fear is out into wall and I have access to rear. Left wall is what I had made 2X6 staggered stud and door way goes to sitting room (also double doors like studio).
Drywall is 1/4" quite rock put together with quite putty ("gel") to another 1/4" sheet so essentially 1/2" and I will have 2 layers of this so 1" mass. I need this up quick or I would put green glue between the sheets (none locally and they are hanging drywall Monday).
Denon 4311ci
2X Emotiva XPA-5
Samsung D8000 64"
Denon 3313 UBD
Full GIK treatments
robc1976 is offline
post #18 of 18 Old 12-07-2013, 07:01 PM - Thread Starter
robc1976's Avatar
Quoted: 137 Post(s)
Liked: 87
Also, it is actually about 5/8" thick. Here is the link to it.
http://m.lowes.com/pd_98765-89477-500_4294864808__?productId=3069747&Ntt=-1'&pl=1&currentURL=%3FNtt%3D-1%2527&facetInfo=
Denon 4311ci
2X Emotiva XPA-5
Samsung D8000 64"
Denon 3313 UBD
Full GIK treatments
robc1976 is offline
