Erskine Group not the best choice for a sub 100k home theatre... - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 21Likes
post #181 of 219 Old 01-05-2014, 02:52 PM
TMcG's Avatar
Quoted: 1156 Post(s)
Liked: 988
Originally Posted by mads1 View Post
I was planning a seymour XD curved screen (1.2 gain).. - could i use a different screen with higher gain to improve image brightness?
The only higher gain AT screen of equivalent or higher quality is the Stewart Filmscreen Studiotek 130 G3 Microperf which is THX and ISF certified and has a 1.3 gain. Hold on to your wallet, though, if you go this route.
TMcG is offline
post #182 of 219 Old 01-05-2014, 02:56 PM
rcohen's Avatar
Quoted: 1377 Post(s)
Liked: 604
Here is my understanding:
Studiotek 130 Microperf is about 20% brighter than XD.
They also have a new 150 with a 1.5 gain.
A high power screen give incredible 3D images with that projector, size, and throw distance, but the 2D images will be too bright without closing the iris more or using an ND filter.
rcohen is offline
post #183 of 219 Old 01-05-2014, 03:05 PM
TMcG's Avatar
Liked: 988
Ft. lamberts are a measurement of reflected light brightness, so it is incorrect to strictly say something will be "too bright" since it is inferred that you will be calibrating your projector for optimal picture quality. The higher gain allows for a larger screen with the same lumen output and/or the ability to put the projector in eco mode (low) instead of "flame thrower" mode to meet reference standards.
Stewart has even higher gain screens than the 1.5....but I also qualified my remarks as "equivalent or higher quality" which, in my opinion and that of other professionals, is not up to the same picture quality standards as the 130 G3. Quite simply, the 150 is prone to hot spotting and "sparklies" from the even higher contrast coating.
The gain rating for the Seymour Center Stage XD is 1.16. Many have measured this to be just over 1.04 in real life testing. Stewart's 1.3 rating is fairly accurate, accounting for the approximate 20% difference in brightness between the two screen materials.
TMcG is offline
post #184 of 219 Old 01-05-2014, 03:09 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 961
Just to note......Seymour XD is a negative gain screen and has been tested by respected calibrator as such.......think 0.90 gain.
While the Stewart noted is only true positive gain screen, still lose light due to perfs. From what I can recall price wise, the Stewart 130 mp was 15% more than Seymour-SE 4k screen.
For what it's worth, I could see hole structure at 11-12 ft on Stewart material and didn't want to risk annoying perfs and problems with HF reduction......
doublewing11 is offline
post #185 of 219 Old 01-05-2014, 03:14 PM
rcohen's Avatar
Liked: 604
While the Stewart noted is only true positive gain screen, still lose light due to perfs. From what I can recall, the Stewart 130 mp was 15% more than Seymour-SE 4k screen.
How does microperf look at 14 ft? Is this more of a concern on a 4k projector?
Also, I thought XD was higher gain than the SE 4k.
When testing with samples over black paper, the XD appeared a bit brighter than 1.0 screens and much brighter than the other "4k" weave screens I tested.
I don't have a light meter, though.
rcohen is offline
post #186 of 219 Old 01-05-2014, 03:25 PM
Quoted: 229 Post(s)
Liked: 961
Yes, the XD is noticeably brighter........S-SE 4k was measured at 0.80 which was a MAJOR concern for me. With throw of close to 17 ft on my 1000ES, I find the picture thrown bright enough on 12ft scope 4k screen. Now I don't have the fancy equipment to verify, but Jeff Meyers from AcuCal does........and he stands by his numbers ie. 0.90 gain on XD.
14 ft would be fine for me......my eyes........but you really need samples and test for yourself.
post #187 of 219 Old 01-05-2014, 04:26 PM
TMcG's Avatar
Liked: 988
Seymour XD is not a negative gain screen. Here is a link to their website where they actively promote 1.2 gain. http://www.seymourav.com/screens.asp Not sure how this was measured, but I am confident that they wouldn't put themselves in a position of false advertising. That being said, most of the official calibration reports I have seen show just over a 1.0 gain which is exactly what Seymour states as the "unbenchmarked gain" figures further below.
The Enlightor 4K is a negative gain screen, but just barely. at 0.98. Here is a comparison of all their 4K materials: http://www.seymourscreenexcellence.com/materials.asp These are fully ISF tested, so the again information can be relied upon.
I know Jeff at Acucal is an experienced calibrator, but there must be something askew to have numbers that low.
TMcG is offline
post #188 of 219 Old 01-05-2014, 04:52 PM
Quoted: 229 Post(s)
Liked: 961
Don't have the equipment to verify nor the expertise to do so.......therefore if an experience calibrator measures such values, I'm more prone to believe them than manufacture data...........
