AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Dedicated Theater Design & Construction (http://www.avsforum.com/forum/19-dedicated-theater-design-construction/)
-   -   Hi all! First Time poster, first time HT builder. (http://www.avsforum.com/forum/19-dedicated-theater-design-construction/1522641-hi-all-first-time-poster-first-time-ht-builder.html)
DEEEEEEEZY 03-15-2014 08:23 AM
3 Attachment(s)
Been lurking on this site for some time, but I bit the bullet on a new home and the wife has granted me a dedicated home theater room.  I'm very excited about it and have started drawing up ideas of how I would like it to be set up.  I am at work now and will later add in some images of my space and also a napkin prelim drawing of my ideas for the room.  Once things get started.  I will add in build progress images to boot.
I'd love for anyone to chime in with their experiences and advice as I am a first timer and can use all the help I can get.
I don't have hobbies outside of this so the DIY aspect of it is important to me, so here goes.
The space I will be working in is 16'x21'x9.5'
I am thinking of a 120 inch AT screen built onto a screen wall with an approximately 30" space behind it to hold the front, center and subwoofers.
The screen size is limited to 120" due to the fact the wall available has 2 doors on it (one leads to a bathroom and the other to the AV closet (wiring for surround speakers, projector, cable and power are already placed [from last owner]).
You can see from the image above the two doors on the screen wall, and another door on the side wall in what will be the back corner of the room.
I haven't decided whether I would like the back the back row of seats all the way against the back wall (or at least closer to it) because the air vents come through the floor below two large windows (that will be filled with sound absorbing material and covered) and ventilation would need to be routed out of the riser.  Right now I have a "wall" behind the last row, but I don't know if I like that idea just yet.
I'd like the seating to be a 4 seat row with loveseat in the middle.  I am neither for nor against reclining seats.
On the screen wall I'd like to add curtains to the sides so that the doors to the AV closet and bathroom are obscured.
I could use advise on anything and everything, so hit me with it as I'd like to do it right the first time.
Thanks all.
(I'll add pictures of the room when I get to my home computer.)
schmidtwi 03-15-2014 12:10 PM
Welcome to AVS! You'll get some great ideas here, but you should provide additional information. Post your entire floor plan, if possible. Three doors in a dedicated HT is not ideal. Perhaps you have options you haven't considered yet.
You also need to plan for type of room construction, HVAC, electrical, sound isolation, room treatments, etc.
Enjoy your journey, HT is an addiction...
DEEEEEEEZY 03-15-2014 01:39 PM
3 Attachment(s)
Thanks for the reply.  I suppose I did leave a bit out.
This is a rough sketch of the bottom floor.  I'm not a hundred percent on the measurements of the closets and bathrooms, but the general layout is there.  The room in the Bottom Right is what is slated to be the home theater room.
As far as sound insulation goes, I am thinking of carpet for the floor.  And dampening panels on the walls with bass traps in the windows and back corners of the room.
As far as HVAC goes.  There are currently only two input vents in the far wall under the windows.  If pumping the air out becomes a necessity/which i'm sure it will get stuffy, I suppose putting a return behind the screen wall could be possible.  That way there would be a good flow of air from behind the back seat row all the way to the front of the room.
The ceiling in the room already has Can lighting that is far enough out to be compatible with a recessed ceiling.
The speaker wiring is already run through the walls in a 7.1 distribution, and while the placement of the middle surrounds is not perfect, it will not be hard to move where it comes out.  Especially if I cover the walls with sound absorbent paneling.
Sound system wise.  My current setup is not my end setup, but I have klipsch reference center RC62 ii and surrounds that will likely remain part of the final product.  I have a reference subwoofer rw-12d that will be replaced by two PB-2000 SVS subs.  The front towers currently are klipsch f-20s but I suspect I will need to replace those as well.  Since the screen wall will not require permanent installation of speakers I will have flexibility with replacing speakers in the future.  LCR and sub-wise anyway.
When you say room treatments, i'm not sure I follow.  I would LIKE to have a matte black recessed ceiling, with perhaps a rope light around the bottom.  Color wise.  Most of the house paint is a matte gun metal gray color and unfortunately for this room a very beautiful dark hardwood/laminate floor.  So the floor will get covered up by carpet or a very large area rug for sound absorbing.
Phew... did I cover it all?
Cthanatos 03-15-2014 02:21 PM
I'm learning that. I don't even have plans that I can work from yet but I've already learned a ton as well as learned that what I know is a drop in the bucket compared to the ocean available here and elsewhere. One step one day at a time. I look forward to following this thread as we'll be building later this year smile.gif Good luck DEEEEEEEZY!
BIGmouthinDC 03-15-2014 03:03 PM
Put down the hammer and step away from the woodpile, seriously your plan needs some fine tuning.
when you said sound insulation do you mean soundproofing? if the later you need to do some more homework.
eliminate the door to the bathroom PLEASE
Lets figure something else out on the AV stack to eliminate that other door. Probably flip the room 180 degrees and have a built in wall rack in the back corner.
