Basement Home Theater in New Construction On A Budget... - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #1 of 84 Old 03-23-2014, 10:14 AM - Thread Starter
BradP's Avatar
Quoted: 34 Post(s)
BP's Basement Budget Build - Groundbreaking 6/27/14
Hi all,Been reading threads and enjoying stories and photos of everyone's theaters for years now here at AVSForum, so I'm excited to be starting mine.I'm pretty good at planning but not at construction. So, I'm happy to be in a position where I am looking to have a new custom home built, totally from scratch. I am trying to stay on a reasonable budget as we're already close to our price limit as-is, so if it's built, it will be on a fairly small budget. The good news is that I've already got my projector, chairs, sub, speakers, and AVR so it's a start on things in that regard.The end result is that I may even just end up having the basic framing of the room done, with construction to come later, and if that's the case, I at least need to be sure I set all the correct groundwork for the builder and the plan. So I was hoping I could start there with a little help from any of you in the know or who have been there. Things I should do at a minimum NOW in order to have the room "ready to finish" down the road if the money runs out.Here's the initial plan the builder came up with. This guy builds whole homes but is not a custom theater specialist so I want to make sure I cover areas like rack location, wiring, speakers (built into wall or not), front stage with hidden speakers (yes/no), etc.This is just a rough but gives you a basic idea of what he's proposing. What I'm hoping for from you all is any red flags you might see. The dimensions look to be roughly 22 feet long but only 14 feet wide (the width is a minor concern but I still hope I can get 4 chairs in there and hopefully 2 aisles).Some feedback I am hoping for:- How are the dimensions and floor plan and would you suggest any changes that he might be able to make?- Are the two doors (double in the back, one in the front) too many?- Where can I put the equipment rack?- Can I fit two rows of seating in as well as a back bar with only 20 feet?- Should I build a stage?- He suggested sconces and floor lighting, I was thinking maybe just overhead cans to reduce clutter and keep costs down, is that typically the way things are going?I do want to put as large of a screen in here as I can. I am a BIG SCREEN person and have found that even going beyond the recommended size at sitting distances within reason is actually better for me. Plus, the second row can always be used as a default by anyone who thinks row 1 is too close.With the room length only around 20 feet I'm afraid I may not be able to do this, but what I'd love is to be able to get those 2 rows of 4 chairs plus a back bar).My hope is to keep this thread alive throughout the entire construction so that it can be referred back and a useful resource to others as well, so I will keep an active diary here as things progress.I've used this thread as an inspiration for a look I'd love to have: http://www.avsforum.com/t/1520803/ht...insway-theaterThanks for any insight, and even if you are just lurking, I hope to be able to share useful tips and a good story as this all comes together.Brad
BradP is offline
post #2 of 84 Old 03-23-2014, 07:27 PM
Quoted: 3017 Post(s)
Liked: 2541
double doors on the back wall limits the theater to one row of seating.
Stick the equipment rack under the stairs in a in-wall rack
two rows and back bar in 20, no.
If you intend to use aggressive soundproofing techniques use isolated framing methods
post #3 of 84 Old 03-23-2014, 07:32 PM - Thread Starter
BradP's Avatar
Quoted: 34 Post(s)
Jeff! My first response, thanks so much.
I can't believe I didn't think of the stairs as a perfect place for the equipment. Would you typically recommend to have the access from the theater side, or from the opposite side outside, for a cleaner wall?
As for the double doors in the back, I can easily have them taken out and a solid wall there, I'm sure. Not sure why he wrote it up that way. Just curious though, how do the doors on the rear wall eliminate a row of seating?
I thought I might have to sacrifice the back bar, but hopefully I assume I could at least get 2 rows of 4 seats in there then at least?
Thanks again for the reply.