I've tested Stewart 100 material and compared to S-SE 4k material and to my untrained eye, the Stewart material was significantly brighter.............just saying.
With that said, I use S-SE 4K screen..........
post #189 of 219 Old 01-05-2014, 04:57 PM - Thread Starter
mads1's Avatar
Liked: 45
I'm actually looking at a very similar setup, although I'm leaning toward a flat screen.
What made you decide on curved? Are you using an a-lens? Which one?
A-lenses are a bit complicated on those projectors.
With a 4k signal, they won't do the a-lens stretch without external scaling.
With a 2k signal, they will do the stretch, but there isn't a significant brightness gain, due to the change in zoom and the projector's aspect ratio.
I came to the conclusion that due to the specific Sony issues, no lens was cheaper, much simpler, and a bit better quality.
A higher gain screen means tradeoffs.
You'd have to go to a microperf screen.
I've never seen either full size first hand. I'm just going by what I've read.
XD is the highest gain weave.
The microperf screens create audio concerns, particularly with a curved screen.
There is a decent amount of extra cost and complexity in order to buy the screen and combat that stuff.
Also, apparently microperf pattern is more visible than the weave.
Anyway, I'm leaning toward flat XD 140" 2.35. As long as 3D is 16:9 and not using an a-lens, I think I'll have okay 3D brightness, although not ideal. I'm sure that most of my viewing will be 2D, so I'm not terribly worried about it. It sound like the most practical alternative to that is actually using a separate projector for 3D. I guess I'll look into that if it's a major concern later (unlikely).
Were the 4x surrounds + 2x rears he was recommending dipole or monopole?
Since they are so close to the seats, it's possible that dipole would be good the feeling that the speaker is too close to you.
I got speakers that were switchable between dipole & bipole, and I found myself preferring bipole.
I had just heard that when using multiple sets that monopoles with controlled directivity was best.
I think dipoles are more prone to crazy cancellation problems than bipoles when using multiples.
I'm not an authority on this stuff, so perhaps someone could make a better recommendation.
The curved screen was what was specified by Erskine (Stewart microperf), they told me that it was to reduce the light reflection onto the front side walls by the screen. I think the curved screen looks better (in terms of room design/style) but no other reason. Could equally go with a flat screen if that helps.
I was planning on having a 16:9 screen to avoid the cost of the lens etc.
like you, the 3d is really for our daughter and her friends to watch kids 3d movies. i prefer to watch 2D.
the surrounds and rear's were all specified as the triad bronze/4 inwall surrounds which are dipole. i assume (?) that the triad gold onwall surrounds (old style) are also dipole but i dont know.
Erskine commented that the dipole speakers would create an illusion of distance to the speaker for the listener in terms of hiding the proximity and location of the surround sounds.
what is your projector to screen distance?
Mads
mads1 is offline
post #190 of 219 Old 01-05-2014, 05:05 PM
TMcG's Avatar
Liked: 988
It is highly unlikely that Chris Seymour would knowingly falsify gain data and subject himself to the ramifications of false advertising, don't you think? cool.gif
The Stewart screen at 1.3 gain should be much brighter than the Seymour 4K with a specified gain of 0.98. I was never contesting that point and in fact stated the Stewart's rated gain seemed very consistent at approximately 1.3 for all the calibrated images.
TMcG is offline
post #191 of 219 Old 01-05-2014, 05:26 PM
blazar's Avatar
Quoted: 730 Post(s)
Liked: 533
What is the precise throw distance and size of your screen?
Looks like 25 foot throw distance which will be problematic for about 90% of all decent reasonably priced home theater projectors.
I have a 21 foot throw distance and 170" screen and my roll down screen is not good enough with 1.0 gain with an epson powerlite 5000 series projector (a very good projector). 3D is out of the question and looks way too dim.
I did a 21 foot throw so i can build the projector into the back wall and it is acoustically and cosmetically more pleasing... But picture would have looked much nicer if the projector was overhead at like 15ft throw distance.
I looked through a TON of projectors and to get decent brightness i would now need to upgrade to a commercial grade projector or one made for daylight use with much worse contrast ratio.
You will likely have less of a problem since your screen size is not as large but still be careful.
Moral: be VERY careful with long throw scenarios and be sure brightness is very adequate, especially for 3D applications.
Blazar!
blazar is offline
post #192 of 219 Old 01-05-2014, 05:36 PM - Thread Starter
mads1's Avatar
Liked: 45
projector lens to screen approx 25ft6" (that is assuming curved screen etc. could probably be improved by 6" to 25ft exactly.
original screen size was 124" wide 16:9 screen, but i think with the widening of the room that could be extended to about 144" wide.
mads1 is offline
post #193 of 219 Old 01-05-2014, 06:59 PM
rcohen's Avatar
Liked: 604
Curved sounds like a reasonable call, since your screen will be close to the walls. There are a bunch of minor tradeoffs.
