Odd celing angles causing design dilemma. - AVS Forum | Home Theater Discussions And Reviews
Old 03-10-2014, 11:34 AM - Thread Starter
cbazhaw's Avatar
I am scratching my head on the proper placement of a rear set of speakers in this soon to be media room. The width of the room is 13'. There will be seating against that back window, and yes black out curtains will be installed. As you can see in the picture the builder really gave me some odd ceiling angles to work with. I initially wanted in ceiling speakers to eliminate hiding speakers wires by running them through the attic. Corner mount speakers are also a challenge with the small build out they did in the right corner. This is my first media room so any suggestions would certainly be helpful.
Denon AVR-X2000
Polk TSx550t
Polk TSx550t
Polk TSx250c
Fluance XLBP
SVS PB1000
AppleTV JB
cbazhaw is offline
Old 03-10-2014, 11:42 AM
HopefulFred's Avatar
Quoted: 490 Post(s)
Liked: 422
I need some more information to give you a "what I would do" recommendation. Is the seating against the window the only seating, or is it second row, overflow seating? Are you trying to place rear surrounds in a 7.x situation, or surrounds for a 5.x installation? Have you picked speakers?
HopefulFred is offline
Old 03-10-2014, 11:55 AM - Thread Starter
cbazhaw's Avatar
The seating under the window will be a couch seating and i planned on placing an additional seat on the left and right in front of the couch, so it will be make a U shape. I was planning on 5.1 since do to the size of the room and my limitations on seating layout. I have not picked any speakers yet just been looking at different manufacturers.
Denon AVR-X2000
Polk TSx550t
Polk TSx550t
Polk TSx250c
Fluance XLBP
SVS PB1000
AppleTV JB
cbazhaw is offline
Old 03-10-2014, 11:56 AM
Quoted: 3260 Post(s)
Liked: 2748
go 7.2 these would be the rears, look at the Axiom on wall surrounds
Old 03-10-2014, 02:51 PM - Thread Starter
cbazhaw's Avatar
How does this sound? A pair of Axiom M0s for the back and a pair of M3s for the side walls. Maybe a pair of M60s or M80s for the front paired up with a VP150 or VP160 and an EP175. Don't think I want to go with 2 subs right now so I'll go 7.1. Now the question is this overkill for mainly watching movies. I am not an audiophile, I might stream music to it via some idevice but that mainly happens downstairs.
Denon AVR-X2000
Polk TSx550t
Polk TSx550t
Polk TSx250c
Fluance XLBP
SVS PB1000
AppleTV JB
cbazhaw is offline
Old 03-10-2014, 03:23 PM
Liked: 2748
I would lean toward the surround speakers not the M series. The reason I suggested Axion surrounds is they beam sound all over the place. I would also pull your seating forward away from the window as much as possible.
Old 03-10-2014, 03:46 PM
BllDo's Avatar
Quoted: 572 Post(s)
Liked: 373
The Triad OnWall Surrounds would be another good option for your room.
BllDo is offline