BradP is offline
post #4 of 84 Old 03-23-2014, 08:13 PM
Liked: 2541
Some planning guidelines screen to back of first row of seating 11 1/2 to 12 ft
back of first row to back of second row. 6 1/2 ft assuming reclining theater seating.
so that is 18 to 18 1/2 ft leaving 1 1/2 to 2 ft behind the last row of seating and the double doors, not enough for a walkway.
did you want a false wall up front and an acoustically transparent screen wall? that takes some space
post #5 of 84 Old 03-24-2014, 02:46 PM - Thread Starter
BradP's Avatar
Quoted: 34 Post(s)
From one fellow northeasterner to another, thanks. This winter probably had you loving being inside watching your own theater. You are asking all the right / tough questions and I appreciate it. Now before my builder gives me any final plans for this whole house is the time I need to at least be sure I have this room's dimensions right. It's funny, I could care less about the bedroom dimensions, but this theater room needs the right planning.
Good point about the doors. Even if I have them open outward if there's only 1.5 or 2 feet in the back, that's a narrow walkway that I don't want. Bummed that I won't be able to do the bar but I definitely want the two rows of seating.
I'd love to put a 140" 16:9 screen in there and would also like to do it with acoustically transparent material. I'm still reading up on how to build that front wall/stage area but I'd like to put my speakers (Large paradigm towers and center, and klipsch sub) behind a fake wall. I'm wondering if he might be able to angle out an extra 1-2 feet and bump that out to not take space away from the room itself. I'll have to ask. Would an extra 2 feet be enough?
I really appreciate the dimension advice. My chairs do recline and while I've yet to measure the space needed for a fully reclined chair in row 2 to not hit the top of the chairs in row 1, your 6.5 feet sounds about right. The width of 4 chairs of the type I have (Berkline microfiber) is 9 feet 8 inches which will only leave around 4 feet (2 on either side) so I may even be already pushing it with the aisles too.
I never thought it would be so tough to fit just 2 rows of 4 chairs in a 22x14 room!
BradP is offline
post #6 of 84 Old 03-24-2014, 04:44 PM
jautor's Avatar
Quoted: 1124 Post(s)
Liked: 738
1) Room dimensions are obviously the main thing - can't change those after the fact. And that includes placement of doors / hallways / equipment areas.
2) Electrical - get enough dedicated circuits brought to the room and accessible for both powering the equipment / projector, but a number of light sources.
3) HVAC - Must have a return in the room, and plan for a heat load like a kitchen. Make sure your system can provide adequate cooling to this area, perhaps even in the winter. Zoning the room can work, too, if you size the HVAC system(s) accordingly.
Everything in that list except the rack placement (and the power for it) can wait until you're ready to build the room.
Yep, as BIG said, those dimensions are a red flag. My room is 16' x 22', and I barely fit 4 chairs in with 2 aisles. I have a bar row behind two rows of recliners, but no AT screen and my middle riser is "too shallow".
BIG answered most of your questions, but I'll add my pair of cents...
Not with two rows of theater recliners. My room is 22' deep in that configuration, and it could really use another 1-2' of depth overall if I did it again...
Personal preference, but that will depend also on your front speaker choices and placement. If you go with an AT screen, you'll want the stage for aesthetics and to keep folks naturally away from the screen.
More light sources at lower levels are better for theaters. In my room, there are six lighting zones and I would have liked a seventh. Sconces can be trouble depending on the design you choose - because they can throw light out into the room and onto the screen - so they may have to be turned completely off while the movie is playing...
You can go too big - the best choice is to wait. Get your room set up and projector in place - throw a movie onto a white wall, cheap fabric or super-easy photographer backdrop paper and see what screen size is "right" for you. While some folks will like sitting in the front or the back - you don't want the image to be so big or small that folks actively avoid half of the seating area.
Jeff
jautor is online now
post #7 of 84 Old 03-25-2014, 07:16 AM - Thread Starter
BradP's Avatar
Quoted: 34 Post(s)
Jeff,
First of all, thanks a ton for taking the time to respond. I appreciate you taking the time to help out!
