Looking for AT screen and front stage build threads - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #31 of 60 Old 03-11-2014, 08:58 AM
Diesel 48's Avatar
Quoted: 71 Post(s)
Liked: 33
What about light spillage from the projector? I think that is what he means.
Diesel 48 is offline
post #32 of 60 Old 03-11-2014, 09:08 AM
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 139
It sounded like his concern was the black bars but if it's spillage, than yes, the closer the screen is to the ceiling, the more reflections you will get. If the ceiling/soffit is painted black, I don't think it would hurt image quality very much, but if it's distracting, you could install a black velvet panel on the bottom of the soffit or on the ceiling above the screen.
Bigmouth's theater
Spaceman is offline
post #33 of 60 Old 03-12-2014, 10:52 AM
jbryngelson's Avatar
Sorry to show my ignorance, but what is the consensus on the benefits to having a front stage in a basement theater build? I am debating the idea from a design/look perspective, but would like to know if there are benefits I am overlooking.
Jeff in Detroit
jbryngelson is offline
post #34 of 60 Old 03-12-2014, 12:41 PM
sgolko's Avatar
STRAIGHT STAGE AND SCREEN WALL 101
Wrap them in either black GOM FR701 or black velvet and put in place.
Big, are your 4 panels just friction fit into place? Or are they secured somehow?
sgolko is offline
post #35 of 60 Old 03-12-2014, 02:48 PM
Quoted: 3256 Post(s)
Liked: 2743
usually just friction fit occasionally if the panel is loose a couple dabs of Velcro.
post #36 of 60 Old 03-12-2014, 05:47 PM
MysticalJet's Avatar
Quoted: 81 Post(s)
Liked: 151
Check my build maybe confused.gif starting here
MysticalJet is offline
post #37 of 60 Old 03-12-2014, 06:26 PM
bigbadbob's Avatar
When it comes to the stage is it necessary to fill it all with sand or can you utilize insulation too?
Klipsch Rocks!
bigbadbob is offline
post #38 of 60 Old 03-12-2014, 07:45 PM - Thread Starter
Reefdvr27's Avatar
Quoted: 1564 Post(s)
Liked: 1038
Good point with the insulation in the stage, is that even effective???
I need some help here guys!!
I had a meeting today with the builder, electrician and heating cooling guy for my build. I am basically just winging this thing and the builder and electrician are not theater builders, but we are on page and I think I can get close to what I want. I have decided that I cannot have an AT screen, maybe down the road, but just not now. One of the reasons are that the ceiling is to low and I am doing a soffit for a Night Sky Mural, so it will conflict with the screen size. So I have decided to just go with a front stage and a fixed screen. There is just not enough room to do an AT screen, but I am fine with it. Cannot have it all I guess.
I need help with a screen size. I am using a Panasonic PT-8000AU. I will be mounting on the ceiling from about 12' to 13'. We figured that a good screen size would be about 4' high and 6' to 7' wide. Can any point in the direction of a screen and aspect ratio. I just know nothing about projectors and screens. I really need help with this.
Thanks in advance.
Reefdvr27 is offline
post #39 of 60 Old 03-12-2014, 09:01 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
The short answer is no, at least that's what BIG told me when I PM'd him about it. I'm sure he'll weigh in and tell you more.
jbrown15 is offline
post #40 of 60 Old 03-13-2014, 07:15 AM
Crash11's Avatar
Quoted: 23 Post(s)
Just my opinion, but I never understood why people made stages where the first step went most of the width of the room. To me, you're losing area in the middle of the stage, which I think is the exact spot you'd want room for someone to stand. I like putting steps to the outside and leaving the center at full height.
Crash11 is offline
post #41 of 60 Old 03-13-2014, 08:23 AM
sgolko's Avatar
Thank you, good sir
sgolko is offline
post #42 of 60 Old 03-13-2014, 08:24 AM
tlogan6797's Avatar
Quoted: 105 Post(s)
Liked: 131
The point of the stage is not to stand on. It's to create a massive base for your sub woofer. Using sand helps keep the rest of the house from vibrating. If you add 1.5 tons of play sand into the stage and keep it from touching the walls, your sub will have to try to vibrate all that mass before it gets to the floor and the rest of the house. Also, in order to get the real bass punch most of us are looking for, the sub cannot vibrate the surface it is sitting on. By having such a solid, massive surface the sub speaker fires as it is designed to. There are far greater explanations out there, but this is the jist of it.
