Any things you wished you did or tips for new construction? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-23-2014, 02:41 PM - Thread Starter
spoonx's Avatar
I am going to be building my new house soon, which i will build a home theater for. So is there anything you would recommend doing or stuff you wish you would of done throughout your home or in the home theater?
spoonx is offline
post #2 of 6 Old 01-23-2014, 04:11 PM
caseyparsons's Avatar
Quoted: 41 Post(s)
The first sticky thread at the top of this section is called "What I'd do differently next time". Probably a lot of good material in there...
http://www.avsforum.com/t/855958/what-id-do-differently-next-time
Rjloper9 likes this.
n00b
Theater Under Construction
Childhood Home Theater Build
caseyparsons is offline
post #3 of 6 Old 01-23-2014, 06:15 PM
blazar's Avatar
Quoted: 731 Post(s)
Liked: 533
Run all the power outlets in your room: in-floor powered speaker outlets, walloutlets, projector outlet, etc. to a single wall inside your media closet and terminate them there. This way you can plug all that into power conditioner in your media closet. Voila no ground loops.
Blazar!
blazar is offline
post #4 of 6 Old 01-23-2014, 06:22 PM
Quoted: 3734 Post(s)
Liked: 3157
And when the inspector tests the outlets, Voila, no occupancy permit. I do that for the projector, but ALL the outlets? just make sure they are dedicated to theater in the main breaker box, and not branching off to other rooms.
post #5 of 6 Old 01-23-2014, 06:34 PM
auburnu008's Avatar
Quoted: 440 Post(s)
Liked: 600
auburnu008 is offline
post #6 of 6 Old 01-23-2014, 06:47 PM
blazar's Avatar
Quoted: 731 Post(s)
Liked: 533
You might need to be there to plug them in and prove they work lol. Or wall plate them in the closet after inspection!
Blazar!
blazar is offline