Your initial 3 tips are great, especially #2 and #3 which my builder may already know, but that I need to make sure I inform on, in case a HT room isn't one of his usual extras. One other interesting point someone came up to me with -- Some real estate agents seem to think that hiring an independent contractor (HT specialist or otherwise) to finish the basement AFTER the house build is done (just roughing in the basement walls), is cheaper than having it fully built by the contractor with the house. I always figured having it done with the house was going to be the best way, but maybe this is something else to consider. If there's no way to build the right room for me with this floor plan, we may need to scrap it.
I'm posting the entire downstairs floor plan (should have done this to start) as I'm growing more concerned that the room dimensions are going to be an issue from day one, and I'm curious if anyone sees any other possibilities beyond just expanding the entire square footage of the basement (and as such the whole house above). Starting a room from total scratch in a new house that is going to be problematic for space doesn't make a lot of sense to me. It sounds like you've got an extra 2 feet of width that I don't have here, and even you are having the issues I don't want to have.
Stage/AT: My front speakers are large Paradigm towers and the center is quite large as well. AT will obviously look the best here. I've been looking at some photos of a stage and sand and that certainly looks better. I don't think that the AT part is something my builder will handle or know how to do, so I need to research how difficult that piece of work is for a novice to do.
Lighting: Most of the photos of theaters I have seen here and liked were all overhead lighting only so I see no reason not to do the same thing. Probably more expensive but I prefer the "cleaner" look (hence the AT screen too).
Screen: So it seems like as long as I place my projector/mount (a BENQ W1070 currently) at a location that will support the range of screen I am looking at, the best course would be to have the stage and cutout for the speakers done by the contractor, and then to handle the fake AT wall on my own after he's done and out? Hang a sheet, dial it in, then build the screen/wall as the last phase of the room?
BradP is offline
post #8 of 84 Old 03-25-2014, 10:09 PM
jautor's Avatar
Liked: 738
Nope, don't buy that at all. It won't be cheaper - the builder has all the trades already there doing each part of the house - adding another few hours of work with materials and people already onsite is cheap. But that assumes you're ready and they fully understand the various theater-specific aspects of the build. In my case I finished the room post-construction for lots of reasons - capital was tied up in my previous house and I was fully consumed with the rest of the house planning / buying and there's no way I could have got all the details right.
One thing I would have done, though, during construction would have been to have the builder buy and stage the drywall inside the room - having all that material brought through my finished house a year later was nerve-wrecking (although the crew did a fantastic job and didn't put a scratch anywhere).
Yep, I did the same thing in my home design - tried to save any square feet that I could - in hindsight, the house would have 5% more footage - and it wouldn't have added but probably 2-3% to the cost.
No, that wasn't extra - it was REQUIRED. Doing it over I would have another foot of width "extra" at least, to make the aisles wider (meaning a room 17' wide).
It's easy...
Just investigate the lighting control - get all those sources wired into good zone/groups, and bring everything to one location so you have good options for control systems. The GrafikEye is the go-to unit for theaters, and it requires a 4-gang, deep box...
What cutout?
False wall can easily be done after the fact - but I'd probably have the builder do it - at least some framing and perhaps finish above the screen with a partial wall / soffit so that the room trim is all done properly?
post #9 of 84 Old 04-08-2014, 06:22 PM - Thread Starter
BradP's Avatar
Quoted: 34 Post(s)
I'm back, after some uncertainty around the build process it's looking again like it's on, so discussions with my builder around the theater are about to resume. And I've got a more current version of the plan as it stands. He doesn't think there's any way to widen the room due to the stairs, but he CAN lengthen the room a bit to allow me room for the acoustic screen and speakers behind as well as to compensate for what looks like an odd cut in at the lower right corner of the image there (ugh). Of all the rooms in the house THIS is the one I have to get perfect for dimensions, the rest hardly matter, though this is the spot the theater has to be in relation to where everything else has gotta go. Otherwise it's time to scrap the whole plan.
So please take a look and let me know if I can make this work...it might be tight but with my chair dimensions coming in around 10 feet across for 4 it does look like I can have around 2 feet of aisle on each side. Maybe not ideal but at least enough to get in and out?