Move the door to the theater between the stage and the first row on the side wall.
Crash11 03-15-2014 04:20 PM
OK before any other decisions are made.........pump the brakes.
I think you should flip your theater 180 degrees. Put the screen wall to the bottom with the vents behind the false wall. Put your side door a few feet up so you enter between the stage and riser (assuming you have a stage).
Shoot, I just saw that Big already mentioned this. Damn you Jeff. Ohh well, my fault for not reading the entire thread. I just had this major urge to say something immediately.
Edit: another thought, build the A/V equipment into a rack in the back wall. Then open up the back of the A/V closet to the bedroom closet behind it. The back of the room is a great place for an A/V rack anyway.
petew 03-15-2014 04:30 PM
++ what Big and Crash11 said.
+++ remove the bathroom door.
BIGmouthinDC 03-15-2014 05:24 PM
About the HVAC, pipe it to the front of the false wall on the sides of the screen.
DEEEEEEEZY 03-15-2014 05:55 PM
3 Attachment(s)
You know, my first inclination was to reverse the whole room 180 degrees and move that door.  The problem is, I dont know if I can convince my wife to do it.
I'll show you why once I get a chance to, but the flip side of that wall is a 19 foot blank wall that she had planned to make as a photography display.  The size of that wall was a big part of her inspiration to do it, but I may be able to convince her to change her mind (its only a few feet right?).  The other problem will be that I have never done any BIG renovations like cutting holes in walls and installing doors, and may not be comfortable tackling that on my own.  The house is on the side of a mountain and anything that I do I dont want to compromise the strength of the house. I suspect the middle long wall is a load bearing wall.
I'd really like to avoid paying a contractor or the like to do this if I can do it [well/safely].
I'll draw up some stuff in the other direction as well and mill it over.  I'd like to try to make a scale model somehow.  I've seen folks use the sketchup program and I'll see what I can do with it.
Thanks for the input so far.  Its good to have multiple opinions on this.  I don't wanna regret a poor decision.
Tedd 03-15-2014 06:41 PM
Design the new door so it is flush, so you still have a 19' photo wall... That way, the photo wall won't be compromising
a room that has a lot of work, time, and money invested in it. Flush mount the bath room door and get a 24' photo wall.
Close off the bathroom to the theater. Build a wall to wall riser and further leverage it as a full range bass absorber.
The av rack could be recessed into the existing back wall closet.
BIGmouthinDC 03-15-2014 09:16 PM
figure out how the ceiling joists run, from your diagram it doesn't appear to be a load bearing wall, but I can't tell for sure.
Cthanatos 03-16-2014 12:20 AM
Crash11 - you mentioned that you assume he's got or will have a stage. Is that just an aesthetic choice, or is there some benefit that I'm not aware of? Is there a reason why someone might want a stage and not just a flat wall?
BIGmouthinDC 03-16-2014 04:29 AM
one more time, here are 9 pages of threads on why build a stage:
http://www.avsforum.com/newsearch?advanced=1&action=disp&search=why+stage&titleonly=1&byuser=&output=all&containingforum[]=19&replycompare=gt&numupdates=&sdate=0&newer=1&sort=relevance&order=descending&Search=SEARCH&Search=SEARCH
it is about the sand
NYGIANTSFAN23 03-16-2014 07:23 AM
I know all about the sand!!!
Crash11 03-16-2014 07:55 AM
Well my argument is that it is in fact for aesthetics. If all one wanted to do was build a structure that weighed a lot, then it wouldn't protrude into the room and look like a stage.
CHILINVLN 03-16-2014 08:48 AM
Agreed with the above, but I'm going to expand just a bit on it.
1. Flip the room 180 degrees
2. Remove the door for access to the bathroom from the theater.  This is not necessary, as its accessible from the main rec room already.
3. Relocate the door to the theater somewhere else on the wall, all depends on how you design the seating layout, but not near the screen.
4. Ensure that your door opens OUTWARD, not inward.  This will better utilize your space inside the theater.
5. Have your wife's paintings/art on the long outside wall.  You can even add accent lighting to enhance them.  If they're in the theater, you need to securely mount them so that they don't rattle.
Tedd 03-16-2014 09:54 AM
1 Attachment(s)
4 will also violate most (- likely all) building codes so that might be something to carefully consider.
X.jpg 175k .jpg file
You also might the Mrs more agreeable if you educate her as to the reasons things are being done a certain way.
DEEEEEEEZY 03-16-2014 10:10 AM
3 Attachment(s)
Finally home!
Here are some shots of the room.
Above is a shot from the stairwell looking in the open living space of the bottom floor.  The far wall is the Long wall that was to be the photography display.
Above is a shot of the "infamous" bathroom door looking into the theater room.  I am standing in the doorway of the bathroom taking the shot.
