System recommendation from my local installer - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #1 of 54 Old 04-16-2014, 09:24 PM - Thread Starter
richardorser's Avatar
Quoted: 16 Post(s)
Friends,
My apologies if I have not chosen the most appropriate forum.
My local audio/video dealer has suggested the following to update my old Knoll/Panasonic DVD/Harman Kardon amp projection system
Epson Pro Cinema 4030 Projector (Includes mount & extra lamp) $2,599.00
Oppo BDP-103D BluRay Player $599.00
Ultralink (HDMI) (Estimate Only) 250.00
Misc. Parts (Estimate only) 50.00
Labor (Estimate only) (2 Men) 750.00
I would be sincerely grateful to hear your comments on this selection of equipment. I watch only Netflix discs on this system and have a DaLite 8' wide Cosmopolitan screen about 14' from the projector.
I may also wish to stream Netflix movies. But, in any case, I only watch movies, i.e., no TV or other media.
Thank you very much, Richard
Richard, Santa Cruz, CA
richardorser is offline
post #2 of 54 Old 04-17-2014, 05:46 AM
ClayliketheDIRT's Avatar
Liked: 24
If that Ultralink you list is only an HDMI cable I would say he is over charging on that. I personally would never pay that for an HDMI cable. Its only transmitting a 1 or a 0. You would be fine with supplying one yourself from monoprice. I don't see why it would take two guys to install that either.
Just my two cents
ClayliketheDIRT is offline
post #3 of 54 Old 04-17-2014, 06:01 AM
Quoted: 3258 Post(s)
Liked: 2744
cable should be under $50
you didn't mention ceiling mount
How difficult is it going to be to pull in the HDMI cable. Is there a conduit in place? Are they cutting drywall, patching and painting?
You are paying for the full day for two guys, shouldn't take but a a half a day.
Basically you are paying close to $1000 to install a projector, most of us DIY.
post #4 of 54 Old 04-17-2014, 01:02 PM - Thread Starter
Quoted: 16 Post(s)
Thanks. I certainly agree about the cable--which may be indicative of overcharging on the other items as well.
Monoprice is fine by me.
The guys like to work as a team in case they have to pull wires. I will be charged only the time they actually spend.
post #5 of 54 Old 04-17-2014, 01:04 PM - Thread Starter
Quoted: 16 Post(s)
Yes, I will confront them about cable costs. Digits are digits.
I have an existing projector system, as I said, but there will be additional wiring from my computer to the BluRay player. The labor will be actual hours spent. I am trying to do as much as possible of it, like the conduits, to keep their charges to a minimum.
Any idea about the projector or player? Or, is that better asked in another forum section?
Thank you, Richard
post #6 of 54 Old 04-17-2014, 04:31 PM
Liked: 2744
discussion about that projector, Mike Garret weighs in and you may want to reach out to him for his pricing on Epson Projectors. I'm hanging a 5030 tomorrow, if the mount arrives.
http://www.avsforum.com/t/1495845/epson-4030-showing-and-value/0_40
post #7 of 54 Old 04-17-2014, 10:36 PM - Thread Starter
Quoted: 16 Post(s)
Thanks Jeff. That's a big help.
post #8 of 54 Old 04-18-2014, 04:26 AM
Liked: 2744
Why can't you install the projector yourself?
post #9 of 54 Old 04-24-2014, 10:57 PM - Thread Starter
Quoted: 16 Post(s)
Here is the response I got when I mentioned the very pricey HDMI cable they intended to use:
"Nate looked at the Monoprice website you attached with the HDMI cable. That cable is basically the lowest line of HDMI cable out there, its not 4K compatible. This is nothing in comparison to the HDMI cable that Nate has quoted. Its like driving your Ferrari on the cheapest tires & cheapest gas possible. Do you really want to run your $3,000 projector on a $27 cable? "
What's this about "4K compatible"?