Anyway have a look. The cut in bugs me but given that it will be open space up there anyway, if I can bump in the opposite side to match it may not be all that bad, but the screen will still need to sit back in, I can't lose all that room length and put the false wall at what looks like about 4 feet in.
Jautor, I haven't responded yet though I read this a while ago and appreciate it.
I'm actually considering just that about your comments regarding the detail of the theater at the end, love that idea and might even be able to have him wait to do this room last or even after we move in, if possible. Dimensions on the plan (especially width) remain a small concern but everything else as far as location, the stairs as a spot for the AV closet, and the length, all very appealing.
Thanks for the comments on lighting, I am hiring my own electrician to handle the entire house (not my builder's) and it's someone I can really work with so that will hopefully make it easy to communicate what I need with him, but I want to make sure all that planning and wiring is there and accounted for in the build as well.
When I said cutout I more meant a bumpout for the false wall, but the more I see it, you basically just frame it in there at the build and then add the screen yourself at the end. I might even see if there's a way to build my screen ahead so I know the dimensions and can at least have the builder frame out and finish the rest. Is there a standard typically for how many feet you want behind the screen that I can pass on for the plan?
BradP is offline
post #10 of 84 Old 04-08-2014, 06:46 PM
Liked: 2541
Please don't put your chairs in that configuration. You just made 2/3 of your seating lousy seats. Sitting close to side walls gives you a terrible sound experience and a less than optimal viewing position.
post #11 of 84 Old 04-08-2014, 06:48 PM - Thread Starter
BradP's Avatar
Quoted: 34 Post(s)
Jeff,
You know what, that's a really good point. So what's the solution? How much space do I need on the left and right side of the room in order to make a 4-seat row (10 feet wide) work properly for everyone?
BradP is offline
post #12 of 84 Old 04-08-2014, 07:25 PM
Liked: 2541
The tightest seats I'm familiar with are the fusion Jives and here are the specs. You can easily do two rows of 3 of many different brands and models You can do a row of 4 with 27 inch aisles with the Jives. One other strategy is to take out the arm rest in the middle for a center love seat.
http://www.rtheaters.com/FusionCollection/images/FC-Jive-1013.pdf
post #13 of 84 Old 04-08-2014, 08:00 PM - Thread Starter
BradP's Avatar
Quoted: 34 Post(s)
Oooh you know what I like that idea, center love seat and that will give me more space, plus it looks like I was only at around 9.5 feet with my current seating and all armrests...So maybe we can get there. I appreciate your information, this has been really helpful to avoid any immediate problems before the first saw is picked up and the first nail put into place!
BradP is offline
post #14 of 84 Old 04-15-2014, 06:48 PM - Thread Starter
BradP's Avatar
Quoted: 34 Post(s)
Jeff,
Given that The Rawlinsway Theater is really my inspiration and represents very closely what I want my builder to do, if there are any plans you might be willing or able to share, regarding most especially the spacing you used as far as the front wall and speaker space, stage spacing, riser spacing...I'd really appreciate any detail that I might be able to pass onto my builder. At this point I'd say we are still a month away from breaking ground, but the home theater room is the one I want to watch the closest during construction.
I'm waiting on a new plan now to get some extra width and length to the theater to accommodate both the back bar and room to use an acoustically transparent screen up front to hide the speakers and subs. So knowing what sort of dimensions I need to give to the guys doing the actual work on the framing out of the walls, ceiling and floors/stage/riser would be beneficial, since they are not custom HT specialists. I should be able to handle a lot of the work involving the wiring once I know where my equipment and speakers will be.
Thanks for any insight you might be willing to share. I'm also going to go through your build thread top to bottom to see what I can learn.
The end result will likely not be quite as beautiful, but given that the dimensions and elements I have are similar, it is a great template from which I'd like to build out.
