The Bass for the 98% DIY build. - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #61 of 70 Old 04-23-2014, 09:26 PM - Thread Starter
MALIX's Avatar
Liked: 32
Building a diy frame for a final size of about 140 to 145 diagonal in 2.4 0 aspect ratio. At least that's what I think thus far.
ellisr63 likes this.
Sony HW50ES | Denon X4000 | Rocket RS850s | Rocket RS200 | Rocket RS750s | Rocket RS250s | Quad Stereo integrity 18" d4 sealed subs | Inuke nu46000 | MiniDSP | Oppo 103D
My Build http://www.avsforum.com/t/1510721/the-bass-for-the-98-diy-build
MALIX is offline
post #62 of 70 Old 04-30-2014, 05:48 PM - Thread Starter
MALIX's Avatar
Liked: 32
Well.. i havent had a chance to take pics yet but I have the screen up and set up the projector on cardboard boxes. I watched oblivion night before last and it looked FANTASTIC. I have a Sony Hw50es which has reality creation and the oppo 103d with darbee and the results are killer.. the room is a ramshackle at this point with makeshift blankets and linacoustic hung up for temporary light control. But with the lights out I was transported into the movie and was thoroughly entertained for the duration. I LOVE having the ability to enjoy this level of home movie experience! The sound and huge image really make it easy to get immersed in the movie..
the projector mount should be here soon. I will have to make a plate to go between the projector and the mount to allow me to mount my Panmorph UH480. The one thast AVS sells is $$$ so I will try to make one myself out of some 3/8 inch aluminum. Thanks mike at AVS for helping with selecting the best route for me on this..
MALIX is offline
post #63 of 70 Old 05-12-2014, 01:13 PM
Lickety's Avatar
Quoted: 13 Post(s)
Your build looks great. I am actually stealing some of your ideas for my ongoing build.
How did you wire up the color changing LED strip lights? I have about 48 linear feet that I would like to control with one remote, but I can't seem to find an easy explanation on how to wire up multiple strips on one controller (I will need 3 x 5 meter strips).
Lickety is offline
post #64 of 70 Old 05-19-2014, 09:36 PM - Thread Starter
MALIX's Avatar
Liked: 32
Well I started with this kit.
http://www.amazon.com/LEDwholesalers-Controller-2034RGB-3315-3215/dp/B0040FJ27S/ref=sr_1_sc_1?ie=UTF8&qid=1400556239&sr=8-1-spell&keywords=led+wholsalers
Then for every additional 16 foot length I purchased one of each of the following.
http://www.amazon.com/Adapter-Power-Supply-LCD-Monitor/dp/B003TUMDWG/ref=sr_1_1?ie=UTF8&qid=1400556375&sr=8-1&keywords=12v+6a+Adapter+Power+Supply+for+LCD+Monitor+with+Power+Cord
http://www.amazon.com/TSSS-Repeater-Signal-Amplifier-warranty/dp/B00A46UAQO/ref=sr_1_1?ie=UTF8&qid=1400556474&sr=8-1&keywords=TSSS+Data+Repeater+RGB+Signal+Amplifier+For+SMD+3528+5050+LED+Strip+Light%2C+DC+12V+12A%2C+2+years+warranty
http://www.amazon.com/Flexible-Changing-LED-Strip-Ledwholesalers/dp/B00476B908/ref=pd_sim_hi_1?ie=UTF8&refRID=0ABC7QK2E32W23SKQX00.
as far as wiring them up you will need to make sure you match up the wires as you link them all up. I stripped the wire ends and tied them into the phoenix connectors on the repeaters. then use one of the power adapters to power each repeater and your good to go.
Lickety likes this.
MALIX is offline
post #65 of 70 Old 05-20-2014, 08:55 AM
Lickety's Avatar
Quoted: 13 Post(s)
That is exactly the equipment list and steps I was looking for! Thanks!
Lickety is offline
post #66 of 70 Old 05-20-2014, 09:40 AM
Lickety's Avatar
Quoted: 13 Post(s)
One more question - Did you ever line your soffits with poly?