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
post #43 of 60 Old 03-13-2014, 08:29 AM
sgolko's Avatar
I'm also going off what Big said, I'll try to regurgitate to the best of my ability....
Filling the stage is done for 2 reasons
-to stop it from acting like a big drum. for this, filling with insulation (as you do for a riser) would work just fine
-to stop the speakers and especially subs from shaking everything in the room - essentially you want to sit the speakers/subs on something so much more massive than the speakers themselves that it just absorbs all of the vibrations from the speakers/subs without transferring the vibrations to everything else. By using insulation, you've got (approximating here) 100 lbs of speakers on 150 lbs of lumber. By filling it with sand, you've got 100 lbs of speaker on 3000+ lbs of lumber and sand.
Hope that makes sense, and reflects some sort of truth.
sgolko is offline
post #44 of 60 Old 03-13-2014, 09:27 AM
Crash11's Avatar
Quoted: 23 Post(s)
I disagree. However, if that's the only reason for it, then I think we should start calling it a sub-base.
Crash11 is offline
post #45 of 60 Old 03-13-2014, 09:39 AM
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 139
Originally Posted by W00lly View Post
Which is the only reason I have one. Mine doesn't hold a sub or karaoke singers. I just like the look.
W00lly likes this.
Spaceman is offline
post #46 of 60 Old 03-13-2014, 09:45 AM
sgolko's Avatar
My stage is simply to hold subs and look bad-ass.
W00lly likes this.
sgolko is offline
post #47 of 60 Old 03-13-2014, 03:36 PM
cw5billwade's Avatar
Quoted: 328 Post(s)
Liked: 184
All the above I had to explain to my WAF several times the purpose. I even had to lay it out with 2x4s to show her. She final gave one of those do whatever you want looks. rolleyes.gif My build is second floor so I could only use pink stuff. Unless the screen was retractable I would not want anyone up there any way. If you want to do karaoke or something go elsewhere. I have 2 subs on my stage.
before velvet panels
cw5billwade is offline
post #48 of 60 Old 05-19-2014, 02:50 AM
Manic1!'s Avatar
Quoted: 172 Post(s)
Liked: 73
Originally Posted by cw5billwade View Post
talk about a wall of sound eek.gif your avatar name says it all biggrin.gif do you have a build thread?
Sorry not my build.
Manic1! is offline
post #49 of 60 Old 06-02-2014, 01:55 PM - Thread Starter
Reefdvr27's Avatar
Liked: 1038
You build a frame on top of roofing felt, keeping it 1/2 inch away from walls
You line each cavity with plastic and fill with play sand
Hey Big. Sorry for a noob question, but with this pic here, you said to keep the stage a 1/2" from the wall with shims, so what do you do to anchor it? Does the sand give enough weight to stay in place or do you anchor to the floor somehow? I have a concrete slab floor.
I will be starting on the stage build next week or following week. So want to get my plans ready.
post #50 of 60 Old 06-02-2014, 02:04 PM
jbrown15's Avatar
Liked: 1993
Dave, there's no way your stage will move once if have sand in it. Mine has 2500lbs of sand in it, there's no way that thing is moving a mm. smile.gif
jbrown15 is offline
post #51 of 60 Old 06-02-2014, 02:18 PM - Thread Starter
Reefdvr27's Avatar
Liked: 1038
Cool, That is was I thought, on the flip side I was not sure if it would rattle or walk a bit with some big bass, cause big bass will be on tap. wink.gif Did you just buy bags of play sand or did you have it delivered in bulk? going up to Lowes now to get a door, gonna check out some play sand prices frown.gif
post #52 of 60 Old 06-02-2014, 02:35 PM
jbrown15's Avatar
Liked: 1993
No I bought a full light of playground sand from Home Depot. Personally I'd rather spend the extra money on the playground sand because its be sterilized, washed and screened, but if you just bought bulk sand you could have stuff growing in it, bugs and of course I would guess you'd have moisture in it too.
jbrown15 is offline
post #53 of 60 Old 07-17-2014, 01:57 PM
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
Quote:Originally Posted by W00lly
Plus stages just look cool
All the above I had to explain to my WAF several times the purpose. I even had to lay it out with 2x4s to show her. She final gave one of those do whatever you want looks. My build is second floor so I could only use pink stuff. Unless the screen was retractable I would not want anyone up there any way. If you want to do karaoke or something go elsewhere. I have 2 subs on my stage.
