HDMI cable - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-28-2014, 06:49 AM - Thread Starter
eljr's Avatar
Quoted: 1193 Post(s)
Liked: 9050
Is it possible to run an HDMI cable and attach the connector after the wire is run ike you would do with coaxial able or even speaker wires?
ELJR's "listening" blog.
eljr is offline
post #2 of 3 Old 01-28-2014, 07:01 AM
Trepidati0n's Avatar
Quoted: 39 Post(s)
Liked: 107
Anything is possible. However, it is not even remotely reasonable to be done in home. But, if the run isn't too long you could use a junction plate. The insertion loss and impedance mismatch for that short of distance shouldn't affect the waveform too much. Is your issue conduit related? If so, an HDMI over Ethernet might work out. Links below are examples. Choose what works best for you.
http://www.monoprice.com/Product?c_id=104&cp_id=10425&cs_id=1042501&p_id=7330&seq=1&format=2&utm_expid=58369800-11.KFcpHWqASSutMqNPOqaJVg.0&utm_referrer=http%3A%2F%2Fwww.monoprice.com%2FCategory%3Fc_id%3D109%26cp_id%3D10425
http://www.monoprice.com/Product?c_id=104&cp_id=10425&cs_id=1042501&p_id=8009&format=2&utm_expid=58369800-11.KFcpHWqASSutMqNPOqaJVg.0&utm_referrer=https%3A%2F%2Fwww.google.com%2F
eljr likes this.
I must be guilty because people say I am guilty because they chose to call me guilty because they refuse to see the truth. Much easier to be part of the mob..
Trepidati0n is offline
post #3 of 3 Old 01-28-2014, 07:45 AM - Thread Starter
eljr's Avatar
Liked: 9050
thanks
eljr is offline