Lickety is offline
post #67 of 70 Old 05-21-2014, 04:00 PM - Thread Starter
MALIX's Avatar
Liked: 32
Yes. ln fact I did. 6 mil poly.
Here are graphs to show what all this treatment thus far has got me..I have been spending time in the REW forum.. but here is what I have to show for all this work so far.
Frequency Response graphs didnt look so good at first, I thought. but Audyssey and minidsp sure did get things tidied up.
I did lots of music listening yesterday. I was really enjoying what it sounds like thus far. tonight I will be watching Tron Legacy.. Hoping to give these subs a workout!!
At his point I have only been focusing on the bass frequencies. AT some point I'll start looking at some of the other things like first reflections and what not.. but so far I am pretty happy with the progress..
And here are photos of the 150" diagonal 2.4 hanging in the room.. So far I am thinking 145 diag will be the final framed size.
And here is the projector temporarily mounted to make sure my DIY mounting plate worked along with the A lens. Saved myself about $400 bucks vs buying the panamorph model. Just some 3/8ths" aluminum plate ( Thx mike at AVS for the tips!) Will have to pull it all down to finish painting it black at some point.. but will keep pluggin away on it all.
Anthony Cler likes this.
MALIX is offline
post #68 of 70 Old 08-03-2014, 06:21 AM
iamjason's Avatar
Quoted: 31 Post(s)
great looking theater and a lot of great ideas - like the idea of the soffits and the rope lights....
iamjason is offline
post #69 of 70 Old 09-11-2014, 09:53 PM
Mike_2008's Avatar
Great theater so far. I was waiting for someone to use some of Moggie's ideas to build a simple flat CIH masking system. Your masking system looks great so far. Did you mount the screen directly to the 2x4 or did you build a frame? What screen material are you using? Thanks
Mike_2008 is offline
post #70 of 70 Old 05-28-2015, 01:56 PM - Thread Starter
MALIX's Avatar
Liked: 32
^^ I built a frame and stretched material from falcon screen. They have newer materials available bu I used their original offering for diy. Excellent material.
I used a pneumatic stapler to stretch the material on and used z metal z hangers to hand the screen. very easy. I then built another frame out of pine base moulding 5.5" wide. Adhered triple plush velvet to it and shot it up onto the 2x4s with brad nails to frame out the final image size.
Been a while since last update.
here are a few pics.
I installed all the screen panels and the motorized masking works well for the most part. the only issue I have with it is that the remote to open and close it has to be a few feet from the screen to work. so I have to get up and walk up to the screen to adjust the aspect ratio...
also got a set of jive 103's from Roman at Rtheaters.com. And added some small fold down chairs that we use as ottomans/storage. They hold throw blankets in underseat storage and usually are folded down. but in a pinch we can add some seats for the rare time w need more than 4 chairs.
Still undecided about covering the window. Early reflections could be handled that way. So I will probably get around to doing that. need to trim out some of the switches, the equipment rack and some of the base molding. And still need curtains and window covering for the door. Also still lacking some tables and chairs for the back of the room. Unless we do a counter behind the theater chairs. Also will eventually build a bar for the back wall...
Next project is to add an outlet to the floor under the chairs. I have dropped the romex. Just need to add the box to the floor. But I have been watching lots of movies. When the lights are out the rest of the room fades away and the large floating image on the large black front wall makes for a great movie viewing experience.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[/IMG]
[IMG][/IMG]
[IMG][/IMG]
gonna try to install the outlet today so I can get rid of the mess of cords behind the chairs.
[IMG][/IMG]
MALIX is offline
Sony Vpl Hw50es 3d Projector , Panamorph Uh480 Anamorphic Lens , Seymour Av , Denon Avr X4000 7 2 Channel Home Theater Receiver , Behringer Nu4 6000 Inuke 1400 Watt Power Amplifier , Oppo Bdp 103d Universal 3d Blu Ray Player Darbee Edition