CW, did you screw the goalpost false wall down through that carpet?
wraunch is offline
post #54 of 60 Old 07-17-2014, 03:35 PM
Quoted: 328 Post(s)
Liked: 184
Yes I did and Into the drywall above go to my screen build link to se details
post #55 of 60 Old 09-07-2015, 08:33 PM
crimsonblue's Avatar
Quoted: 126 Post(s)
Liked: 83
[Reviving old but good thread]
Once you have a frame built for the stage, I had a few questions:
1. Is there any difference in using MDF, OSB, or Plywood for decking? I have some extra MDF lying around that I thought I might use.
2. What is the best way to line the cavities with plastic? Do you just take plastic drop cloth and cut it to size?
3. Any difference between a bag of play sand vs. a bag of multipurpose sand? In larger quantities, the multi-purpose sand is a little cheaper (and a larger bag could mean fewer trips!)
4. I plan to replace the carpet in the entire room, but for the purposes of building the stage, is there any reason that I couldn't leave that 24" portion there for extra vibration/sound absorption under the stage? (I'll cut and rip out the rest next month when things get really messy)
________________________________________________
Home theater build 1.0 | Black & Grey Theater (2.0)
Marantz AV7702mkII | Epson 5040 | 7.2.4 Elusive 1099 LCR + Volt 8 Atmos & Surrounds + Dual UM18 Subs
crimsonblue is offline
post #56 of 60 Old 09-08-2015, 02:16 PM
Liked: 2743
1) not really I would use at least two layers of 3/4 or three layers of 5/8. use GG or roofing felt between layers, lots of screws for the last layer.
2 over-sized piece of plastic drop cloth, fill at least 3/4 full punch the sand into the corners and then trim the plastic even with the top edge, fill the remaining cavities no more than 7/8 full. There is some floor structure design research that suggests mixing sawdust with the sand to keep it from compacting too much is beneficial in making it dampen vibration. Totally filled and overly compacted sand is not a good, it acts more like concrete than sand.
3) play sand is washed and has less dust. Workers who have been around sand dust for 20 years have had health issues. Just be sure what ever you put in is bone dry and I wear a mask when pouring. Pouring is not an activity for your young kids to help (breathing the dust) with nor let your cats have access to the room, you've been warned.
4) in the unlikely event that you have a minor water event (leaky water heater for example) you will regret leaving carpet anywhere you can't easily rip it out.
post #57 of 60 Old 09-09-2015, 09:03 AM
woolfman's Avatar
Quoted: 23 Post(s)
Add decking, two layers of 3/4 plywood or OSB with Roofing felt or GG between layers leave a 1 1/2 inch lip and round over with a router.
You build a screen support structure and add the z clips for the screen frame.
You make 4 frames for around the screen top,bottom, left and right. Picture of the ones for the top and bottom:
Hey Big, what type of screen and frame did you use? Was this a kit?
WOOLFMAN
Woolfman’sTheater Build #2
WOOLFMAN THEATER Construction thread
One small job for mankind, one hell of a build for 1 guy
woolfman is offline
post #58 of 60 Old 09-09-2015, 09:23 AM
Liked: 2743
That screen was Falcon serial #00000002 . 00000001 was the prototype at Rich's house. If you look at the Rawlinsway build thread I think there are more pictures of the screen assembly. I think all AT screens ship un-assembled. You put the frame together and attach the fabric. Falcon uses some very easy to use quick assembly brackets and an O ring post and loop design for the grommetted screen fabric.
post #59 of 60 Old 09-12-2015, 08:00 AM
Quoted: 126 Post(s)
Liked: 83
I'm taking up carpet from the area where my new stage is going to go, and there is a carpet pad underneath. I know that the guidance has been to build the stage on the concrete floor, but why wouldn't it be beneficial to build it on top of the pad? I will be using roofing felt on the bottom too.
1. If the resonance of the concrete is why we all pour sand, why not pad the bottom of the stage to reduce resonance from the wooden stage touching the concrete floor?
2. How far do you guys extend the stage past the screen frame into the room? 18-24 inches?
post #60 of 60 Old 09-12-2015, 10:31 AM
Liked: 2743
if you ever have a minor water event, trapping a sponge under the stage won't seem like a good idea at that future date. Usually minor events are remedied with industrial sized drying equipment or removing the carpet. If you don't take out the sponge it won't dry fast enough to avoid mold and odor.