BradP is offline
post #15 of 84 Old 04-15-2014, 07:11 PM
Liked: 2541
Brad I would get the dimensions the same place you can, I've listed the critical dimensions in the build thread and the theater of the month article. From memory screen wall to wall is two feet, riser is 11 1/2 ft from the screen, bar is 6 1/2 ft from the front edge of the riser, room size on the first page of the build thread. I think his first row of seating was 120 wide the second 126.
post #16 of 84 Old 04-15-2014, 07:25 PM - Thread Starter
BradP's Avatar
Quoted: 34 Post(s)
Thanks Jeff, I have been sponging up tons from the forum over the past few days as we get closer to reality. The information you have provided to so many across the board here is phenomenal. Just wanted to say thanks for all you have done to further the hobby and the dream.
BradP is offline
post #17 of 84 Old 04-15-2014, 08:45 PM
thestoneman's Avatar
Quoted: 126 Post(s)
Liked: 47
BIG, what would you say is the minimum distance from the side wall you would place seating? I have a 14' width I am hoping to squeeze a 4 seat/120" row.
Sorry for the hijack question, but seems applicable to this thread.
My Theater Build
Equipment List: Denon X5200, Epson 6030, 120" Carada cinemascope screen, Panamorph U480, Oppo-103, Emotiva XPA-5, SVS PB12-NSD, LSA Statement LCR & surround speakers, Def Tech ProCinema 1000 rears, DefTech DI5.5R Atmos overheads, Grafik Eye 3106
thestoneman is offline
post #18 of 84 Old 04-15-2014, 11:08 PM
Liked: 2541
Take a handy chair and place it 24 inches from a wall, are you comfortable walking in that gap? It is different for everyone.
Another trick is to cheat a little, if one side of the room will be the normal walkway leave that at 28 inches and the other at 20
post #19 of 84 Old 04-16-2014, 07:45 AM
Quoted: 126 Post(s)
Liked: 47
20" is OK in terms of sound? I don't think it's a problem getting by...the only concern is the sound getting funky on the end chairs.
If you're only 20" from the wall, would you alter the height you mount your surrounds?
My Theater Build
post #20 of 84 Old 04-16-2014, 03:42 PM
Liked: 2541
the end seats, are for the in-laws. Obviously sitting close to side surrounds is a problem, you can increase the distance by putting them high. You are the one who wants 4 seats across. if you do three there will always be one seat in the perfect sweet spot.
post #21 of 84 Old 04-16-2014, 08:36 PM
Quoted: 126 Post(s)
Liked: 47
Well, one seat in the perfect spot sounds awfully nice to the guy doing all the work and paying for it!
My Theater Build
post #22 of 84 Old 04-17-2014, 01:00 AM
Dizzy49's Avatar
Quoted: 28 Post(s)
Liked: 30
I've been struggling with the 3-4 seat issue as well. I want 4 for a variety of reasons, one of them is that we have two kids that will want to sit next to us or ON us smile.gif
I'm trying to do some math and understand a few things...
1) Seating should be placed in the middle of the room, not offset on one side or the other
2) Need approx 27" walkway on each side
So, if we start with a 14' room, and add 12" columns for speakers on each side, I assume the 27" is from the outter edge of the columns, not the wall. So, we now have 12' to work with. Add 27" walkway on each side, and that's another 4.5' lost and you're left with approx 7.5' (90"). The 3 seat config BIG linked to would fit nicely. You might be able to squeeze 4 seats in if you have two armless recliners in the middle. Also means no cup holders though, that would be 97.25", so you'd have to shave a few inches elsewhere.
Sean Hull
Denon 3808ci | PS3 80Gb | Harmony One | Toshiba XA2 | Samsung 61" PN60E6500EF | HTPC with HDMI
Dizzy49 is offline
post #23 of 84 Old 04-17-2014, 06:06 AM - Thread Starter
BradP's Avatar
Quoted: 34 Post(s)
Sweet spot seating is definitely important. I'm envisioning a 2 person loveseat style setup for front row center for the wife and I (or just me to strech out) and then singles on either side, then 4 individual seats in row 2, followed by the back bar.
We've got the room dimensions up to a more comfortable 15' 3 1/2" wide by 27' 2" long (but the length will lose a couple once we have the false front wall up for the acoustic screen). I'll post full dimensions as well as a new photo of the plan, where I intend to have the risers put, etc, soon.
