Stage Question - Final construction - Sand - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 04-12-2014, 06:21 PM - Thread Starter
smiddleton5401's Avatar
Quoted: 48 Post(s)
Liked: 24
I think I know the answer already frown.gif but do I need sand in both sections of my stage?
Here is the full stage - The top is not attached yet.
smiddleton5401 is offline
post #2 of 19 Old 04-12-2014, 06:47 PM
Quoted: 3255 Post(s)
Liked: 2743
Obviously the part of the stage where the speakers sit is the top priority. If your body isn't willing to fill the rest than you do what you can, fill with insulation. Are you going to carpet the stage?, if yes you should have a lip and it can be added after the fact.
Last comments, you should drywall the room before building the stage and risers, trust me it is easier and better for sound containment. Be sure the stage doesn't touch or is otherwise connected to the rooms framing. Also best practice is to put a barrier between concrete walls/floors and untreated lumber. I see regular plywood sitting on the floor. I would put down a layer of roofing felt.
post #3 of 19 Old 04-12-2014, 06:59 PM
Liked: 2743
I looked at your pictures again, you are planning to build some walls aren't you?, you need to frame them first. I don't see any room to frame the front wall.
post #4 of 19 Old 04-12-2014, 07:40 PM - Thread Starter
Quoted: 48 Post(s)
Liked: 24
Unfortunately, I had a novice helping me in the beginning. The stage is only a few inches from the rear wall (concrete). I was going to seek help on what to do for the front wall next. I wonder how to decouple it; wall attached to the stage top after filling it with sand while decoupling from the ceiling?
I wish I had this forum resource when I had the traditional framer follow the design:
post #5 of 19 Old 04-12-2014, 07:45 PM - Thread Starter
Quoted: 48 Post(s)
Liked: 24
The stage is decoupled from the side walls but unfortunately it was set with construction adhesive to the concrete slab (no roofing felt underneath)
post #6 of 19 Old 04-12-2014, 08:16 PM
Liked: 2743
Frankly I'd rip it out and start over, it is that bad. I doubt it is glued so tight a crowbar couldn't get the job done before the first coffee break. For one thing lets assume at some point you want to convert the room to another use, the wall is sitting on the stage? no way.
post #7 of 19 Old 04-12-2014, 08:24 PM - Thread Starter
Quoted: 48 Post(s)
Liked: 24
Ugg, I thought it might be that bad. I plan to stay in the house I built for my whole life so I want the theater done right. It's the only room I have left for me : ) The house full of girls (my wife and two daughters) took over everything else.
As close as you are to me, maybe you're looking for another client?
post #8 of 19 Old 04-12-2014, 08:34 PM
Liked: 2743
I'm booked for a bit for hands on work but I do Skype consulting in the evenings.
Here is what the stage framing should generally look like.
another:
smiddleton5401 likes this.
post #9 of 19 Old 04-12-2014, 08:45 PM - Thread Starter
Quoted: 48 Post(s)
Liked: 24
Yeah, I see the shortcomings by comparison. I'm going to see if it can be disassembled to have it forward enough for a proper wall assembly with clips, GG, DD, etc
If you know of someone good near the Montgomery County Maryland area you work well with, let me know.
post #10 of 19 Old 04-13-2014, 05:00 PM - Thread Starter
Quoted: 48 Post(s)
Liked: 24
I don't know much, but I've seen enough of his builds and advice to listen to BIG.
I fear I will have to move out and redo the rear riser as well:
post #11 of 19 Old 04-13-2014, 05:13 PM
Liked: 2743
I would, that may not be tall enough anyway. Risers should have at least two layers of 3/4 decking (keep it quiet) and be filled with insulation. Built on roofing felt of course. unless those were Pressure treated sleepers.
post #12 of 19 Old 04-13-2014, 05:23 PM - Thread Starter
Quoted: 48 Post(s)
Liked: 24
They are 2x6's on top of pressure treated with about 1.5"- 2" of gap from any walls. I'm limited to the height of the platform coming off the steps leading into the theater from the other hallway. There is enough room for 2 layers of 3/4" decking though. The pictures only show temporary decking to move around; its not attached yet.
post #13 of 19 Old 04-13-2014, 05:41 PM
Liked: 2743
Make it a two level riser, the entrance level and the seating area, use step lights if you plan on having guests.
I'd have to see the entrance maybe you could step up to the final level outside the theater first
post #14 of 19 Old 05-29-2014, 07:51 PM
Cthanatos's Avatar
Why roofing felt? I've seen that elsewhere too, but what's the reason/science behind it? Also, how far away from the walls should stage be? Does the carpet and sand just keep it in place then?
Cthanatos is offline
post #15 of 19 Old 05-29-2014, 08:19 PM
kmhvball's Avatar
Quoted: 496 Post(s)
Liked: 275
I am leaning towards a two level riser now as well... The first being the height of the last step into the basement, carried into the theater room. This will make for slightly more head room under soffits... The 2nd will be contained essentially inside the footprint if the initial riser to contain the 2nd row of seats at a higher height. The main riser, already being step height, would then step down to the first row floor level. I may still extend the ends of the riser to go past the rear of the first row.
kmhvball is offline
post #16 of 19 Old 05-29-2014, 08:50 PM
Cthanatos's Avatar
Answered my own question about the sand -
3. 4 or 6 mil plastic in cavity and fill the the top with dry play sand.
Q. is the weight of the sand what actually keeps the floor in place in lieu of attaching it to the concrete?
More importantly it makes stage accoustically dead - no/little resonance from stage. But yes, my 12' x 4' x 6" stage has nearly half a ton of sand in it and it inst going anywhere. My stage is not that large.
post #17 of 19 Old 05-29-2014, 09:42 PM
Cthanatos's Avatar
Dennis menioned in a couple threads I've read
 Be sure your subwoofer(s) is (are) very firmly anchored to the platform.
How exactly would they be anchored? I keep thinking that I'll just end up setting my speakers on the carpet for the front, and others higher around the room.
post #18 of 19 Old 05-30-2014, 04:45 AM
Liked: 2743
I've never read that instruction and I've never anchored a sub. I use gravity and the little knobby feet dig into the carpet. Another method is to put spike feet on the bottoms.
post #19 of 19 Old 05-30-2014, 03:32 PM
Cthanatos's Avatar
Ok, that's what I was planning, but I couldn't for the life of me think he would mean to literally anchor it to the platform with screws and such. But it is Dennis, so I wanted to make sure I wasn't just being ignorant. Thanks BigmouthinDC!
