AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Dedicated Theater Design & Construction (http://www.avsforum.com/forum/19-dedicated-theater-design-construction/)
-   -   Where is your a/v equipment? (http://www.avsforum.com/forum/19-dedicated-theater-design-construction/1523105-where-your-v-equipment.html)
Hockeypucks 03-18-2014 06:47 AM
I'll be framing my dedicated room shortly and I'm gathering as much advice as I can. Just wondering where most of you have your equipment and reasons for that location. I have plenty of space and options but the one thing I know is I want a clean front wall with nothing visible but the screen.
Plans are to build a false wall/AT screen so I'm not worried about speaker placement but not sure if I want the equipment inside or outside the room. It'll be about 14x25x7 and completely sealed. I live in Michigan so I have cold winters and the basement can get cold but I don't want to have the room get overly hot. I'd prefer the equipment inside the room for convenience purposes but if the heat is an issue I would have it outside.
Anyone regret putting equipment inside or outside their room? I only have an Onkyo 818, Emotiva XPA-3, belkin power conditioner and a Blu-ray player. Thanks for looking.
Aberk 03-18-2014 10:03 AM
I know I don't want to see the LEDs from any of my components, so my stuff will go behind the rear most seating or in a closet.
helmsman 03-18-2014 10:53 AM
I'm finishing up a remodel of my existing home theater and I have moved all my equipment behind the back wall in another room (accessible by a door in the back wall of the theater.) First of all I was shocked how nice it is to have zero projector noise, given that PJ noise never really bothered me before. But I agree with Aberk, I don't want want to see any lights or LEDs from my components, as pretty as they are (Marantz AV7005 processor, Oppo BDP-103 Blu-Ray player, Carver amps, Panamax 5300PM power manager.) Just be sure you have a good RF remote solution that you like. I'm quite happy with my Logitech Harmony Smart Control because I like to control everything with my iPhone. The only reason I ever need to access my equipment is to load or remove a Blu-Ray disc, which I could eliminate with a server solution ($$$$$ sigh)!
Hockeypucks 03-18-2014 11:00 AM
I guess the main reason I would put everything outside the room would be for heat management. I'd rather not have to buy expensive RF solutions so I'm leaning towards putting everything towards the rear of the room. I have over 900 Blu-ray movies so easy access to my player is a plus.
stockmonkey2000 03-18-2014 01:04 PM
I put my equipment in a rack just outside the theater door. I worried about not having access to at least the Blu-ray player, but it turned out to be a good decision. Having the lights, fans, heat, inside the theater would have been a major distraction.
rkinmoval 03-18-2014 01:42 PM
Where? Outside the room.
Reasons why? Fan noise and light distractions. I just finished building an HTPC. All of my media will be on it but realize I don't have 900 blu rays. smile.gif Additionally, as technology continues to evolve, more and more stuff works on wireless. I recently bought an Onkyo 929 and the remote app is pretty cool and I've seen some you can purchase for almost nothing that are even nicer. I'm still building my out my theater room and ran an IR repeater line that I picked up on Monoprice.com for a very reasonable price but have to wonder how much I'll use it. I have one now for my main floor set up and have been very happy with it.
Ultimately I'll likely go with the new Harmony. I've read a lot of good things about it and interfaces with smart phones and tablets. This ultimately leaves you with a very "clean" looking room.
Wahoo_envy 03-18-2014 01:58 PM
I installed mine just outside the theater in a wall shared by the storage room. In addition to all the reasons already stated, it is nice to stand behind the rack with good light while wiring up the equipment.
Hockeypucks 03-18-2014 05:00 PM
Wherever I decide to put it I'll have full access to the rear which is a must for future upgrades. Thanks for the ideas and input
Tfleming675 03-18-2014 05:43 PM
Under stairs for me.
doublewing11 03-18-2014 05:53 PM
Best location?
Just right outside you theater entrance door.........
Hockeypucks 03-18-2014 06:00 PM
Originally Posted by doublewing11 View Post
Best location?
This is almost exactly what I had in mind..
dhendriksen 03-18-2014 06:08 PM
^ That's almost exactly how mine is, but it's directly across from the theater door framed in to the wall. All the equipment for the whole house is there. One 37U reach in the wall, and a small (21U?) rack in the same area but not flushed in to the wall.