Since my builder is an excellent home builder, but not necessarily an advanced theater builder, I want to make sure I think of everything I need done up front, from placement of wiring, power outlets, and anything else that needs to be thought of ahead of time, so he has these details in his mind (and on paper) before he starts framing up and working in the room. The rest of the house is getting built at the same time but I expect to be putting half my attention to just this room to make sure everything is thought of ahead of time so there are no surprises when the walls are up and we missed something critical.
BradP is offline
post #24 of 84 Old 04-19-2014, 09:08 PM - Thread Starter
BradP's Avatar
Quoted: 34 Post(s)
Okay, I'm back with new dimensions from my builder. Photo is below. The theater is now 15 3 1/2 by a nice 27 foot 2 feet long. Wasn't able to get any wider and I realize that's a bit on the long side, but given that I want to do a false wall in the front for an AT screen (I assume 2 feet lost there?) and a back bar, and probably start the first row back at least 11 feet, I think this will work for 2 rows of seating and a back bar, and still have some room at the rear doors.
The ceilings will be 9 feet downstairs so I'm not too worried about the crossbeam getting in the way of the image, but the block over the 2nd row of chairs on the right I believe represents a support pole, which worries me somewhat.
Thoughts welcome.
If I decide to take the plunge and have this in my new build, I'll definitely have a lot of questions here (or in a new thread) as I think my builder is an awesome custom home builder without a lot of home theater experience, so I want to make sure I am getting him as much detail as I can about stuff he needs to do before it's too late. What I need up for the false wall, what I need for soundproofing, what I need run to the closet under the stairs as far as power and wiring, etc. His initial thought was "a couple sconces on the wall and some rope lighting and a riser" and I want to make sure that the other important details don't get missed before it's too late and the drywall is up.
BradP is offline
post #25 of 84 Old 04-20-2014, 05:27 AM
Liked: 2541
It looks like the support pole can be buried in the wall, as long as they do a good job measuring. As drawn it is. I see them all the time. If the builder is finishing this room it has proven extremely difficult to get them to take the soundprooofing measures you might like.
post #26 of 84 Old 04-21-2014, 07:54 PM
kmhvball's Avatar
Quoted: 445 Post(s)
Liked: 260
You may want to ask about sinking a portion of the room even lower, usually below main floor level , then the main floor can be the riser. We built our house 18 months ago and wish I knew of this forum then. You could also ask about a triple sill plate, which makes the basement a full 9' tall. Typical construction is a 9' wall, then the slab is poured about 3-4", resulting in a little less than 9' ceilings.
Good luck!
kmhvball is offline
post #27 of 84 Old 04-24-2014, 06:03 AM - Thread Starter
BradP's Avatar
Quoted: 34 Post(s)
Kevin - Hadn't even thought of asking if he can do the floor a foot lower in the main area so the riser can be at basement level. Interesting idea and worth the ask unless the cost changes. I like it. Good call on the ceiling height too. I would like the full 9 footers especially since I think in some spots it will have to drop to conceal steel beams (both in and out of the theater).
Jeff - Good to know about the pole and the potential soundproofing issues. So what's it going to cost me to have you drive up here to Central PA a few days and boss people around and get the job done right? smile.gif
BradP is offline
post #28 of 84 Old 04-24-2014, 07:18 AM
kmhvball's Avatar
Quoted: 445 Post(s)
Liked: 260
One example of the dropped floor is the Cinemar theater build.  I have seen a few others on this site but don't recall exactly where.   A friend of mine building a house in my same sub-division just did this on their's as well (it is under construction).   One thing to consider when you assess the 'cost' factor is making sure to compare against the 'cost' of the Riser if you were to do one.   Also, this gives 10'ish ceiling height and then with the riser seating, still with 9'ish foot.    If you are planning to put in any soffits, then, with a 8 '8" start height, 8" soffit drop (can be a variety of heights) and 12" ish riser, you start getting into a 7' tall floor to 'soffit' height.