Thanks, Richard
post #10 of 54 Old 04-24-2014, 11:25 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 938
Thanks, Richard
Wow, I wonder what your dealer would say when I'm using one of those cheap Redmere cables from Monoprice on a $25,000 projector? I over budgeted though.......I think my cable was $54! eek.gif
doublewing11 is offline
post #11 of 54 Old 04-25-2014, 05:25 AM
Liked: 24
I am running my 5000$ project on a monoprice redmere cable as well. Like I said before it's a digital signal you don't need to be sending it down an eight gauge wire. IMO and most others peoples here are trying to tell you, your seller/integrator is over charging you. That is were he make the biggest margins, cables. I am willing to bet that some of the people that have suggested this to you in your thread, have more experience in hooking up dedicated theater rooms than your supplier.
I am not trying to be an a$$ just trying to make sure you are satisfied and your original question is answered (are opinions on equipment). Your better off saving $150 on that and spending it on a nice universal remote to run you new system.
post #12 of 54 Old 04-30-2014, 11:30 AM - Thread Starter
Quoted: 16 Post(s)
Thank you so much for giving me the knowledge and courage to confront the A/V salesman/installer.
I would like to know what they mean when they say that the Monoprice HDMI cable "is not 4k compatible". They may bring that up again, and I would like to have a response for them.
Thanks again for all your help guys, Richard
post #13 of 54 Old 04-30-2014, 11:34 AM - Thread Starter
Quoted: 16 Post(s)
As I told Doublewing, Thanks for giving me the confidence to confront these sales people.
What do you think of the projector and BluRay player they suggested?
Thanks for your support, Richard
post #14 of 54 Old 04-30-2014, 02:52 PM
Liked: 2744
Oppo is THE number one recommended Bluray player on this forum, hands down. Personally I just installed an Epson 5030 and I rank it lower than the JVC, Sony and Panasonic that I've installed lately.
post #15 of 54 Old 05-01-2014, 07:50 AM
HopefulFred's Avatar
Quoted: 490 Post(s)
Liked: 422
You're not installing a 4K projector or player - why would you install a 4K compatible HDMI cable? (if such a thing were to exist) Similarly, you're not installing a Ferrari (not that there's anything wrong with the Epson, per se)
Go to the source of HDMI-related information: http://www.hdmi.org/consumer/finding_right_cable.aspx A common high-speed cable is all you need.
HopefulFred is offline
post #16 of 54 Old 05-01-2014, 10:34 AM
UGAd13's Avatar
Quoted: 100 Post(s)
Liked: 121
http://www.cnet.com/news/why-all-hdmi-cables-are-the-same/
Big box stores and dealers make the most money (margin) on accessories. Monoprice cables are used throughout this forum on builds ranging from budget to extreme.
If you have some time, cruise through the different sub-forums on here and get more comfortable with the gear you are purchasing.
If your installer keeps hard selling the expensive cables you should look elsewhere.
wraunch and willmo like this.
My living room budget build: Samsung PN51E530 / Denon AVR1613 / DefTech PC1000 / DefTech PM60 / DefTech ProSub 60 / Dayton Sub1200
UGAd13 is offline
post #17 of 54 Old 05-01-2014, 10:44 AM
UGAd13's Avatar
Quoted: 100 Post(s)
Liked: 121
p.s. http://www.monoprice.com/Product?c_id=102&cp_id=10255&cs_id=1025501&p_id=9169&seq=1&format=2
Look at what it supports... That's one of their "Ferrari" cables.
UGAd13 is offline
post #18 of 54 Old 05-01-2014, 12:51 PM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
Personally I wouldn't spend that much on a blu-ray player with that set-up, I'd just get a $150-250 ish one. And definitely get the HDMI from monoprice.