This shot is standing in the doorway of the bathroom door looking into the room which is to be the theater.  You can see the wire coiling out of the walls where the 7.1 channels were previously.  As well you can see the wiring from previous installed projector.
Above is the AV closet as it stands currently.  The HDMI and composite wires here are the ones that terminate from the ceiling in the previous image.  See the cable and ethernet socket as well.
This is a shot from the far doorway looking back at the AV closet and bathroom.
Now you all have a better idea of what I'm working with, lets hear it.
BIGmouthinDC 03-16-2014 10:19 AM
what is throwing you off your game is the space is finished. Nothing a hammer and some contractors cleanup bags couldn't solve in a weekend. You are looking for an easy fix, we want a great theater space.
Remove all the doors and reposition as has been suggested. The theater door can swing in without a problem if you place it properly.
You may want to contact the Erskine group for the basic design service.
Tedd 03-16-2014 10:32 AM
Awesome space.
So how far are you prepared to take this space? Is it to be a sound proofed dedicated theater, or a simple rework of the existing room?
DEEEEEEEZY 03-16-2014 11:41 AM
3 Attachment(s)
I suppose I am still a bit fuzzy on what my options are for sound treatments.  I had originally thought about mounting panels on the wall similar to the ones in the "staggered walls" theatre on the forum.  The difference being I would make the panels much larger and not staggered.  Perhaps two tone with a stripe running through the middle about 1/3 of the way up the wall (I'll try to find an example of what I mean).  Kind of like a thicker chair rail but just a different colored sound panel.  Also I would plug the windows with sound absorbing material of some kind.  I'd also like bass traps in the corners if possible.
As far as moving the door.  I have spoken with the Mrs. and moving it wont be an issue (provided I have a contractor do the moving.)  She would prefer the door match the others in the house rather than changing it to a different style (i.e. flush mount).
So, I agree with everyone about the turning 180 degrees, and closing off the bathroom door.  If done this way.  I could possibly add new equipment for HVAC if necessary in the existing AV closet that could be gutted and redone.
As far as taking the drywall down and putting up clips and rails or green glue.  I have a feeling that would significantly increase the budget.  At this point I'm not sure what my budget will be for the room, so really all options are on the table at the moment.  That being said, if there will only be marginal improvements in sound reduction for certain techniques over cheaper alternatives, budget will certainly be more important.
I like the idea of an acoustically transparent screen with framing around it that is black GOM and is removable for easy access to the equipment behind the screen.  Stage wise, this floor is over a crawl space.  I am not sure it is a problem to have all that sand not over a slab, but those of you here with more experience can chime in.
BIGmouthinDC 03-16-2014 11:49 AM
If you know the location of your subs you can put a contained area of sand under the sub footprint and insulation in the rest and get a partial benefit. I would not put a ton or so of sand on a concentrated area over a crawl space.
Tedd 03-16-2014 12:31 PM
You could leverage the crawl space and put in bracing to carry the weight of a sand filled stage, if so inclined.
schmidtwi 03-16-2014 12:49 PM
Your budget will determine your options, decisions and results. You need to decide what your budget is, what your goals are and how much of the required effort you can do yourself.
DEEEEEEEZY 03-16-2014 01:23 PM
3 Attachment(s)
Well, lets say my flexible ceiling at this point is 15K.  Hard limit is probably 17.5K including the projector.  I expect that would place my room spending as follows.
15K - 2500 (projector) - ~1000 (screen) = 11500 for everything else.  The subwoofers were budgeted for already so that is not currently part of the equation.  Also at least for now I have all the speakers I will need.
Lets plan for a ~12,000 dollar room, and go from there.  If the budget ceiling opens up we can start talking extras.  As much of the room I can do myself the better since it will save money.
DEEEEEEEZY 03-16-2014 02:13 PM
3 Attachment(s)
The most up to date plan.  Top down view.
As far as the screen wall goes.  I saw one fella that made a theater that had a solid black wall from side to side with the only the screen on it.  I really liked the look of that as opposed to putting up columns on the sides and a big curving stage out front.  I game a lot, so likely the aspect ratio will need to be 16:9 as opposed to 2.35:1
 I'm liking the idea of wall to wall riser.
schmidtwi 03-16-2014 02:15 PM
With that budget, you have some good options to consider that can result in a great HT.
Tedd 03-16-2014 03:39 PM
When one mentions gaming, SOWK comes to mind.:
http://www.avsforum.com/t/1368295/2-35-1-pc-gaming-powered-by-lumagen
You should bring the seating forward and get the rear row off the back wall and create some separation
from the rear surrounds.
BIGmouthinDC 03-16-2014 04:43 PM
examples of screen surrounded by wall to wall black
DEEEEEEEZY 03-16-2014 05:06 PM
3 Attachment(s)
That bottom one is what I'm talking about.  I may not be a hundred percent on that stage/step at the bottom though.
And I like what looks like sound absorbing panels on the first one.
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