You'll want to make sure they aren't putting support poles in the theater area to support I-beams.   If they say they 'have to' that is b.s., they can use a thicker guage I-beam that spans the distance easily.
If cost weren't a factor, I would look into the dropped floor, and trying to get the I-beam in that area.   Frankly, with your planned screen wall and rough seating distance, this looks close as it is.  To do this, they should be able to space floor joists closer together, use a better wood, uses floor trusses, or make the wall with french doors a load bearing wall, etc. to achieve this.   I wish I could always spend other people's money and not my own!
I see your double doors, I don't know tons about sound reduction, but having a single set of double doors I think can be somewhat challenging.    I am doing two parallel 2x4 walls with two, single width, doors opening different ways to help with the sound (one opening into main basement, one into theater, this is called 'communicating doors' I believe).   There is a soundproofing thread on this forum, in the Dedicated Theater Build Sticky post section, and the 'benefit' I understand from the double walls & two doors, is you can use relatively normal solid 1 3/4" doors on each side and with seals, get the same sound reduction benefit as the wall structure itself.   Of course, if sound transmission isn't a big deal in your situation, then that is a waste of space & money!
kmhvball is offline
post #29 of 84 Old 05-17-2014, 02:49 PM - Thread Starter
BradP's Avatar
Quoted: 34 Post(s)
Thanks for the input on the double doors and the I-Beam. We're getting a 9' height before finishing down there so we're figuring 8' 8" where there's no duct/beam and 7' 8" where there is (loss of a foot). I still think 7' 8" will not interfere with the projection (even though my unit, the Benq W1070, doesn't have a lens shift, vertically I should be able to still hit the top of the screen from there).
I'm building the place in the hopes this room stays as theater forever but another good point was that it would be nice if this room could be stripped out and re-purposed down the road, so in that case using a riser makes more sense. Cost is also cheaper than pouring the slab deeper for the bottom row.
I am interested in seeing if there's any way to get that i-beam out of there. I don't think it will be an issue with the 9 foot ceilings (projector will be mounted behind it), but still, no beam is better than having a beam I guess.
I'm attaching the final spec as it's drawn up pre-construction (breaking ground in a month) so if anyone sees anything else we can do on the cheap (trade off) to do things better, please feel free to chime in, I won't be offended. This is a housing contractor doing this work, not a specialty theater builder, so I may need to nudge him the directions we need to go.
Seat position is obviously not accurate, maybe not even the rear bar wall. Rough calculations currently happening. I'm figuring 2-3 feet for false area behind screen and 4-5 feet behind back bar. Hopefully 11 feet from front of front row chairs to screen. 2 feet 8 inches roughly on either side. Final measurements still to come.
As far as lighting, I am using the Rawlinsway theater as inspiration, so I intend to have all ceiling lightning, no sconces or rope lights. As such this will likely just be 3-zone (screen, back area above bar, and center/left/right main room area as the 3rd). I may be in overkill mode but I impulse-bought a Grafik Eye GRX-3106 for $300 on ebay. Too much? Not enough? I don't need a ton of scenes but basic scene ability and control via my Harmony 900 are the ideal here. I intend to mount the keypad somewhere near the rear entry doors for ease of access when coming in.
Any suggestions or OH NO type things at this stage, I'm all ears. I'll soon be sharing with you my detailed low and high voltage wiring plans for the room.
The goal here is too see how cheaply I can still put together a nice theater. Since this is just part of a whole house, I can't go all out, spare no expense as others have here, but I still think I can find a way to do this nicely and budget-friendly, hopefully with your help (less mistakes!)
Thanks all.
B.
BradP is offline
post #30 of 84 Old 05-19-2014, 07:44 AM
Tedd's Avatar
Quoted: 814 Post(s)
Liked: 308
A $300 3106 is a very nice piece of bling, for a budget room!
With your nine foot ceilings, have you considered entering at theater riser level, by having a large
landing at the end of the stairs?
Tedd is offline