Sent from my Droid MAXX via Tapatalk.
iamjason 03-19-2014 08:00 AM
mine will be in the room next to the screen behind fabric panels on hinges. this gives me easy access but I cannot see the lights through the fabric. I do want to figure out a way to make my projector quieter not sure how to do that though
Hockeypucks 03-19-2014 09:26 AM
I like the hinged panel idea as well. Are you concerned with the room getting too warm from having the equipment there? Not sure how you can quiet down that pj though. I'm new to the projection world.
design1stcode2nd 03-19-2014 10:12 AM
If I had the space I'd do it outside the theater as well. Mine is to the left of the room behind a hinged "panel" covered with acoustic fabric. you can't see any lights but remote signals pass through just fine.
Hockeypucks 03-19-2014 10:29 AM
Very cool, thanks for sharing
iamjason 03-19-2014 08:07 PM
it was not an issue in our last home but this is a lot smaller and it does get toasty in there - when i start building i will add cooling fans, have the ac on a bit more and and will crack the windows to add some air flow - i don't have any other option outside the room so i will figure it out as i start building -
Hockeypucks 03-20-2014 05:37 AM
I suppose it does vary by room. I still think I like a rack built in to the back side of the wall. It's naturally cool in the basement year round so I don't think I'm going to worry too much about heat. It's mostly just me watching movies as well so I won't have lots of bodies heating up the space as well.
iamjason 03-20-2014 04:57 PM
I wish we had basements in fl...it seems that helps with temp control.
Hockeypucks 03-20-2014 07:57 PM
Yeah it's really nice having natural a/c but winters can get cold smile.gif Plus it'll help being underground so I can stretch the Emotiva's legs without bothering the neighbors.
Kamikaze13 03-20-2014 08:33 PM
I also have my HT in the basement and it is much cooler being down there. My equipment is located in the side wall behind my first row of seating. The rack is built into the wall in an mdf cabinet with a removable back so I can access it from the utility room. I also have an external fan venting out the top.
I often look to see what audio signal is being processed so I would just go nuts if I had my equipment outside the room.
Hockeypucks 03-21-2014 05:48 AM
I'm heavily leaning towards something like this. I too like to see my receiver at times, just not on the screen wall. You said you have a vent fan, what type? I built my gaming pc and have large, quiet fans but not sure how to power them in a system like what you have. Do you hear the fan while watching a movie?
Kamikaze13 03-21-2014 08:10 AM
I just rigged up a cheap coolmaster fan and wired it into my theater signs switch. I have it blowing into an insulated flex duct. It's not very noticeable at my main seating position, a higher end fan would probably not be noticeable at all. I don't notice the fan at all when watching movies, but my projector is right above my head so I do hear that during quiet scenes.
Some guys just plug into the AVR's usb port which turns the fan on when the receiver is on, which is what I will probably do when I upgrade the fan.
Hockeypucks 03-21-2014 10:21 AM
Huh, didn't know usb fans existed. I haven't spent any time researching this yet but I like the idea of venting the shelving unit I'll build. The fans in my tower are whisper quiet so it's worth looking into. Thanks for the info
design1stcode2nd 03-21-2014 12:08 PM
I used this for my rack cabinet:
http://www.coolerguys.com/840556093145.html
It's been running a year straight with no issues. I have the naturally cool basement as well.
Hockeypucks 03-21-2014 12:23 PM
Sweet, thanks for the link. I'll be adding this for sure.
roccoleach 04-16-2014 07:47 AM
21 Attachment(s)
I actually want to do this, but it feels so wrong because everyone has a separate room. One side is outside, the other a bathroom, and the back of the room the boss ( read wife) won't let me have because it's a kids playroom. Glad to see I'm not alone, I did add a return vent to ac system and plan on setting the fan to "run" when I'm in there.
roccoleach 04-16-2014 07:50 AM
21 Attachment(s)
Also, doesn't your sub rattle the heck outta the cabinet?
Expat444 04-16-2014 09:47 AM
Mine are split, I have one rack at the back of the room behind the bar with the amps etc., the servers are in another rack in the basement, the only fan noise I can hear is the projector......
Swervepf 04-16-2014 03:10 PM
4 Attachment(s)
Out of sight from the seats.... in a wall in the bar. The noisy stuff is on the other side of that wall accessible through a closet door.
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