That's a good point about dipole due to speaker proximity. My speakers aren't as close, but I'm glad I got the bipole/dipole switchable speakers, since I ended up liking bipole better in my room. You can always turn the volume down a notch or two if you're not happy with the sound. I think the Triad surrounds are "tri-pole" types, which would probably work better, actually.
My understanding is that the Sony 4k projectors are a lot brighter than that Epson Powerlite in their good quality movie modes.
I agree that it wouldn't hurt to keep some flexibility to move the Sony closer. There's a pretty big difference in brightness at the min throw distance - perhaps 30-50%, with a spectrum in-between. The long throw distance, however, gives less barrel distortion on the curved screen, less hot spotting (probably not much of an issue for XD), significantly better contrast, and is quieter. Then, you've got the whole spectrum in-between. I'm not sure if it's practical to make that decision after the screen is up, but that would be ideal.
I'm going with a 2.35 screen because that most of what I watch, and I want to optimize height, size, and masking for that. Also, a 140" wide 16:9 image may be uncomfortably big. That's a personal taste thing, though. If you watch mostly 16:9 stuff, the opposite argument applies. You would want to tune height, size, and masking around that.
rcohen is offline
post #194 of 219 Old 01-05-2014, 07:32 PM - Thread Starter
mads1's Avatar
Liked: 45
i am hoping it works.. maybe the VW600es would do the same job too which is a good (read: cheaper) option.
Since the theatre will be a muted pallet of blacks and dark greys the light reflection shouldnt be such an issue with the screen either way. curved or flat. Since i have an 11ft ceiling at the screen i figured to put in the largest screen size then can play either 2.35 or 16:9 formats to maximum size. i can always make the screen smaller (or mask it) but i cant make it larger if i choose to go the other way.
Once the theatre it built maybe i will trial a sony vw600es and see how that looks, unless i stumble over a cheap vw1000 in the mean-time. i am really keen to keep the projector hidden in the hush box at the back of the room rather than have it in the ceiling in the room.
when are you starting your theatre?
Mads
mads1 is offline
post #195 of 219 Old 01-06-2014, 06:42 AM
Quoted: 229 Post(s)
Liked: 961
Sorry, just can't let dead dogs lie...........isn't this a thread for consumer?
Chris and you are both right..........yes, the material is most likely advertised gains....... But when light loss is factored in due to perfs, weave etc. I believe the actual light reflected off screen to viewers eye is way less than advertised.......remember good ole' Ronald Regan? " trust but verify"...........
I believe AcuCal numbers are correct and would like to post resource data from AcuCal.,...but I'm in a hurry and out the door. biggrin.gif
post #196 of 219 Old 01-06-2014, 06:47 AM
rcohen's Avatar
Liked: 604
Mads
I don't think the vw1000 and 600 differences are very big, based on what I have read.
I'm not sure when I'm starting. I'm trying, but it has been hard to find the time. I need a designer/builder.
rcohen is offline
post #197 of 219 Old 01-06-2014, 07:04 AM
TMcG's Avatar
Liked: 988
Yes, you can essentially kiss 10% of your light / brightness "goodbye" with any acoustically transparent screen. CenterStage XD has been measured many, many times to land in the 1.03 to 1.04 gain range with a real-life calibrated setup. But that doesn't mean the material itself does not have the 1.16 to 1.20 gain as an example of where some of the confusion may lie in this comment thread.
I was just surprised that Jeff was getting 0.9 for the XD and 0.8 for the 4k because that is WAY outside of what is to be expected.
TMcG is offline
post #198 of 219 Old 01-06-2014, 07:09 AM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 193 Post(s)
Liked: 154
Meters matter. Jeff has one of the best, most expensive ones. Jef does not sell nor promote equipment, I trust his data.
GetGray is offline
post #199 of 219 Old 01-06-2014, 07:32 AM
TMcG's Avatar
Liked: 988
Never doubted Jeff's talents or equipment, just surprised that his rating was so low and where the differences lie. Do you happen to know which piece of calibration equipment he uses? Sencore?
TMcG is offline
post #200 of 219 Old 01-06-2014, 07:51 AM
thebland's Avatar
Quoted: 1589 Post(s)
Liked: 926
I have had Jeff to my theater as well. Very professional, smart and loves what he does.
