Anyone know what CAD software this might have been made with? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 12-11-2013, 11:24 AM - Thread Starter
bt90's Avatar
http://cadovations.com/av_01%20Layout1%20(1).pdf
here is a link to an image of a CAD drawing.
bt90 is offline
post #2 of 10 Old 12-11-2013, 12:56 PM
LeBon's Avatar
Quoted: 184 Post(s)
Liked: 86
We used to use a product called VidCAD, which was an add-on to AutoCAD, to document broadcast studio plants. It produced drawings like this, but it was very expensive.
LeBon is offline
post #3 of 10 Old 12-11-2013, 01:05 PM
TorTorden's Avatar
Quoted: 108 Post(s)
Liked: 149
Nothing you wouldn't be able to duplicate using photoshop or even gimp, with a bit of virtual elbow grease.
But it would not be easy or fast and at times mind numbingly tedious.
TorTorden is offline
post #4 of 10 Old 12-11-2013, 01:09 PM
ktm250rider's Avatar
Quoted: 18 Post(s)
Solidworks or almost any CAD program could do that. Any way to find out the native file type?
ktm250rider is offline
post #5 of 10 Old 12-11-2013, 01:47 PM - Thread Starter
bt90's Avatar
I am not sure on the native file type. We only have the printed files..
bt90 is offline
post #6 of 10 Old 12-11-2013, 03:43 PM
Nyal Mellor's Avatar
Quoted: 435 Post(s)
Liked: 312
Maybe DTools? I use v.6 and do drawings like that for my clients. v.6 doesn't look exactly like the one you sent but its possible earlier versions did.
Want to learn about home theater design and acoustics? Read our blog.
Company: Acoustic Frontiers - design and creation of high performance home theaters for discerning audio/video enthusiasts.
Certifications: HAA Level I & II, THX Video Level I & II, CEDIA EST I & II.
AVS Projects: Too many to show in my signature - see here for the master list.
Nyal Mellor is offline
post #7 of 10 Old 12-11-2013, 04:10 PM
sebberry's Avatar
Quoted: 26 Post(s)
Liked: 30
I right clicked in the PDF document and went to "Properties". It says AutoCAD 2004.
sebberry is offline
post #8 of 10 Old 12-11-2013, 05:41 PM
morphlaugh's Avatar
But autocad costs a bloody fortune. Using it for something like this is silly, IMO. I bet you could make a drawing like that in Microsoft Visio or if you have a Mac, you could use OmniGraffle. You could even try something more like a vector art program like InkScape or Illustrator.
morphlaugh is offline
post #9 of 10 Old 12-11-2013, 06:45 PM
sebberry's Avatar
Quoted: 26 Post(s)
Liked: 30
One reason to use something like AutoCAD for electrical diagrams is that the designer can place electrical and electronic components in the plans for the room/theater/whatever and have the system generate wiring diagrams.
Or if you're designing equipment racks you can automate your wiring diagrams. Many commercial A/V, electrical and automation products will have equipment drawings in popular CAD formats, too.
sebberry is offline
post #10 of 10 Old 12-11-2013, 08:21 PM
Quoted: 435 Post(s)
Liked: 312
Not really, with DTools it's part of a workflow. There is a big database with all the products you use, their connections, pricing, etc. You build proposals for clients from that database. Then once project is approved you go into engineering. There is a plugin for AutoCAD and Visio from DTools, you drag products onto the drawing. You can create many views including rack elevation views, wiring diagrams, etc. You can print wire labels from DTools straight onto a desktop Brother label printer. Then when you come back to the system in a year or two you have a diagram showing how everything is wired up, all of your cables are labeled and it is easy to service. It's one of the things separating the boys from the men in terms when you are paying someone else to put your system together for you.
Here's another example, last page is the wiring diagram, this one created with DTools
NyalMellor 1078k .pdf file
