My "Dragon Nest" Theater - AVS Forum | Home Theater Discussions And Reviews
 8Likes
Old 12-06-2013, 10:19 AM - Thread Starter
fbuzila's Avatar
Hello everybody,
after 1 year of reading this forum I finally started to build my dedicated Home Theater.
So let's start:
Inspiration: http://img.gawkerassets.com/img/18h6u2w5xc3sdjpg/original.jpg
If you are wondering how will I build the cave walls please see here: http://laurafrancisart.blogspot.com/2011/06/cave-days-6-to-11.html
I already practiced at a lower scale:
Room (in basement):
Room size (without the double walls): 17' x 29 ' x9'
Walls: I will build double walls for a real separation from the rest of the home, including separated ceiling joists
http://www.soundproofingcompany.com/soundproofing101/room-within-a-room/ (no furring channels or clips)
I just started the framing yesterday: *
Sound proofing: double walls, double drywall with Green Glue between.
All other components are still under research...I will add more pictures while I progress...this will take a while to complete smile.gif
fbuzila is offline
Old 12-06-2013, 10:31 AM - Thread Starter
fbuzila's Avatar
For doors I'm considering 2 communicating exterior doors, solid core of course.
For lighting Grafik Eye(4 or 6 zones...not sure yet)
Sound receiver: http://www.amazon.com/dp/B0092KZCKC/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=2E0149Q44KJTB&coliid=I3U6IG778LZWVD
I will pre-wire for 11.2
Screen (with fake wall to hide the front speakers): http://www.amazon.com/Elite-Screens-R135WH1-A1080P2-ezFrame-Projection/dp/B007PM99B2/ref=sr_1_6?s=tv&ie=UTF8&qid=1363789646&sr=1-6&keywords=acoustic+screen
fbuzila is offline
Old 12-11-2013, 05:47 PM - Thread Starter
fbuzila's Avatar
some progress on framing...*
fbuzila is offline
Old 12-13-2013, 01:29 PM
Dradius's Avatar
Uh... this is going to be an extremely interesting build. The bat cave theater is one of my all-time favorites. Good luck!
Dradius is offline
Old 12-14-2013, 06:02 PM - Thread Starter
fbuzila's Avatar
started on ceiling joists...
j051499 likes this.
fbuzila is offline
Old 12-15-2013, 02:31 AM
Nightlord's Avatar
Quoted: 712 Post(s)
Liked: 237
Papier mache? I've made my diffusers out of that. Have considered doing walls like yours too, but decided it would be too big project for me. Best of luck.
Under construction: the Larch theater
Nightlord is offline
Old 12-16-2013, 07:18 AM - Thread Starter
fbuzila's Avatar
Yes, papier mache and then 2 layers of good paint.
fbuzila is offline
Old 12-16-2013, 08:12 AM - Thread Starter
fbuzila's Avatar
and the last wall framed...
fbuzila is offline
Old 12-24-2013, 07:54 AM - Thread Starter
fbuzila's Avatar
Wiring in progress. The good part about cave walls is I can use surface mounted electrical boxes, so no cutting in ceiling or walls.
The boxes will be hidden after I finish the "paper mache" cave walls.
fbuzila is offline
Old 12-24-2013, 09:24 AM
Yzfbossman's Avatar
Quoted: 44 Post(s)
Liked: 75
Looking forward to following your build!
Here is my build thread:
---->Like a Boss Theater Build<----
Yzfbossman is offline
Old 12-30-2013, 03:33 PM - Thread Starter
fbuzila's Avatar
I'm reconsidering the "paper mache" after I've read this forum. http://www.halloweenforum.com/tutorials-step-step/69755-haunted-cave-5.html
This guy used foam and it looks very well. http://www.tigerfoam.com/
Probably I will use open-cell foam for side walls up to 4-5 feet and closed-cell foam for the rest and ceiling...
fbuzila is offline
Old 01-14-2014, 12:17 PM - Thread Starter
fbuzila's Avatar
short update:
I finished the wiring and ordering the fiberglass insulation and 2 exterior doors....
fbuzila is offline
Old 01-16-2014, 03:33 PM - Thread Starter
fbuzila's Avatar
new delivery smile.gif[ *
fbuzila is offline
Old 01-19-2014, 01:07 PM - Thread Starter
fbuzila's Avatar
and the door is installed (almost)
fbuzila is offline
Old 01-19-2014, 01:08 PM - Thread Starter
fbuzila's Avatar
started on insulation
fbuzila is offline
Old 01-19-2014, 01:27 PM
TMcG's Avatar
Quoted: 1072 Post(s)
Liked: 870
TMcG is offline
Old 01-21-2014, 07:12 AM
cw5billwade's Avatar
Quoted: 328 Post(s)
Liked: 184
cw5billwade is offline
Old 01-21-2014, 07:48 AM
AirBenji's Avatar
Quoted: 35 Post(s)
Liked: 83
Very impressive so far - looking forward to seeing this come together! Good luck!
AirBenji is offline
Old 01-21-2014, 10:43 AM - Thread Starter
fbuzila's Avatar
Thanks guys!
Btw, installing fiberglass insulation between ceiling joists is not fun mad.gif but I know it will pay off....
fbuzila is offline
Old 01-21-2014, 01:42 PM
JVoth's Avatar
Quoted: 261 Post(s)
Liked: 124
JVoth is offline
Old 01-21-2014, 01:46 PM
blipszyc's Avatar
Quoted: 134 Post(s)
Liked: 72
5/8" drywall is even worse. tongue.gif
Visit the Lipszyc Home Theater! 1.0
2.0 done and finally posted! - Theater 2.0
And now...The Queen City Theater (3.0)
blipszyc is offline
Old 01-21-2014, 01:55 PM - Thread Starter
fbuzila's Avatar
That's why I'm looking for someone to "help" me with insulation and drywall smile.gif
I just realized how heavy is 5/8" drywall smile.gif
fbuzila is offline
Old 01-21-2014, 02:43 PM
Quoted: 328 Post(s)
Liked: 184
Rent the Drywall lift from Home Depot best $35 I ever spent. Especially since my first layer was OSB
Old 01-27-2014, 03:53 PM - Thread Starter
fbuzila's Avatar
Found this lift on Amazon at $150.
If I use it few weeks and sell it when done with $100 on Craigslist is better than renting smile.gif
http://www.amazon.com/dp/B000ZIEOHW/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=2E0149Q44KJTB&coliid=ID2QWIUISLSW9
fbuzila is offline
Old 01-27-2014, 03:54 PM - Thread Starter
fbuzila's Avatar
Almost done with insulation:
fbuzila is offline
Old 01-29-2014, 02:40 PM - Thread Starter
fbuzila's Avatar
Insulation done...drywall and green glue is next...
fbuzila is offline
Old 01-29-2014, 03:34 PM
TMcG's Avatar
Liked: 870
Nice progress. Are you using decoupling clips as well?
TMcG is offline
Old 01-29-2014, 03:40 PM
AlphaG's Avatar
Quoted: 37 Post(s)
Liked: 32
Looking forward to seeing the cave part of this build ...
AlphaG is offline
Old 01-29-2014, 03:57 PM - Thread Starter
fbuzila's Avatar
No clips...free stranding room in a room including separate ceiling joists.
fbuzila is offline
Old 01-30-2014, 01:57 PM - Thread Starter
fbuzila's Avatar
I just ordered 90 panels of 5/8 drywall smile.gif
This forum helped me to understand that local drywall companies delivering directly to your basement is better than Lowe's or HomeDepot ...it saved me a lot of work (that drywall is very heavy)
And the price is the same....
fbuzila is offline