Goodbye to a great audio and video genius and writer... JOHN GANNON. I enjoyed your friendship, wit and a nice long run we took around Indianapolis at CEDIA years back... and for buying my Runco 980 Ultra years back... you saved my ass! Rest in peace.
thebland is online now
post #201 of 219 Old 01-06-2014, 08:04 AM
GetGray's Avatar
Quoted: 193 Post(s)
Liked: 154
http://www.accucalhd.com/isf-calibration.htm
GetGray is offline
post #202 of 219 Old 01-06-2014, 08:32 AM
adidino's Avatar
Quoted: 362 Post(s)
Liked: 277
+1 on Jeff. He's been to my home a few times. Very professional and knowledgeable.
adidino is offline
post #203 of 219 Old 01-06-2014, 12:24 PM
Randy Bessinger's Avatar
Quoted: 231 Post(s)
Liked: 195
me3 or 4. Very straight shooter.
Randy Bessinger is offline
post #204 of 219 Old 01-06-2014, 02:16 PM - Thread Starter
mads1's Avatar
Liked: 45
Simple/stupid question, if i make the screen larger i assume the projector needs more lumens to maintain the screen brightness.
I was looking at option of putting in a larger retractable screen (seymour AT) that could be close to wall to wall width (150 or 160 inch width) with masking for option of 2.35 image.
THat way when i need access behind the screen i can just retract it fully.
This is as an alternative to a xd fixed / curved screen about 130" wide. (my contractor thinks if i go any wider will have trouble getting behind the screen at all.
would there be issues in having virtually a wall to wall screen? i know light reflection onto the side walls is one problem. will the screen feel overbearing to those in the front row only 130" away from the screen?
Also a sony vw1000 or vw600 would maybe struggle to light up the larger screen?
thanks
Mads
mads1 is offline
post #205 of 219 Old 01-06-2014, 02:26 PM
Quoted: 3690 Post(s)
Liked: 3131
Screens are mounted with a French cleat system and held in place by gravity, I installed a Seymour curved screen and it was the same way (Curve frenzy thread) his screen came withing 3-4 inches of the side wall on both sides and getting the screen on and off was less than a 10 minute operation. You just need to be good at parallel parking. The curved screen did have two screws though brackets on the bottom part of the frame to hold the screen vertical.
I wouldn't opt for a retractable screen to provide better access to the speakers if someone gave me one for free. The frequency of access (almost never) doesn't warrant opening up the chance that the screen won't hang perfectly flat or the motor goes bananas.
mads1 likes this.
post #206 of 219 Old 01-06-2014, 03:48 PM
Johnsteph10's Avatar
Quoted: 31 Post(s)
Liked: 24
The vw1000 would light up 130 inches without any issues whatsoever. The vw600 is somewhat dimmer and may not look quite as "punchy" but it should do ok.
mads1 likes this.
John
Johnsteph10 is offline
post #207 of 219 Old 01-06-2014, 04:40 PM
Quoted: 229 Post(s)
Liked: 961
My 1000ES lights up my 0.80 gain S-SE 4K screen with ease.......after 500 hrs still as bright when first hung. Great projector...........
I watch college football with lights 50% on in room and projector is bright enough I have no desire to lower lights.........
post #208 of 219 Old 01-08-2014, 01:33 AM
dsiroky's Avatar
I used Erskine Group - was very happy with the result and finished it for far less than $100k. My biggest expense other than seats, were carpet ($5.8k), buying a surround sound processor and projector ($6.5k). Seats were $16k. I figure I spent around $40k all up on materials.
That said - I did everything DIY, except for laying the carpet. I figure between Dad and myself, we put in about 200 man days of work. Here in Australia, the day rate for a general contractor is around $300 per day, so I figure I saved myself somewhere around $60k in labor costs.
dsiroky is offline
post #209 of 219 Old 01-08-2014, 06:38 AM - Thread Starter
mads1's Avatar
Liked: 45
that is great, however i never intended to DIY this theatre. spending 400 man days of work is a HUGE cost! Much cheaper for me to pay someone to do it.
Before i contracted Erskine, i had already had quotes from contractors to build out the space to my own plans (which ended up very similar to the Erskine ones) and that estimated price was $40k. We have contracted for that sum. so the balance was for the AV equipment and acoustic treatments etc.
mads1 is offline
post #210 of 219 Old 01-08-2014, 06:42 AM
BllDo's Avatar
Quoted: 596 Post(s)
Liked: 395
OP - very interested in seeing some of the details of your theater come together. Might be a good time to start a new dedicated build thread.
Mfusick likes this.
BllDo is offline
Procella P6 , Triad Inwall Bronze 4 Lcr , Triad Inroom Platinum Sub , Triad Inwall Bronze 6 Sub , Runco Ls 5 Projector
