Black velvet for wall recommendation (Fidelio???) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-13-2014, 04:51 PM - Thread Starter
ch1sox's Avatar
Quoted: 317 Post(s)
Liked: 113
I was at Joann Fabrics and they had a Royalty, Premiere and Empress velvet. I couldn't find the Fidelio black velvet. Does anyone know who sells it or something similar? Or are the Joann velvets I listed fine? This will go on the wall behind the screen.
ch1sox is offline
post #2 of 2 Old 02-13-2014, 05:13 PM
Quoted: 3278 Post(s)
Liked: 2754
If you like the look of the velvets at Joann's use it you will save money. I've used it before, you can also check for Hancock fabrics in your area.
if you want the real thing get out your check book http://www.bymichelle.com/fidelio.html
