Can you install a regular outlet in line with a PowerBridge? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-14-2014, 07:17 AM - Thread Starter
ParanoidDroid's Avatar
I'm trying to figure out a way to get this to work without hiring an electrician. I have one outlet and need three. Ive drawn my layout. Is this possible? I know I can run another outlet from a single outlet, but will the outlet work if its wired in series with a PowerBridge device? Nothing would be added that's not already on on the circuit....so no increase in load.
So it would be PowerBridge Inlet---->Romex---->Another Outlet--->Romex--->Powerbridge Out to main outlet
Dont laugh at my pictures. The wiring diagram is attached in the PDF File.
Setup.PDF 32k .PDF file
The TV would stay where its at. The receivers would be moved underneath the bar.
ParanoidDroid is offline
post #2 of 5 Old 03-14-2014, 08:05 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
Why would you need to run power bridges? Usually the purpose of a powerbridge would be to hide unsightly wiring from a wall mounted tv. Running an outlet behind the fridge and bar shouldn't require that. Wiring up an outlet is barely different than wiring up a power bridge. If you have to run wires from the TV outlet to 1a and 1b just use regular outlets and save some money.
A basic diagram of how to wire.
http://www.handymanhowto.com/wp-content/uploads/2011/01/Parallel-Wiring1.jpg
Youtube video
http://www.youtube.com/watch?v=CN4sxAmcRME
oman321 is offline
post #3 of 5 Old 03-14-2014, 08:17 AM - Thread Starter
Originally Posted by oman321 View Post
Why would you need to run power bridges? Usually the purpose of a powerbridge would be to hide unsightly wiring from a wall mounted tv. Running an outlet behind the fridge and bar shouldn't require that. Wiring up and outlet is barely different than wiring up a power bridge. If you have to run wires from the TV outlet to 1a and 1b just use regular outlets and save some money.
Youtube video
The powerbridge 1A would be hiding wires going into the wall and up across the ceiling to the speakers up top.
I guess I was worried about how many outlets would be running off one outlet. I guess I could wire the fridge to a regular outlet which would be connected to another rooms outlet. If I did that, would it be OK to do the powerbridge in line with another outlet, then to the powerbridge to outlet?
post #4 of 5 Old 03-14-2014, 08:26 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
Probably best to do that for the fridge just so you don't get spikes from the fridge when it runs. Like you said, since the load isn't changing you shouldn't have a problem. What I recall from personal knowledge a circuit should only have about 8-10 fixtures/receptacles on it. Best practice is to calculate what you actual load will be and go to about 80% of the circuits max.
Again since you are not changing the load, you should be ok.
oman321 is offline
post #5 of 5 Old 03-14-2014, 10:49 AM
bluedevilbrent's Avatar
I see no reason why you need a powerbridge.
Just wire all of the outlets together and forget about the inlet.
bluedevilbrent is offline
