HDMI extender CAT6 into Onkyo 818 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-28-2014, 10:44 AM - Thread Starter
YitEarp's Avatar
Hello
I've been toying with ideas on how to distribute media across the home its caused me no end of headaches just thinking about it so planning is now going to be harder.
I need to ask if running a hdmi extender into an av receiver will work OK or not?
I intended to connect 5 devices into a network ready av receiver and have the ability to control it via a remote. I've read some issues with EDID etc and im a bit worried now that this might not work?
I've also looked into a hdmi matrix over cat6 but if I can help it I don't want to spend on that just yet. I have already put in cat6 cables ready for it if I have to go that route.
I have purchased a dual cat6 hdmi extender and I haven't got around to testing it yet but should the method work or not? Thanks guys
YitEarp is offline
post #2 of 2 Old 02-28-2014, 01:47 PM
WSLN 6's Avatar
I am doing the same thing with my 818, works great! I did have to add a second 5 volt power supply for the other hdmi splitter, even though the cat 6 run was quite short.
WSLN 6 is offline
Onkyo Tx Nr818