JWagstaff is offline
post #19 of 54 Old 05-01-2014, 01:30 PM
Nyal Mellor's Avatar
Quoted: 435 Post(s)
Liked: 312
I think installation seems reasonable. I guess they are pulling a new cable to the PJ, which might include some sheetrock cutting, patching, who knows. Couple that to uninstalling all the old stuff, changing the PJ mount, unpacking all the new stuff, hanging the new mount, aligning the PJ, tidying up it's probably not that unreasonable. Remember this is the Bay Area. It's expensive to live out here, labor rates are higher than in the rest of the country. My senior installer is $85/hr. Sure it's cheaper to DIY, but not everyone wants to do that, or has the skills to.
Mfusick likes this.
Want to learn about home theater design and acoustics? Read our blog.
Company: Acoustic Frontiers - design and creation of high performance home theaters for discerning audio/video enthusiasts.
Certifications: HAA Level I & II, THX Video Level I & II, CEDIA EST I & II.
AVS Projects: Too many to show in my signature - see here for the master list.
Nyal Mellor is offline
post #20 of 54 Old 05-01-2014, 11:11 PM - Thread Starter
Quoted: 16 Post(s)
Thanks. I went to the HDMI site and found this recommendation:
High Speed HDMI Cable
The High Speed HDMI cable is designed and tested to handle video resolutions of 1080p and beyond, including advanced display technologies such as 4K, 3D, and Deep Color. If you are using any of these technologies, or if you are connecting your 1080p display to a 1080p content source, such as a Blu-ray Disc player, this is the recommended cable.
I plan to connect to a "Blu-ray Disc player", so it would seem that I should use the High Speed HDMI Cable rather than the Standard HDMI Cable. Right?
post #21 of 54 Old 05-01-2014, 11:14 PM - Thread Starter
Quoted: 16 Post(s)
Great article. Thank you, R
post #22 of 54 Old 05-01-2014, 11:18 PM - Thread Starter
Quoted: 16 Post(s)
Thanks. It's gotta be good enough for my system. If the installer objects to using that cable, I will look elsewhere for an installer/equipment vendor.
kinw3 likes this.
post #23 of 54 Old 05-01-2014, 11:19 PM - Thread Starter
Quoted: 16 Post(s)
I agree. I will be paying them by the hour, so their estimate is irrelevant.
post #24 of 54 Old 05-01-2014, 11:21 PM - Thread Starter
Quoted: 16 Post(s)
How is it that one Blu-ray player is better than another. Do they not all translate the digital signal from the disc into the same information that is then fed to the projector? If you can afford the time to explain this to me, I would be grateful.
Richard
post #25 of 54 Old 05-02-2014, 06:41 AM
Liked: 2744
post #26 of 54 Old 05-02-2014, 06:57 AM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
Richard
It's a a bit controversial topic... some people swear they can notice huge differences between blu-ray players, but most data says there is none or very small differences. In general you're right digital is digital. I wouldn't go out and buy a $35.00 blu-ray player though. High end blu-ray players are better at upconverting features for converting SD to HD, but as far as blu-ray HDMI output the signal should be the same. Higher end ones also support DVD-A and SACD and have much better DAC's for analog playback. Also better streaming features and other software things.
post #27 of 54 Old 05-02-2014, 10:00 AM
Liked: 2744
Don't forget that unit comes with Darbee.
post #28 of 54 Old 05-02-2014, 10:59 AM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
ah, true. So the signal is different.
post #29 of 54 Old 05-07-2014, 09:28 PM - Thread Starter
Quoted: 16 Post(s)
Thanks for the explanation. Might there be a difference in the robustness of the Blu-ray players? I am a Netflix user and find that my current DVD player cannot abide scratches and leaves me hanging in the middle of a movie scene frantically pushing my FF button to try to drive through the damaged portion of the disk.
post #30 of 54 Old 05-07-2014, 09:30 PM - Thread Starter
Quoted: 16 Post(s)
Is Darbee something I want to look for in any Blu-ray player? Do all Oppo units come with Darbee?
