Dream come true... - AVS Forum | Home Theater Discussions And Reviews
Old 01-23-2014, 04:33 PM - Thread Starter
Oledurt's Avatar
Quoted: 201 Post(s)
Liked: 288
I have been into home theater since the 90's. Back then I had speakers attached to my bed with shoe strings. I have come a long way with this hobby. Today my wife and I signed a contract to build our first home. It will include a finished basement with a dedicated media room. It is surreal that I will finally have a dedicated room for this great hobby. I daydream about the possibilities all the time. I just wanted to tell someone how excited I am. biggrin.gif:D:D:D:D:D:D
Oledurt is offline
Old 01-23-2014, 05:12 PM
caseyparsons's Avatar
Quoted: 41 Post(s)
Sounds awesome. Congrats! Post lots of pics.
n00b
Theater Under Construction
Childhood Home Theater Build
caseyparsons is offline
Old 01-23-2014, 08:11 PM
Cla55clown's Avatar
Quoted: 135 Post(s)
Liked: 71
Yep that's awesome to have that opportunity. Hope you have plenty of time for planning so it's done right. Do you have an early list of components and/or direction you want to take? I hope to be where you are in a couple years.
Cla55clown is offline
Old 03-01-2014, 08:05 AM
Renstar's Avatar
Congrats Casey!
If you're starting from scratch, then the sky's the limit. You seem handy so building your own dedicated speaker system and acoustic room treatments will save you some $$$ and help you achieve high end sound. I'd strongly recommend you consider having your basement dug a few feet deeper than average for a nice high ceiling. Also consider designing your room to allow you to build an Infinite Baffle sub system. ie., have a laundry or storage room on the other side of the front of your theater room. I'm also a convert to single full range driver sound, which also can save you money on speakers and amps if you have adequate space to build big cabinets. As soon as you have a floor plan and foundation measurements for your home, post it.  Read up on room acoustics so you can build your HT to golden proportions and have less issues with standing waves.
Have fun with your dream home! :D
Renstar is offline
